Small ESP32 Modul ( all include in new ESP32-PICO )
Re: Small ESP32 Modul ( all include in new ESP32-PICO )
Postby rudi ;-) » Mon Aug 05, 2019 1:38 am
@loboris nice, txs, will try to get :)
btw, the engineering samples was from 2017
and i did combine with the "Beetle"
loboris
Postby loboris » Mon Aug 05, 2019 7:47 am
WiFive
Postby WiFive » Mon Aug 05, 2019 8:15 am
M5stickC also has pico inside
samsam
Postby samsam » Tue Aug 06, 2019 3:52 am
TTGO Micro-32 Unfortunately doesn't have any certifications, so is good only for hobby brewery,
Plus looks bigger in size than Espressif's Engineering sample with the 3D antenna ;)
loboris
Postby loboris » Tue Aug 06, 2019 7:09 am
Even if you are using an RF certified module, your system (the final device) still will require testing. You will save money though, because it will require less testing than a full FCC / IC / CE certification of the underlying transmitter.
Postby rudi ;-) » Tue Aug 06, 2019 11:19 pm
hi
Jarrett build the uMesh Esp32
has inside ESP32-Pico-D4 too
projectinfo
Postby rudi ;-) » Sat Aug 15, 2020 10:09 am
playflash wrote:
Wed Nov 22, 2017 4:27 pm
rudi ;-) wrote:thanks for updating
ESP32-PICO-D4 datasheet V1.0 from 31. August 2017
esp32-pico-d4_datasheet_en_V1.0_vom_31.08.2017.pdf
src now online again
Hi, rudi,
I must say you did a great job here.
So, an External PSRAM work with these two chips.
- D2WD
- PICO
Can you tell me what PSRAM you tested? And where to buy them if you know?
It is pity that espressif didn't put a PSRAM in PICO.
Thank you very much.
update Aug 15 / 2020
Hi
know this psram on pico thread is 3 years old - but there are news:
FYI: ESP32-Pico-V3-02 is with PSRAM
Postby rudi ;-) » Mon Aug 24, 2020 1:04 pm
