I need to use a micro-controller to program the flash which in ESP32-C3-MINI1. Do it have related documents which can be referred?
Flahs programming with ESP32-C3-MINI
Re: Flahs programming with ESP32-C3-MINI
Normally, you'd use esptool.py (included in esp-idf) to flash the flash chip using a PC. However, if you need something embedded to do the flashing, there's esp-serial-flasher, an embeddable library you can use for this.
Users browsing this forum: No registered users and 224 guests
