ESP32 SPI external flash driver help
zazas321
Postby zazas321 » Mon Oct 18, 2021 8:30 am
Hello. I have recently written my own I2C driver, now I am trying to work with the SPI and write my own external flash memory driver.
The flash chip datasheet:
https://datasheet-pdf.com/PDF/GD5F1GQ4U ... ice-791680
I have a function that is supposed to send some data over SPI:
static void spi_cmd(spi_device_handle_t spi, const uint8_t cmd)
    esp_err_t ret;
    spi_transaction_t t;
    memset(&t, 0, sizeof(t));       //Zero out the transaction
    t.length=8;                     //Command is 8 bits
    t.tx_buffer=&cmd;               //The data is the cmd itself
    t.user=(void*)0;                //D/C needs to be set to 0
    ret=spi_device_polling_transmit(spi, &t);  //Transmit!
    assert(ret==ESP_OK);            //Should have had no issues.
I initialise SPI bus:
void SPI_init(){
    esp_err_t ret;
    //spi_device_handle_t spi;
    spi_bus_config_t buscfg={
        .miso_io_num=PIN_NUM_MISO,
        .mosi_io_num=PIN_NUM_MOSI,
        .sclk_io_num=PIN_NUM_CLK,
        .quadwp_io_num=-1,
        .quadhd_io_num=-1,
        .max_transfer_sz=PARALLEL_LINES*320*2+8
    spi_device_interface_config_t devcfg={
        .clock_speed_hz=10*1000*1000,           //Clock out at 10 MHz
        .mode=0,                                //SPI mode 0
        .spics_io_num=PIN_NUM_CS,               //CS pin
        .queue_size=7,                          //We want to be able to queue 7 transactions at a time
        //.pre_cb=lcd_spi_pre_transfer_callback,  //Specify pre-transfer callback to handle D/C line
Note that spi_device_handle_t I have created as global because I may need to access the SPI functions from other components so it is more convenient to have it global even thought this may not be the best solution.
My full .c file:
#include "GD5F1GQ4UEYIG.h"
spi_device_handle_t external_flash;
    esp_err_t ret;
uint32_t GD5F1_get_id(spi_device_handle_t spi)
    //get_id cmd
    spi_cmd(spi, 0x9F);
    t.length=8*3;
    t.flags = SPI_TRANS_USE_RXDATA;
    t.user = (void*)1;
    esp_err_t ret = spi_device_polling_transmit(spi, &t);
    assert( ret == ESP_OK );
    return *(uint32_t*)t.rx_data;
void GD5F1_init(spi_device_handle_t spi)
    //detect LCD type
    uint32_t GD5F1_id = GD5F1_get_id(spi);
    printf("GD5F1_id: %08X\n", GD5F1_id);
void SPI_init(){
    esp_err_t ret;
        .quadwp_io_num=-1,
        .quadhd_io_num=-1,
    //Initialize the SPI bus
    ret=spi_bus_initialize(EEPROM_HOST, &buscfg, DMA_CHAN);
    ESP_ERROR_CHECK(ret);
    //Attach the LCD to the SPI bus
    ret=spi_bus_add_device(EEPROM_HOST, &devcfg, &external_flash);
my full .h file:
#ifndef GD5F1GQ4UEYIG_H
#define GD5F1GQ4UEYIG_H
#ifdef __cplusplus
extern "C" {
#endif
#include "driver/spi_master.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
#include "string.h"
#define EEPROM_HOST    HSPI_HOST
#define DMA_CHAN    2
#define PIN_NUM_MISO 19 // OK
#define PIN_NUM_MOSI 23 // OK
#define PIN_NUM_CLK  18 // OK
#define PIN_NUM_CS   5  // OK
#define PARALLEL_LINES 16
extern spi_device_handle_t external_flash;
void SPI_init();
uint32_t GD5F1_get_id(spi_device_handle_t spi);
void GD5F1_init(spi_device_handle_t spi);
#ifdef __cplusplus
#endif
#endif
And in my main.c I do:
    SPI_init(); // initialise SPI bus
    printf("getting spi id \n");
    GD5F1_init(external_flash); // initialise SPI device GD5F1 ( external flash)
I am trying to understand a little bit more about how SPI works and how can I read from registers.
https://ibb.co/3Skn8nL
For example, when I send the command 9F ( Read ID), do I also need to send something else? For example, do I need to send the addresses as shown in Read ID command description?
