I cann't SPI(VSPI) communication between external ADC and esp32-wrover-e with esp32-idf
Hello
I am going to SPI (VSPI) communicate with external ADC using esp32-wrover-e and esp32-idf
It works well in arduino code as below, however, in esp32-idf, I cannot read or write the register value.
I tried to approach using some methods, but they did not communicate normally.
I want to know what's wrong with my code on esp32-idf.
thanks
1. Arudino code (good works)
int CS = 5;
unsigned char g_cData = 0x01;
void setup()
pinMode(CS, OUTPUT); // Chip Select pin is output
digitalWrite(CS, HIGH); // initial state is High
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE0);
SPI.begin();
void loop()
int val1, val2;
char sbuf[100];
unsigned char cRegister = 0xE;
digitalWrite(CS, LOW);
/* write a data (g_cData) to a register (0xE) */
SPI.transfer(cRegister | 0x80);
SPI.transfer(g_cData);
sprintf(sbuf, "[Write] 0x%x to a Register (0x0E)\r\n", g_cData);
Serial.print(sbuf);
/* read a data (val2) from a register (0xE) */
SPI.transfer(cRegister | 0x40);// default : full duplex
val1 = SPI.transfer(0x00);
val2 = SPI.transfer((byte)0);
g_cData++;
sprintf(sbuf, "[Read] 0x%x from a Register (0x0E)\r\n", val1, val2);
Serial.print(sbuf);
delay(1000);
<Result>
[Write] 0x01 to a Register (0x0E)
[Read] 0xFF, 0x01 from a Register (0x0E)
[Write] 0x02 to a Register (0x0E)
[Read] 0xFF, 0x02 from a Register (0x0E)
[Write] 0x03 to a Register (0x0E)
[Read] 0xFF, 0x03 from a Register (0x0E)
[Write] 0x04 to a Register (0x0E)
[Read] 0xFF, 0x04 from a Register (0x0E)
2. ESP32-IDF (didnt work)
#define SPI_CS_PIN_O 5
#define SPI_SCLK_PIN_O 18
#define SPI_MOSI_PIN_O 23
#define SPI_MISO_PIN_I 19
#define DMA_CHAN 2
spi_device_handle_t g_SPI = 0;
void app_main(void)
bInit_spi_master();
bool bInit_spi_master()
esp_err_t ret;
spi_device_handle_t spi;
spi_host_device_t SPI_BUS = VSPI_HOST;
spi_bus_config_t buscfg = {
.miso_io_num = SPI_MISO_PIN_I,
.mosi_io_num = SPI_MOSI_PIN_O,
.sclk_io_num = SPI_SCLK_PIN_O,
.quadwp_io_num = -1,
.quadhd_io_num = -1,
.max_transfer_sz = (4 * 8),
.flags = SPICOMMON_BUSFLAG_MASTER,
spi_device_interface_config_t devcfg = {
.mode = 0,
.clock_speed_hz = 10 * 1000 * 1000,
.spics_io_num = SPI_CS_PIN_O,
.queue_size = 1,
.pre_cb = NULL,
.post_cb = NULL,
//Initialize the SPI bus
ret = spi_bus_initialize(SPI_BUS, &buscfg, DMA_CHAN);
ESP_ERROR_CHECK(ret);
//Attach the SPI bus
ret = spi_bus_add_device(SPI_BUS, &devcfg, &spi);
g_SPI = spi;
/* Test */
writeData(cRegister, 0xab);
readData(cRegister);
void writeData(uint8_t addr, char data)
spi_transaction_t t;
uint8_t u8Tx[4] = {0};
u8Tx[0] = (addr | 0x80);
u8Tx[1] = data;
memset(&t, 0, sizeof(t));
t.flags = SPI_TRANS_USE_TXDATA;
t.length=2*8;
t.tx_buffer=u8Tx; //Data
esp_err_t ret = spi_device_transmit(g_SPI, &t);
assert(ret==ESP_OK);
uint8_t readData(uint8_t addr)
uint8_t u8Rx[4] = {0};
u8Tx[0] = (addr | 0x40);
t.length=4*8;
t.tx_buffer=u8Tx;
t.rx_buffer=u8Rx;
printk("READ(0xE)%d : 0x%x, 0x%x, 0x%x, 0x%x\r\n", t.rxlength, u8Rx[0], u8Rx[1], u8Rx[2], u8Rx[3]);
