Strange errors with TFT_eSPI
Rubbernose
Postby Rubbernose » Wed Jun 02, 2021 1:40 pm
I want to show values an an ESP32 with TFT-Display. The values are stored in an array. The serial monitor shows the correct values, but the TFT display not. all examples are working propperly.
In my code are two errors!!!
1) on every 4th row is a huge value. Why?
If the part in the setup is uncommented, this error disappears.
2) the value on the TFT freezes
Why???
int Drehmom[10];
int DrehmomPointer;
#include <TFT_SB_1.h>            //  own pins
TFT_eSPI tft = TFT_eSPI();       // by Bodemer
  tft.init();
  tft.fillScreen(TFT_BLACK);
  Serial.begin(57600);
Drehmom[0]=0;
Drehmom[1]=0;
Drehmom[2]=0;
Drehmom[3]=0;
Drehmom[4]=0;  // 1061177988
Drehmom[5]=0;
Drehmom[6]=0;
Drehmom[7]=0;
Drehmom[8]=0;
Drehmom[9]=0;
      DrehmomPointer++;
      if(DrehmomPointer > 8) {DrehmomPointer=1;}
      tft.drawNumber(DrehmomPointer, 100, 80, 6);
      //Drehmom[DrehmomPointer] = 5;     // stopps at 3
      //Drehmom[1] = 5;                  // ok
      //Drehmom[2] = 5;                  // ok
      //Drehmom[3] = 5;                  // stopps at 1
      //Drehmom[4] = 5;                  // ok
      //Drehmom[5] = 5;                  // ok
      //Drehmom[6] = 5;                  // ok
      //Drehmom[7] = 5;                  // ok
      Drehmom[8] = 5;                  // ok
      Drehmom[0] = Drehmom[1] + Drehmom[2] + Drehmom[3] + Drehmom[4] + Drehmom[5] + Drehmom[6] + Drehmom[7] + Drehmom[8]  ;
      Serial.print(" Pointer: ");Serial.print  (DrehmomPointer); Serial.print("\t");
      Serial.print(" Drehmom: ");Serial.println(Drehmom[DrehmomPointer]);
      delay(50);
I changed the declaration as long, Pointer as Byte, instead drawNumber i tried drawString(String...). Without success.
Any ideas?[/Codebox]
ESP_Sprite
Re: Strange errors with TFT_eSPI
Postby ESP_Sprite » Thu Jun 03, 2021 1:49 am
If anything, you declare Drehmom to have 10 entries (drehmom[0] to drehmom[9]), but then set entries 0 to 10.
Rubbernose
Postby Rubbernose » Fri Jun 04, 2021 10:10 am
Yes, sorry for the [10]. That was from earlier experiments.
My solution was to change the order from:
int Drehmom[10];
int DrehmomPointer;
to
int DrehmomPointer;
int Drehmom[10];
Now it works, but i don't know why...
ESP_Sprite
Postby ESP_Sprite » Sat Jun 05, 2021 7:49 am
Still sounds like you're overwriting Drehmom[10], which is out of bounds of the array as you defined it. By changing the order, you're overwriting something else instead, which is not immediately obvious but will lead you to problems later.
Rubbernose
Postby Rubbernose » Sat Jun 05, 2021 10:23 am
No, ...
Users browsing this forum: Google [Bot] and 233 guests
