An esp32 died during my hardware development. Everything worked fine for a day or two and then the chip quit responding to any uart RX input from my ftdi usb converter. I have a suspicion that the problem might be that the ftdi kept putting out its TX signal at 3.3v with low impedance while my chip was powered down (the chip uses a different supply, not the usb power).
If the esp used normal protection diodes then I understand how this might have happened. The ftdi would be trying to power up the esp through the protection diode. I have seen this kind of behavior in other chips. If the esp drew a lot of current from the ftdi I could see how the protection diode, if not the input itself, might be damaged from the current.
But I have heard that the esp32 uses snapback circuits instead of diodes. If I understand them correctly the snapbacks are triggered at a specific voltage, like 6V, not by 0.7V above the vdd pin as diodes are.
The reason I am concerned is that I'm worried something else in my circuitry is at fault. I would appreciate any opinions as to my theory about the different kinds of protection work. To ask a specific question, what voltage is allowed on an input pin when the chip is powered down?
What is max input pin voltage when esp32 is powered down?
Re: What is max input pin voltage when esp32 is powered down?
Its good practice to never have power going to any GPIO pin when the processor is powered down. Backfeed issues can kill a pin.
If they are powered from different sources you should some form of isolation to prevent this like and opto, or other means.
Users browsing this forum: No registered users and 115 guests
