MCPWM fault - low level trigger
elexinverter
Postby elexinverter » Thu Jul 29, 2021 9:21 am
Greetings,
The documentation for MCPWM fault initialization function mcpwm_fault_init describes
Initialize fault submodule, currently low level triggering is not supported
also the definition for its argument in mcpwm.h file says
typedef enum {
    MCPWM_LOW_LEVEL_TGR = 0,  /*!<Fault condition occurs when fault input signal goes from high to low, currently not supported*/
    MCPWM_HIGH_LEVEL_TGR,     /*!<Fault condition occurs when fault input signal goes low to high*/
} mcpwm_fault_input_level_t;
I am not able to find a reason as to why low level trigger should not be used.
I have tried using initialization with
MCPWM_LOW_LEVEL_TGR
and the module works as it should with low level fault trigger.
Can somebody put a light on this? Is there an errata or bug report?
Thanks.
Users browsing this forum: No registered users and 147 guests