The result I get from my read_id command is:
getting spi id
GD5F1_id: 00FFFFFF
zazas321
Re: ESP32 SPI external flash driver help
Postby zazas321 » Mon Oct 18, 2021 12:26 pm
After watching this video, I have decided to follow a different approach:
https://www.youtube.com/watch?v=El6sEEQ ... =Michaelee
void GD5F1_read_reg(spi_device_handle_t spi, uint8_t reg, uint8_t* data){
    cs_low();
    memset(&t,0,sizeof(t));
    t.length = 8;
    t.tx_buffer = ®
    spi_device_transmit(spi,&t);
    t.length = 8;
    cs_high();
    *data = t.rx_data[0];
void GD5F1_read_id(spi_device_handle_t spi){
    uint8_t reg = 0x9F;
    uint8_t id;
    GD5F1_read_reg(spi,reg,&id);
    printf("ID read = %02X \n",id);
This seems to make more sense than the esp-idf SPI examples. However, I still read the same result 0xEF.
ESP_Sprite
Postby ESP_Sprite » Tue Oct 19, 2021 12:43 am
According to your datasheet, the command 0x9F needs an address byte indicating where in the ID space you want to start the read.
zazas321
Postby zazas321 » Tue Oct 19, 2021 4:46 am
Hey. Thank you very much.
This is exactly what is confusing me. How do I send an additionall address byte indicating the ID? For example I have these 2 functions:
    cs_low();
    t.length = 8;
    t.tx_buffer = ®
    t.length = 8;
    cs_high();
    uint8_t reg = 0x9F;
    uint8_t id;
Could you please show me how should I need to modify them to get to read the device ID?
zazas321
Postby zazas321 » Tue Oct 19, 2021 5:21 am
From what I understand, I just need to send an additional byte as with the address. Please see my modified function below:
void GD5F1_read_id(spi_device_handle_t spi,uint8_t* data){
    uint16_t reg2 = 0x9f00;
    cs_low();
    t.length = 16;
    t.tx_buffer = &reg2;
    t.length = 8;
    cs_high();
As you can see from the function above, I am sending 2 bytes instead of 1 ( t.length = 16 and my reg2 contains 2 bytes) 0x9F for the command and 00 for the address ). With this command, I expect to read the C8 as described in the datasheet.
In my main.c I call:
        uint8_t id;
        GD5F1_read_id(external_flash,&id);
The result is not what I expect:
ID read = 40
ID read = 40
ID read = 40
ID read = 40
ID read = 40
ID read = 40
ID read = 40
ID read = 40
ID read = 40
What I am concerned is whether my SPI transmission is correct or whether I should try and look for hardware issues on my board.
zazas321
Postby zazas321 » Tue Oct 19, 2021 5:50 am
I have also tried another method:
    esp_err_t ret;
    //t.user=(void*)0;                //D/C needs to be set to 0
static void spi_data(spi_device_handle_t spi, const uint8_t *data, int len)
    esp_err_t ret;
    if (len==0) return;             //no need to send anything
    t.length=len*8;                 //Len is in bytes, transaction length is in bits.
    t.tx_buffer=data;               //Data
    //t.user=(void*)1;                //D/C needs to be set to 1
uint8_t get_id2(spi_device_handle_t spi)
    spi_cmd(spi, 0x9f);
    spi_data(spi,0x00,1);
    t.length=8;
    //t.user = (void*)1;
    printf("rx data = %02X \n",*t.rx_data);
    return *t.rx_data;
Then In my main.c I call:
        id = get_id2(external_flash);
        printf("id in task = %u \n",id);
The results are even more strange:
rx data = EF
id in task = 239
rx data = 16
id in task = 22
rx data = 00
id in task = 0
rx data = 00
id in task = 0
rx data = 00
id in task = 0
The first time data is read it returned 0xEF, then 0x16 and then after that just 0
ESP_Sprite
Postby ESP_Sprite » Tue Oct 19, 2021 6:47 am
Okay, no offense, but now you're just throwing stuff at the wall to see if it sticks. Every transaction you do takes CS down at the start and up at the end, so you're simply sending separate bytes and then aborting the transfer. That works for the LCD you copied the code from, but not for a flash chip.
