Set USB port & Compile or install mkspiffs
arjfca
Postby arjfca » Tue Nov 30, 2021 3:03 am
Hello
Trying to install some code on a ESP32 but i'm stuck. I'm lost.
The original project is from this site. A Bluetooth thermometer interface gateway to wifi.
https://github.com/dereulenspiegel/ibbq-gateway
I did followed these procedures to install some code on an ESP32
Clone this repository somewhere
Connect the ESP32 board to your computer
Setup the ESP-IDF
Set the correct USB port via make menuconfig (see ESP-IDF documentation)
Change into the directory where you cloned this repository
Execute make flash_spiffs, wait for it to finish
Execute make flash, wait for it to finish
From these procedures,
- from a command line, How do I set a USB port to talk with the ESP32?
- How do I compile or install mkspiffs?
Any help appreciated
Martin
Montreal, Canada
Users browsing this forum: Baidu [Spider], Bing [Bot] and 175 guests
