High-resolution timer period is drifted when WiFi is active
I've set up a periodic high-resolution timer with the period 1000 us and it gets executed on average at 1000 us with three-sigma about 20 us. A few unheavy FreeRTOS tasks are running aside. The FreeRTOS tick rate is 100 Hz though I don't think it should matter - I ain't using a soft timer.
When I turn on either WiFi (I'm using a websocket client example) or Bluetooth classic, the timer is sometimes delayed for 7000 us. Even when the Bluetooth is idling, the timer period id drifted a lot - it gets executed at 400...2000 us period.
How do you deal with such a problem? I also don't find anything related to the priority of a high-resolution timer - I guess, there is no such an option.
It looks like the problem is more severe: not only high-resolution timers but also GPIO interrupts get delayed for a few milliseconds when I connect an external device that sends interrupts at a specified pin at a frequency of 2000 Hz with the WiFI/Bluetooth on.
Re: High-resolution timer period is drifted when WiFi is active
dont be shy, post some code
Here is the code. The "websocket_app_start()" function is taken from https://github.com/espressif/esp-idf/tr ... /websocket
The output:
If I don't start the websocket client, the timer period is preserved: 1000 ± 20 us.
int64_t last_tick = 0;
int64_t timer_dt_min = INT64_MAX;
int64_t timer_dt_max = 0;
static void timer_callback()
int64_t tick = esp_timer_get_time();
if (last_tick != 0) {
int64_t dt = tick - last_tick;
if (dt < timer_dt_min) timer_dt_min = dt;
if (dt > timer_dt_max) timer_dt_max = dt;
last_tick = tick;
void task_send() {
char data[512];
while (1) {
printf("dt_min = %lld us, dt_max = %lld us\n", timer_dt_min, timer_dt_max);
esp_websocket_client_send_bin(client, data, sizeof(data), portMAX_DELAY);
vTaskDelay(pdMS_TO_TICKS(1000));
void app_main() {
websocket_app_start();
const esp_timer_create_args_t sdp_timer_args = {
.callback = &timer_callback,
ESP_ERROR_CHECK(esp_timer_create(&sdp_timer_args, &sdp_timer));
ESP_ERROR_CHECK(esp_timer_start_periodic(sdp_timer, 1000));
xTaskCreatePinnedToCore(task_send, "task_send", 4096, NULL, 0, NULL, PRO_CPU_NUM);
I (5004) websocket: WEBSOCKET_EVENT_CONNECTED
dt_min = 305 us, dt_max = 1286 us
W (8174) wifi:<ba-add>idx:0 (ifx:0, 60:aa:ef:13:aa:68), tid:0, ssn:10, winSize:64
dt_min = 3 us, dt_max = 4065 us
Use a hardware timer with isr in iram
wifive is (as usual) right. The issue with esp_timer specifically is that it executes all the callbacks it has scheduled in series, in other words, if there's a callback scheduled from e.g. the wifi driver just before your callback is scheduled, your callback will only get called when the wifi driver callback is done. Additionally, non-IRAM interrupts and tasks get suspended on flash writes, in other words, flash writes can also delay your callback.
Thanks for your replies but I don't think a hardware timer will solve the problem. My mistake though - I've oversimplified the code in the description. Let me dive deeper into the problem.
I don't have a hardware timer with me but I have an SDP sensor with an IRQ pin that sends a "measurement ready" signal (high) to a pin of my ESP32 board. I've attached a callback with the IRAM_ATTR attribute to these interrupts and it does not solve the problem. Therefore, I conclude that a hardware timer won't solve it either. Below are the timings with and without a websocket active.
When the websocket is awaited for portMAX_DELAY rather than pdMS_TO_TICKS(10), the problem disappears - the delay is in the [349, 953] us range.
Full code for the "websocket_app_start()" is here https://github.com/dizcza/esp32-sdpsens ... ebsocket.c.