return 0;
<Result>
Read(0xE)24 : 0x0, 0x0, 0x0, 0x0
thanks
int CS = 5;
void setup()
SPI.begin();
void loop()
int val1, val2;
char sbuf[100];
Serial.print(sbuf);
g_cData++;
Serial.print(sbuf);
delay(1000);
<Result>
#define DMA_CHAN 2
void app_main(void)
bInit_spi_master();
esp_err_t ret;
.mode = 0,
.queue_size = 1,
.pre_cb = NULL,
.post_cb = NULL,
g_SPI = spi;
/* Test */
u8Tx[1] = data;
t.length=2*8;
t.length=4*8;
t.tx_buffer=u8Tx;
t.rx_buffer=u8Rx;
return 0;
<Result>
Re: I cann't SPI(VSPI) communication between external ADC and esp32-wrover-e with esp32-idf
Hm, I can't see any fault in your code... only difference is that Arduino defaults to 1MHz, while your ESP-IDF code sets the SPI speed to 10MHz. Perhaps 10MHz is too fast for your hardware?
Thanks your response
I did the same test with an SPI speed of 1 MHz.
But it still didn't work.
Can you connect a logic analyzer or oscilloscope to the wires, see what it does? Alternatively, if you remove your ADC and connect MOSI to MISO on the ESP, what result do you get?
It works well in my arduino code, so I don't think it's a hardware issue. Is there anything I need to configure regarding the esp32-idf API or menuconfig?
thanks
thanks
No, reasonably simple transfers like this should just work.
Could you give me a clue on how to solve it?
Thanks.
Thanks.
As I said, connecting a LA or scope to the signals would help tremendously in seeing what part of the SPI stuff actually goes wrong.
Thanks for the replies and advice.
I changed some codes on ESP32-IDF.
And then, I checked output wave from the ESP32.
SDI output no signal when I used ESP32-IDF code
but, there are them on arduino code
but, In the Arduino codes, the SDI output waveform is observed.
I used 24bit ADS (TI, ADS127L11)
1. The output data frame : Read Register Data on ADS127L11
[img]d:\Work\NewPSS\ADS.PNG[/img]
2. esp32-idf codes
t.flags = SPI_TRANS_USE_TXDATA | SPI_TRANS_USE_RXDATA;
t.rxlength = 8 * 1;
t.length = 8 * 1; .
t.tx_data[0] = u8Tx[0];
cs_low();
ret=spi_device_transmit(g_SPI, &t);
assert(ret == ESP_OK);
t.flags = SPI_TRANS_USE_RXDATA;
t.rxlength = 8 * 1; //Len is in bytes, transaction length is in bits.
t.length = 8 * 1;
cs_high();
cs_low();
cs_high();
for (int i = 0; i < 4; i++) {
u8Rx = t.rx_data;
3. Screen shots
[img]d:\Work\NewPSS\arduino_01.png[/img]
sjkim
2. esp32-idf codes
t.rxlength = 8 * 1;
t.length = 8 * 1; .
cs_low();
t.length = 8 * 1;
cs_high();
cs_low();
cs_high();
u8Rx = t.rx_data;
3. Screen shots
sjkim
- ads127l11.pdf
- (2.78 MiB) Downloaded 302 times
- arduino_01.png (29.29 KiB) Viewed 4198 times
- ADS.PNG (18.71 KiB) Viewed 4198 times
You have an image of the LA trace of the Arduino code? What does the equivalent ESP-IDF code trace look like?
If anything, you don't memset() your transaction to 0 before the first byte you send. As t is allocated on the stack, this may lead to uninialized members of t to contain garbage.
Users browsing this forum: Rckyan and 190 guests