If you actually want this to work properly, the best bet is to use the half-duplex mode of the SPI controller, then sending both the command, address and receiving the response in one transfer. Effectively:
* Read the docs first, for good measure.
* Configure your device to be half-duplex, using a command of 8 bits and an address length of 8 bits. (Note you may need to change that once you actually want to write/read data to the actual amount of address bits your flash reads and writes need. For reading the ID, you can then override it by specifying the deviating address length in spi_transaction_ext_t.)
spi_device_interface_config_t config={
	.command_bits=8,
	.address_bits=8,
	.flags=SPI_DEVICE_HALFDUPLEX.
* Use the command/address members to send that data, then receive what you need:
spi_transaction_t t={
	.cmd=0x9F,
	.addr=0x00,
	.flags=SPI_TRANS_USE_RXDATA,
	.rxlength=8
(Note that all the code here is untested, there may be small mistakes.)
zazas321
Postby zazas321 » Tue Oct 19, 2021 8:52 am
Thank you very much for the response. It is getting more clear how I need to use the SPI but not quite there yet. I would like to understand the below:
I have my get_id function below:
void get_id2(spi_device_handle_t spi)
	t.cmd=0x9F;
	t.addr=0x00;
	t.flags=SPI_TRANS_USE_RXDATA;
	t.rxlength=16;
    printf("rx data = %04X \n",*t.rx_data);
I am getting the following errors:
E (2610) spi_master: check_trans_valid(694): txdata transfer > host maximum
rx data = 000C
E (3620) spi_master: check_trans_valid(694): txdata transfer > host maximum
rx data = 00B0
E (4620) spi_master: check_trans_valid(694): txdata transfer > host maximum
rx data = 00B0
E (5620) spi_master: check_trans_valid(694): txdata transfer > host maximum
rx data = 00B0
E (6620) spi_master: check_trans_valid(694): txdata transfer > host maximum
rx data = 00B0
E (7620) spi_master: check_trans_valid(694): txdata transfer > host maximum
rx data = 00B0
E (8620) spi_master: check_trans_valid(694): txdata transfer > host maximum
rx data = 00B0
E (9620) spi_master: check_trans_valid(694): txdata transfer > host maximum
rx data = 00B0
E (10620) spi_master: check_trans_valid(694): txdata transfer > host maximum
I would like to understand more about the SPI structure:
From the datasheet I need to first send 2 bytes (command and address and then read 2 bytes back (manufacturer ID and device ID). So from what I understand, I first need to transmit 2 bytes, then receive 2 bytes.
My question:
Does this function:
Automatically transmits and then switches the mode to receive mode?
zazas321
Postby zazas321 » Tue Oct 19, 2021 9:07 am
I have connected the osciloscope and confirmed that the following function:
    uint8_t command_byte = 0x9F;
    uint8_t address_byte = 0x00;
	t.cmd=command_byte;
	t.addr=address_byte;
	t.rxlength=16;
Does not do anything. It does not even generate clock on my SPI pin.
I have then tested this command:
    cs_low();
    t.length = 16;
    t.length = 16;
    cs_high();
    *data = t.rx_data;
I know that the above function may not be correct. Since I am using tx_buffer and in the documentation it is mentioned not to touch it (I have seen it being used in some other examples though). But the important thing is, that I can see the clock being generated. Any suggestions what is happening and why the first function does nto generate the clock?
ESP_Sprite
Postby ESP_Sprite » Wed Oct 20, 2021 1:06 am
You're not using named initializers in your code (like I did in mine), nor are you clearing the spi_transaction_t structure using memset(). That leads to random data ending up in the members of that struct that you have not written, causing you that trouble.
Users browsing this forum: Baidu [Spider] and 115 guests
