I'm trying to get the esp-idf/examples/storage/sd_card/sdspi example to work on the esp32-LyraT-mini card, but I get an 0x107 error when it runs.
The esp-adf/examples/audio_processing/poipeline_alc successfully plays music files on the sd-card, so I know the hardware works.
The audio example calls audio_board_sdcard_init, which has the below code in it, which I'm guessing is setting up GPIO_NUM_32. I'm guessing the sdspi example code is not doing this, but I'm nite sure where/how to add it.
gpio_config_t sdcard_pwr_pin_cfg = {
.pin_bit_mask = 1UL << SDCARD_PWR_CTRL,
.mode = GPIO_MODE_OUTPUT,
.pull_up_en = GPIO_PULLUP_DISABLE,
.pull_down_en = GPIO_PULLDOWN_DISABLE,
.intr_type = GPIO_INTR_DISABLE,
gpio_config(&sdcard_pwr_pin_cfg);
gpio_set_level(SDCARD_PWR_CTRL, 0);
Has anyone update the examples to work with the new development boards?
LyraT-mini SD-card
Re: LyraT-mini SD-card
The code I found was the fix, I was just applying it to the wrong example.
I added the following at the beginning of main in the sd_card_example_main.c of sdmmc which is in the sd-card folder of the Examples.
And it now works.
And it now works.
Users browsing this forum: No registered users and 136 guests
