Small ESP32 Modul ( all include in new ESP32-PICO )
Hi Folks,
ESP32-P1CD ??
edit: it is PICO
Small ESP32 Modul ( all include )
without comment
rudi
ESP32-P1CD ??
edit: it is PICO
without comment
rudi
Re: Small ESP32 Modul ( all include in new ESP32-P1CD ?? )
Maybe ESP32-PICO-Q7
"Pico module" 7mm x 7mm
know a "modul" with embedded crystal and embedded flash(hope 128Mbit in esp32 pico ) from HF-SIP120
what you mean, is pSRAM included in pico too?
will it come as a regular product?
rudi
txs for your out flying wishes
edit: the pinheader of the board looks like raspberry pi zero ..
edit: yes it is pico i edit the head of post
edit: the tiny board is not for sale, but some folks get samples
btw: a new ESP32 comes 2018
perhabs 5GHz
rudi
perhabs 5GHz
Re: Small ESP32 Modul ( all include in new ESP32-PICO )
Small ?
;p
Here my version
ESP + LED DRIVER + 1.8v + 3.3v, plus I2C 1.8v->3.3v->1.8v plus battery managment. + RFID + RG Leds + FTDI + wifi antenna + Pedometer
Next version will be 30 % smaller.
;p
Here my version
- Small ESP32.jpg (661.35 KiB) Viewed 20908 times
I am in awe of you guys building such solutions ... I would love to read a blog article on how you go about the mechanics of this. Specifically, how are you attaching the ICs to the PCB? Are you soldering them yourselves? Is there a "service" that will assemble low volume modules such as these?
Yeah we used a company for a small batch pick and place. (15 boards)
Very nice! Well done!enitalp wrote: Small ?
;p
Here my version
Do you go to MP? Or where we can catch your nice Board ( like it )
Not sure you have seen the "new ESP32-PICO Q7" on the "Small" ESP Modul,
the ESP32-PICO Q7 is a new ESP32 with all include in the SoC Package, OSC and Flash is include too.
it is a miniature ESP32 modul in a package.
if you can use in your next PCB that is 30% smaller you can save again place cause you did not need OSC and Flash example.
this was a prework of the ESP32-PICO Q7
the modul where the ESP32-PICO Q7 is mounted is "BIG" cause it is RPI (Raspbery PI) 2x20 2.54 RM form size
rudi
He is already using d2wd and tiny crystal and passives but PICO may save a few mm. NFC section looks biggest. Maybe "ESP-2018" will have built in NFC like rtl8711
you're right,WiFive wrote:He is already using d2wd and tiny crystal and passives but PICO may save a few mm. NFC section looks biggest. Maybe "ESP-2018" will have built in NFC like rtl8711
i would use a small chip antenna in the meantime
( pic is for a size compare with an ESP32-D2WD - it's the right black from D2 ) best wishes
rudi
edit: examples ( Products -> RF Antenna -> Chip Antenna )
ACA-2012-A1-CC-S super only 2.0x1.2x0.55 for 2.4G
ACM0-3216-A1-CC-S only 3.2x1.6x0.5 for GPS + 2.4G
ACM3-5036-A1-CC-S to big 5.0x3.6x0.7 for 2.4G + 5G
How you like that linkit smart7688? Good signal?
Users browsing this forum: No registered users and 249 guests
