How to run Mongoose HTTPS server
gost.404
Postby gost.404 » Sun Jul 02, 2017 10:16 am
Hi All!
I'm trying to run a HTTPS server and I already run up HTTP version.
After that I found example in Mongoose official docs https://docs.cesanta.com/mongoose/master/#/http/ssl.md/ and also see pcbreflux example of ssl_webserver. I was alert to various methods of certification and key specifying and I start walk down in Mongoose method:
 mg_bind_opt() -> mg_ssl_if_conn_init() -> mg_use_cert() -> SSL_CTX_use_certificate_file()
Here the definition of SSL_CTX_use_certificate_file():
int SSL_CTX_use_certificate_file(SSL_CTX *ctx, const char *file, int type)
    return 0;
So what the question: can I to use Mongoose HTTPS server without changing its implementation and, if can, how to do this?
WiFive
Re: How to run Mongoose HTTPS server
Postby WiFive » Sun Jul 02, 2017 6:23 pm
gost.404
Postby gost.404 » Mon Jul 03, 2017 5:54 pm
WiFive, I understand, this question will be more correct to ask on Mongoose forum, but the last function in that chain (SSL_CTX_use_certificate_file) is a part of esp-idf
WiFive
Postby WiFive » Tue Jul 04, 2017 5:00 am
I think the answer is that the mongoose in mongoose-os has changes to support esp32 so you should consider using that.
Otherwise you can switch to one of the methods for reading certificates that is supported by esp-idf openssl wrapper.
Users browsing this forum: No registered users and 256 guests