- Normally, the sensor sends interrupts at [470, 480] us period - that's precisely the "timer_dt_min" and "timer_dt_max" I see in a terminal when WiFi is inactive.
dt_min = 470 us, dt_max = 480 us
- When a websocket is functioning, the delay between successive events is drifted X2. It's already a problem, but not as severe as in the following example.
dt_min = 349 us, dt_max = 953 us
- Lastly, when the socket is disconnected, the delay is shifted dramatically (but only once)
W (3910) wifi:<ba-add>idx:0 (ifx:0, 60:aa:ef:13:aa:68), tid:0, ssn:10, winSize:64 dt_min = 349 us, dt_max = 953 us dt_min = 349 us, dt_max = 953 us dt_min = 349 us, dt_max = 953 us dt_min = 349 us, dt_max = 953 us E (5730) TRANSPORT_WS: Error transport_poll_write E (5740) WEBSOCKET_CLIENT: Network error: esp_transport_write() returned 0, errno=0 E (5770) TRANSPORT_BASE: poll_read select error 0, errno = Success, fd = 54 I (5770) WEBSOCKET_CLIENT: Reconnect after 10000 ms E (5770) WEBSOCKET_CLIENT: Network error: esp_transport_poll_read() returned -1, errno=9 I (5780) WEBSOCKET_CLIENT: Reconnect after 10000 ms I (5790) websocket: WEBSOCKET_EVENT_DISCONNECTED I (5800) websocket: WEBSOCKET_EVENT_DISCONNECTED dt_min = 349 us, dt_max = 8099 us dt_min = 349 us, dt_max = 8099 us dt_min = 349 us, dt_max = 8099 us
char data[5120];
// This task is needed only to trigger the "the next measurement ready" IRQs
// sent by the sensor when the I2C reading in "read_sdpsensor()" is done
static void sdptask_read_sensor() {
while (1) {
ulTaskNotifyTake(pdTRUE, portMAX_DELAY);
read_sdpsensor(); // simple I2C reading
static void IRAM_ATTR timer_callback() {
last_tick = tick;
// notify the "sdptask_read_sensor" task
BaseType_t xHigherPriorityTaskWoken = pdFALSE;
vTaskNotifyGiveFromISR(read_sensor_task_handle, &xHigherPriorityTaskWoken);
portYIELD_FROM_ISR(xHigherPriorityTaskWoken);
void task_send() {
while (1) {
esp_websocket_client_send_bin(client, data, sizeof(data), pdMS_TO_TICKS(10));
vTaskDelay(pdMS_TO_TICKS(10));
void SDPSensor_AttachIRQ(gpio_num_t irq_gpio, void* irq_handler) {
gpio_config_t irq_io_conf = {
.pin_bit_mask = 1ULL << irq_gpio, // IRQ pin
.mode = GPIO_MODE_INPUT, // input mode
.pull_up_en = GPIO_PULLUP_ENABLE, // enable pull-up
.pull_down_en = GPIO_PULLDOWN_DISABLE, // disable pull-down
.intr_type = GPIO_INTR_NEGEDGE // falling edge interrupt
ESP_ERROR_CHECK(gpio_config(&irq_io_conf));
// install the GPIO ISR service
ESP_ERROR_CHECK(gpio_install_isr_service(0));
// hook an ISR handler for the specific GPIO pin
ESP_ERROR_CHECK(gpio_isr_handler_add(irq_gpio, irq_handler, NULL));
void app_main() {
SDPSensor_AttachIRQ(4, timer_callback); // attach a callback to sensor IRQ signal
xTaskCreatePinnedToCore(sdptask_read_sensor, "sdp_read", 2048, NULL, 4, &read_sensor_task_handle, APP_CPU_NUM);
xTaskNotifyGive(read_sensor_task_handle); // trigger the first measurement
All right, gotta answer my own question.
