'i2s_pop_sample' was not declared in this scope
MEL_21
Postby MEL_21 » Sun May 09, 2021 9:00 am
Hello All,
I am using the Arduino IDE 1.8.13 with the ESP32 boards definition v1.0.6 and I am trying to compile the I2S sample code (from: https://diyi0t.com/i2s-sound-tutorial-for-esp32) and get the error: 'i2s_pop_sample' was not declared in this scope.
What else do I need to install to make this work?
(the other calls in the code seem to be compiling fine)
Thanks,
Markus
#include "driver/i2s.h"
const i2s_port_t I2S_PORT = I2S_NUM_0;
  esp_err_t err;
  // The I2S config as per the example
  const i2s_config_t i2s_config = {
      .mode = i2s_mode_t(I2S_MODE_MASTER | I2S_MODE_RX), // Receive, not transfer
      .sample_rate = 16000,                         // 16KHz
      .bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT, // could only get it to work with 32bits
      .channel_format = I2S_CHANNEL_FMT_ONLY_RIGHT, // use right channel
      .communication_format = i2s_comm_format_t(I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB),
      .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,     // Interrupt level 1
      .dma_buf_count = 4,                           // number of buffers
      .dma_buf_len = 8                              // 8 samples per buffer (minimum)
  // The pin config as per the setup
  const i2s_pin_config_t pin_config = {
      .bck_io_num = 26,   // Serial Clock (SCK)
      .ws_io_num = 25,    // Word Select (WS)
      .data_out_num = I2S_PIN_NO_CHANGE, // not used (only for speakers)
      .data_in_num = 33   // Serial Data (SD)
  // Configuring the I2S driver and pins.
  // This function must be called before any I2S driver read/write operations.
  err = i2s_driver_install(I2S_PORT, &i2s_config, 0, NULL);
  if (err != ESP_OK) {
    Serial.printf("Failed installing driver: %d\n", err);
    while (true);
  err = i2s_set_pin(I2S_PORT, &pin_config);
    Serial.printf("Failed setting pin: %d\n", err);
    while (true);
  Serial.println("I2S driver installed.");
  // Read a single sample and log it for the Serial Plotter.
  int32_t sample = 0;
  int bytes_read = i2s_pop_sample(I2S_PORT, (char *)&sample, portMAX_DELAY); // no timeout
  if (bytes_read > 0) {
    Serial.println(sample);
MEL_21
Re: 'i2s_pop_sample' was not declared in this scope
Postby MEL_21 » Sun May 09, 2021 5:48 pm
OK found the issue: it's marked 'deprecated' - and has been replaced with 'i2s_read()'.
rv2442
Postby rv2442 » Mon Oct 18, 2021 9:55 am
im having the same issue can you guide on what you did to make it work?? pls explain in a way i can understand as im a noob in i2s as well as esp32
MEL_21
Postby MEL_21 » Tue Oct 19, 2021 12:32 pm
As I wrote the function call is old and had been replaced. use something like this:
void setup()
    .sample_rate = 5000,                         // 5KHz
    .bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT, // 16bit samples
    .channel_format = I2S_CHANNEL_FMT_ONLY_LEFT, // use left channel
    .communication_format = i2s_comm_format_t(I2S_COMM_FORMAT_STAND_I2S),
    .dma_buf_count = 3,                           // number of buffers
    .dma_buf_len = ARRAY_SIZE                     // samples per buffer
    .bck_io_num = 8,   // Serial Clock (SCK)
    .ws_io_num = 9,    // Word Select (WS)
    .data_in_num = 10   // Serial Data (SD)
    while (true);
    while (true);
int16_t sBuffer[ARRAY_SIZE];
void loop()
    size_t bytesIn = 0;
    esp_err_t result = i2s_read(I2S_PORT, sBuffer, sizeof(sBuffer), &bytesIn, /*portMAX_DELAY*/ 10); // no timeout
    if (result == ESP_OK && bytesIn > 0)
    	// do your processing
Users browsing this forum: Baidu [Spider] and 136 guests
