After i using the command ‘make app’,one error happen.I don't know how to solve it. Do the compile system have some mistakes?
// Error log
CC ulp_example_main.o
ULP_BIN ulp_main.bin
E:\Aithinker\13_Aithinker_IDE\AiThinkerIDE_V0.5\cygwin\home\aithinker\esp32ulp-elf-binutils\bin\esp32ulp-elf-objcopy.exe:/home/aithinker/down_git_esp-idf/esp-idf/examples/system/ulp/build/main/ulp_main.bin: No such file or directory
make[1]: *** [/cygdrive/e/Aithinker/13_Aithinker_IDE/AiThinkerIDE_V0.5/cygwin/home/aithinker/down_git_esp-idf/esp-idf/components/ulp/component_ulp_common.mk:55: /home/aithinker/down_git_esp-idf/esp-idf/examples/system/ulp/build/main/ulp_main.bin] Error 1
make: *** [/cygdrive/e/Aithinker/13_Aithinker_IDE/AiThinkerIDE_V0.5/cygwin/home/aithinker/down_git_esp-idf/esp-idf/make/project.mk:386: main-build] Error 2
One error happen when compiling the example of ulp
Re: One error happen when compiling the example of ulp
Could you please post:
1. the output of make V=1
2. the contents of /home/aithinker/down_git_esp-idf/esp-idf/examples/system/ulp/build/main
The output of 'make V=1ESP_igrr wrote:Could you please post:
make[1]: Entering directory '/home/aithinker/down_git_esp-idf/esp-idf/examples/system/ulp/build/xtensa-debug-module'
make[1]: Leaving directory '/home/aithinker/down_git_esp-idf/esp-idf/examples/system/ulp/build/xtensa-debug-module'
Target 'xtensa-debug-module-build' responsible for '/home/aithinker/down_git_esp-idf/esp-idf/examples/system/ulp/build/xtensa-debug-module/libxtensa-debug-module.a'
make -C /home/aithinker/down_git_esp-idf/esp-idf/examples/system/ulp/build/main -f /cygdrive/e/Aithinker/13_Aithinker_IDE/AiThinkerIDE_V0.5/cygwin/home/aithinker/down_git_esp-idf/esp-idf/make/component_wrapper.mk COMPONENT_MAKEFILE=/home/aithinker/down_git_esp-idf/esp-idf/examples/system/ulp/main/component.mk COMPONENT_NAME=main build
make[1]: Entering directory '/home/aithinker/down_git_esp-idf/esp-idf/examples/system/ulp/build/main'
esp32ulp-elf-objcopy -O binary ulp_main.elf /home/aithinker/down_git_esp-idf/esp-idf/examples/system/ulp/build/main/ulp_main.bin
make[1]: Leaving directory '/home/aithinker/down_git_esp-idf/esp-idf/examples/system/ulp/build/main'
./component_project_vars.mk
./embed_bin
./pulse_cnt.ulp.d
./pulse_cnt.ulp.lst
./pulse_cnt.ulp.o
./ulp_example_main.d
./ulp_example_main.o
./ulp_main.common.d
./ulp_main.common.ld
./ulp_main.elf
./ulp_main.h
./ulp_main.ld
./ulp_main.map
./ulp_main.sym
FYI.
Hi Tony,
Do you only get this error when building the ULP example, or you get an error when building other examples?
What build environment are you using? ESP-IDF build system only supports using MSYS2, as described in the docs here. This example builds for me in the MSYS2 build environment we provide with IDF.
It looks like you may be using a different Cygwin environment? Can you provide any details?
Cygwin paths (like /home/xxx) are only supported by Cygwin programs, and the ESP32 & ULP toolchains are MINGW programs not Cygwin. We do some tricks inside the ESP-IDF build system in order to convert paths to the correct formats, but it's possible if you're using a Cygwin environemnt (ie Cygwin version of "make", etc) then it may not be converting them properly.
Angus
Angus
All example are OK, except ULP example.ESP_Angus wrote:Hi Tony,
Angus
My build environment is Cygwin.
In your opinion,the attached (https://dl.espressif.com/dl/esp32ulp-el ... b4f341.zip) is only used for MSY2?
It's not only used for MSYS2, but it's a MINGW executable which is different to Cygwin, and means it can't resolve Cygwin paths. I am guessing the "make" you are running is a Cygwin make, so "make" is resolving Cygwin absolute paths - which the toolchain cannot understand.tony2simmy wrote: All example are OK, except ULP example.
We only officially support MSYS2 for ESP-IDF, but if you can give me more details about your build environment (can I download it somewhere?) then we may be able to help you resolve this issue.
(Alternatively, you can recompile the entire toolchain for Cygwin. But I do not recommend doing this, it's tricky to do and the resulting toolchain will be slower.)
Hi Angus,ESP_Angus wrote:It's not only used for MSYS2, but it's a MINGW executable which is different to Cygwin, and means it can't resolve Cygwin paths. I am guessing the "make" you are running is a Cygwin make, so "make" is resolving Cygwin absolute paths - which the toolchain cannot understand.tony2simmy wrote: All example are OK, except ULP example.
I download the SDK from 'http://wiki.ai-thinker.com/ai_ide_install'.It use Chinese to describe.
Users browsing this forum: No registered users and 249 guests