I've bought a hardware timer (DS3231), set up SQW at 1024 Hz connected to pin 22 and the code boils down to:
The console output:
Hope I got it right. And I don't see any solution how to bring the gap of 8000+ us down. Also, WiFi severely influences the delay on its own.
/* ESP HTTP Client Example
#include <stdio.h>
#include "esp_wifi.h"
#include "esp_system.h"
#include "nvs_flash.h"
#include "esp_event.h"
#include "protocol_examples_common.h"
#include "freertos/task.h"
#include "esp_log.h"
#include "esp_websocket_client.h"
#define NO_DATA_TIMEOUT_SEC 5
#define IRQ_GPIO 18
static const char *TAG = "WEBSOCKET";
esp_websocket_client_handle_t client;
void IRAM_ATTR handler() {
last_tick = tick;
void attachIRQ(gpio_num_t irq_gpio, void* irq_handler) {
static void websocket_event_handler(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data)
switch (event_id) {
case WEBSOCKET_EVENT_CONNECTED:
ESP_LOGI(TAG, "WEBSOCKET_EVENT_CONNECTED");
case WEBSOCKET_EVENT_DISCONNECTED:
ESP_LOGI(TAG, "WEBSOCKET_EVENT_DISCONNECTED");
case WEBSOCKET_EVENT_DATA:
case WEBSOCKET_EVENT_ERROR:
ESP_LOGI(TAG, "WEBSOCKET_EVENT_ERROR");
void task_send() {
char data[512];
while (1) {
if (esp_websocket_client_is_connected(client)) {
timer_dt_max);
static void websocket_app_start(void)
esp_websocket_client_config_t websocket_cfg = {};
websocket_cfg.uri = "ws://echo.websocket.events";
ESP_LOGI(TAG, "Connecting to %s...", websocket_cfg.uri);
client = esp_websocket_client_init(&websocket_cfg);
esp_websocket_register_events(client, WEBSOCKET_EVENT_ANY, websocket_event_handler, (void *)client);
esp_websocket_client_start(client);
attachIRQ(IRQ_GPIO, handler);
void app_main(void)
ESP_LOGI(TAG, "[APP] Startup..");
ESP_LOGI(TAG, "[APP] Free memory: %d bytes", esp_get_free_heap_size());
ESP_LOGI(TAG, "[APP] IDF version: %s", esp_get_idf_version());
esp_log_level_set("*", ESP_LOG_INFO);
esp_log_level_set("WEBSOCKET_CLIENT", ESP_LOG_DEBUG);
esp_log_level_set("TRANSPORT_WS", ESP_LOG_DEBUG);
esp_log_level_set("TRANS_TCP", ESP_LOG_DEBUG);
ESP_ERROR_CHECK(nvs_flash_init());
/* This helper function configures Wi-Fi or Ethernet, as selected in menuconfig.
* Read "Establishing Wi-Fi or Ethernet Connection" section in
* examples/protocols/README.md for more information about this function.
