How to use test_sd.c
How can i use test_sd.c to check my sd card?
https://github.com/espressif/esp-idf/bl ... /test_sd.c
When i try to compile the program, i get the message
C:/msys32/home/esp/esp-idf/components/sdmmc/test/build/esp32\libesp32.a(cpu_start.o):(.literal.main_task+0xc): undefined reference to `app_main'
C:/msys32/home/esp/esp-idf/components/sdmmc/test/build/esp32\libesp32.a(cpu_start.o): In function `main_task':
C:/msys32/home/esp/esp-idf/components/esp32/cpu_start.c:348: undefined reference to `app_main'
collect2.exe: error: ld returned 1 exit status
make: *** [C:/msys32/home/esp/esp-idf//make/project.mk:330: /home/esp/esp-idf/components/sdmmc/test/build/test_sd.c.elf] Fehler 1
I can't see a app_main in this script?
Re: How to use test_sd.c
Sorry for being dull. But i'm at step 'Building unit test app'.
I'm in the directory "test".
make menuconfig - configure unit test app.
>> there is nothing in make menuconfig to configure (also there is no Kconfig.projbuild, so its ok i think)
make TESTS_ALL=1 - build unit test app with tests for each component having tests in the test subdirectory.
I tried 'make flash TESTS_ALL=1'CC trax.o
CC eri.o
AR libxtensa-debug-module.a
LD test_sd.c.elf
And well, yes, i've got no unity.h file$ make flash TESTS_ALL=1
not linking libsodium tests, use 'TEST_COMPONENTS=libsodium' to test it
CC test_trace.o
C:/msys32/home/esp/esp-idf/components/app_trace/test/test_trace.c:6:19: fatal error: unity.h: No such file or directory
compilation terminated.
make[1]: *** [/home/esp/esp-idf/make/component_wrapper.mk:229: test_trace.o] Fehler 1
make: *** [C:/msys32/home/esp/esp-idf//make/project.mk:392: component-app_trace_test-build] Fehler 2
That should work:
(replace /dev/ttyUSB0 with your port name)
cd $IDF_PATH/tools/unit-test-app/
make defconfig
make flash monitor TEST_COMPONENTS=sdmmc ESPPORT=/dev/ttyUSB0
Problem at step
make flash monitor TEST_COMPONENTS=sdmmc ESPPORT=com3
Already tried 'make clean' before.Leaving...
Hard resetting...
MONITOR
--- idf_monitor on com3 115200 ---
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT)
rst:0x10 (RTCWDT_RTC_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0010,len:4
load:0x3fff0014,len:4124
load:0x40078000,len:0
load:0x40078000,len:11968
entry 0x40078cd8
E (48) esp_image: image at 0x150000 has invalid magic byte
W (49) esp_image: image at 0x150000 has invalid SPI mode 255
W (68) esp_image: image at 0x150000 has invalid SPI size 15
E (126) boot: Failed to verify app image @ 0x150000 (8194)
user code done
Pullup on GPIO12 setting VDD_SDIO voltage to 1.8V, while flash chip is 3.3V part? Please read readme document in example/storage/sd_card.
I only want to test the 1-line mode, not the 4-line mode, so GPIO12 is not used.
Are you able to program any other examples successfully using 'make flash monitor'? The output you see indicates that either flash programming or reading data from flash was not successful. Is it possible that you have something connected to the pins used for SPI flash (SD_xx pins)?
Yes, i use some of those pins. But i never had problems by flashing other programs with this circuit.
IO23 and IO19. Is IO14 also with SDCLK one of those pins? I use this also this one.
I disconnected all cables on my ESP32 board, but it's still the same issue. Never saw this message while flashing other programs.
Users browsing this forum: Bing [Bot], gojimmypi and 137 guests
