Corrupt variable when using ESPNOW
jonsb01
Postby jonsb01 » Sat Jan 22, 2022 5:30 pm
Hi all, I'm creating a remote joystick using ESPNOW for the range benefits and I've come across a strange issue. The Xmap variable works fine when the ESPNOW code in the setup block is not there and then becomes -100 when its on. The Ymap variable still works fine? Both of the values send across to the reciever board without issue, albeit the Xmap is wrong. Can someone scan over this code and see if anything stands out as glaringly wrong? Its the section shown in the setup code that makes the ESPNOW code turn on or off and also seems to corrupt the Xmap variable.
/////////////ESPNOW
#include <esp_now.h>
#include <WiFi.h>
uint8_t broadcastAddress1[] = {0x94, 0xB9, 0x7E, 0xD4, 0x50, 0xAC};//address of sender
typedef struct Send_Data_Format { //format of the information to be sent
  int x;
  int y;
} Send_Data_Format;
Send_Data_Format example;
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) { //callback when data is sent
  //char macStr[18];//Serial.print("Packet to: ");snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x", mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);Serial.print(macStr);Serial.print(" send status:\t");Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
esp_now_peer_info_t peerInfo; //needed here instead of in setup due to bug
/////////////ESPNOW
///setup pin inputs for joystick and setup variables.
const int SW_pin = 32;
const int X_pin = 25;
const int Y_pin = 33;
volatile int Xmap = 0;
volatile int Ymap = 0;
  //joystick pins
  pinMode(SW_pin, INPUT);
  pinMode(X_pin, INPUT);
  pinMode(Y_pin, INPUT);
  digitalWrite(SW_pin, HIGH);
  Serial.begin(115200);//serial connection
  /////////////ESPNOW setup stage
//COMMENTING OUT THIS PART MAKES THE X AXIS READ OKAY AGAIN?!
  WiFi.mode(WIFI_STA);
  if (esp_now_init() != ESP_OK) {
    //Serial.println("Error initialising ESPNOW");
    return;
  esp_now_register_send_cb(OnDataSent);
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  memcpy(peerInfo.peer_addr, broadcastAddress1, 6);
  if (esp_now_add_peer(&peerInfo) != ESP_OK) {
    //Serial.println("Failed to add peer");
    return;
  //delay(1000);
/////// END
int newdata = 0;
int lastY = 0;
  joystickoutput();
  if (lastY!=Ymap){
  /////////////ESPNOW loop stage
    example.x = Xmap;
    example.y = Ymap;
    esp_err_t result = esp_now_send(0, (uint8_t *) &example, sizeof(Send_Data_Format));
  lastY=Ymap;
  delay(10);
void joystickoutput() {
  if (analogRead(X_pin) <= 1790) {
    Xmap = map(analogRead(X_pin), 0, 1790, -100, 0);
  if (analogRead(X_pin) >= 1800) {
    Xmap = map(analogRead(X_pin), 1800, 4095, 0, 100);
  if (analogRead(Y_pin) <= 1825) {
    Ymap = map(analogRead(Y_pin), 0, 1825, -100, 0);
  if (analogRead(Y_pin) >= 1835) {
    Ymap = map(analogRead(Y_pin), 1835, 4095, 0, 100);
  Serial.print("Switch: ");
  Serial.print(digitalRead(SW_pin));
  Serial.print("\n");
  Serial.print("X-Axis: ");
  Serial.print(Xmap);
  Serial.print("\n");
  Serial.print("Y-Axis: ");
  Serial.print(Ymap);
  Serial.print("\n");
ESP_Sprite
Re: Corrupt variable when using ESPNOW
Postby ESP_Sprite » Sun Jan 23, 2022 1:49 am
Pin 25 is connected to ADC2, which becomes unavailable when WiFi is running. Suggest you use a pin connected to ADC1 instead.
jonsb01
Postby jonsb01 » Wed Mar 02, 2022 4:52 pm
That was the right fix. Thank you
Users browsing this forum: acmodbios and 72 guests
