I am trying cross compile mongo C driver to ESP32 platform on Ubuntu OS, which uses the xtensa-esp32-elf-gcc toolchain (gcc 5.2.0 based, compiled from crossNg tools). The toolchain has its own sysroot, which has an incomplete glibc library built-in.
After numerous tries on the compilation, I finally managed to run the ./configure command successfully, along with lots of LDFLAGS and CPPFLAGS. But I still unable to "make" the source because there are lack of glibc headers and library on the xtensa-esp32 toolchain, such as poll.h, sys/uio.h and etc.
Is there any possible way to build the mongo C driver for xtensa-esp32 toolchain? Or it is not possible at all.
Your suggestions and help is very much appreciated!
Regards,
Peter
Cross compile Mongo C Driver for xtensa-esp32-elf Toolchain
Re: Cross compile Mongo C Driver for xtensa-esp32-elf Toolchain
Xtensa toolchain for ESP32 doesn't come with glibc; we use newlib as our C library. For this reason some facilities you mention (poll, sys/uio) are not provided. Glibc is not easy to port to an RTOS, for this reason most MCU toolchains use newlib, musl, or some other stripped down standard library implementation.
I haven't found any mentions or ports of Mongo C driver for microcontrollers. The project page lists a number of supported platforms, but all of them are fully featured OSes, not RTOSes.
Users browsing this forum: No registered users and 194 guests