ESP_ERROR_CHECK(example_connect());
- When WiFi is disabled (commented out):
dt_min = 970 us, dt_max = 983 us
- When WiFi is enabled but no websocket is running:
dt_min = 487 us, dt_max = 1466 us
- When WiFi is enabled and a websocket is running:
I (10112) WEBSOCKET: WEBSOCKET_EVENT_CONNECTED dt_min = 406 us, dt_max = 1547 us ... E (10972) TRANSPORT_WS: Error transport_poll_write E (10972) WEBSOCKET_CLIENT: Network error: esp_transport_write() returned 0, errno=0 E (10972) TRANSPORT_BASE: poll_read select error 0, errno = Success, fd = 54 E (10982) WEBSOCKET_CLIENT: Network error: esp_transport_poll_read() returned -1, errno=119 I (10992) WEBSOCKET_CLIENT: Reconnect after 10000 ms I (10992) WEBSOCKET_CLIENT: Reconnect after 10000 ms I (11002) WEBSOCKET: WEBSOCKET_EVENT_DISCONNECTED I (11002) WEBSOCKET: WEBSOCKET_EVENT_DISCONNECTED dt_min = 381 us, dt_max = 1572 us I (21372) WEBSOCKET: WEBSOCKET_EVENT_CONNECTED dt_min = 381 us, dt_max = 1572 us ... E (319582) TRANSPORT_WS: Error transport_poll_write E (319582) WEBSOCKET_CLIENT: Network error: esp_transport_write() returned 0, errno=0 E (319582) TRANSPORT_BASE: poll_read select error 0, errno = Success, fd = 54 E (319592) WEBSOCKET_CLIENT: Network error: esp_transport_poll_read() returned -1, errno=119 I (319602) WEBSOCKET_CLIENT: Reconnect after 10000 ms I (319602) WEBSOCKET: WEBSOCKET_EVENT_DISCONNECTED I (319612) WEBSOCKET_CLIENT: Reconnect after 10000 ms I (319612) WEBSOCKET: WEBSOCKET_EVENT_DISCONNECTED dt_min = 226 us, dt_max = 1728 us
So, with a 'hardware timer', we mean one inside of the ESP32 itself. You wanna look here for instance. That should give you similar results as the DS3231 but without external components. (Probably even better as there's no GPIO subsystem 'in the way') Furthermore, you can probably get a bit less jitter by putting the initialization routines / non-interrupt handling stuff for that timer in a task that runs off the app CPU: that makes sure the interrupt is also tied to that app CPU, and as the WiFi stuff is going on on the pro cpu, it should interfere less.
True, thanks for the advice. I've set up an onboard hardware timer at 1024 Hz freq (976 us period). Having the timer interrupt routine bound to the APP CPU core significantly reduces the jitter of the period at which the timer callback is executed - now it's in the [899, 1054] us range. Full code for the notice:ESP_Sprite wrote: ↑Tue Jan 25, 2022 1:55 pmFurthermore, you can probably get a bit less jitter by putting the initialization routines / non-interrupt handling stuff for that timer in a task that runs off the app CPU: that makes sure the interrupt is also tied to that app CPU, and as the WiFi stuff is going on on the pro cpu, it should interfere less.
#include <stdio.h>
#include "driver/timer.h"
#define IRQ_GPIO 18
BaseType_t core_id = 0;
static bool IRAM_ATTR irq_handler() {
last_tick = tick;
core_id = xPortGetCoreID();
return pdFALSE;
switch (event_id) {
void task_send() {
char data[512];
while (1) {
printf("[CPU core=%d] dt_min = %lld us, dt_max = %lld us\n", core_id, timer_dt_min, timer_dt_max);
static void timer_start_task() {
/* Select and initialize basic parameters of the timer */
timer_config_t config = {
.divider = 25,
.counter_dir = TIMER_COUNT_UP,
.counter_en = TIMER_PAUSE,
.alarm_en = TIMER_ALARM_EN,
.auto_reload = TIMER_AUTORELOAD_EN,
}; // default clock source is APB
timer_init(0, 0, &config);
/* Timer's counter will initially start from value below.
Also, if auto_reload is set, this value will be automatically reload on alarm */
timer_set_counter_value(0, 0, 0); // <-- don't really know if this is needed
/* Configure the alarm value and the interrupt on alarm. */
timer_set_alarm_value(0, 0, 3125); // 1024 Hz
timer_enable_intr(0, 0);
timer_isr_callback_add(0, 0, irq_handler, NULL, 0);
timer_start(0, 0);
vTaskDelete(NULL);
void app_main(void)
xTaskCreatePinnedToCore(timer_start_task, "timer_start", 4096, NULL, 0, NULL, APP_CPU_NUM);
Thanks. Problem closed.
Users browsing this forum: fanmen1 and 245 guests
