I'm new at esp32.
Following http://esp-idf.readthedocs.io/en/latest ... ndex.html# successfully installed Toolchain and ESP_IDF, connected ESP32 to PC (win7), port is USB-SERIAL CH340 (COM5), but running Putty and opening serial line nothing happens. Putty parameters are set up as win device mgr com port is set.
Can you help me why?
The dev board is Geekcreit® ESP32-DevKit ESP32.
Running MSYS/Mingw32 ls -l /dev/tty* comes:
crw-rw-rw- 1 Hp None 117, 5 Aug 30 18:28 /dev/ttyS5
esp32 does not connect via putty
Re: esp32 does not connect via putty
Hi
try to compile an example and upload on the board...
Thanks,
after recomliping and quitting PUTTY everything went ok.
windows com port start with COM1... COM2...COM3 and so onlaz7591 wrote:I'm new at esp32.
/dev/tty* start with /dev/ttyS0 ... /dev/ttyS1 ... /dev/ttyS2 and so on
if you runs:
CH340 then is on /dev/ttyS5 right?Running MSYS/Mingw32 ls -l /dev/tty* comes:
but you use COM5 - think this is wrong if there is CH340 from your board is on /dev/ttyS5
try putty with COM6
or try putty with /dev/ttyS5
( cygwin, mingw msys )
and you are done
rudi
Thanks,
putty and serial comms is ok.
First stumblings...
First stumblings...
Users browsing this forum: No registered users and 117 guests
