Trying to get the OpenSSL_Server example to run. I have tried it with both USB power source and a regulated power source at 3.3V; same issue. Below is the output:
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0008,len:8
load:0x3fff0010,len:4408
load:0x40078000,len:11072
load:0x40080000,len:252
entry 0x40080034
I (45) boot: ESP-IDF v3.0-dev-114-g4ec2abb-dirty 2nd stage bootloader
I (46) boot: compile time 21:54:50
I (49) boot: Enabling RNG early entropy source...
I (65) boot: SPI Speed : 40MHz
I (78) boot: SPI Mode : DIO
I (90) boot: SPI Flash Size : 4MB
I (102) boot: Partition Table:
I (114) boot: ## Label Usage Type ST Offset Length
I (136) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (160) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (183) boot: 2 factory factory app 00 00 00010000 00100000
I (206) boot: End of partition table
I (219) boot: Disabling RNG early entropy source...
I (236) boot: Loading app partition at offset 00010000
I (1319) boot: segment 0: paddr=0x00010018 vaddr=0x00000000 size=0x0ffe8 ( 65512)
I (1320) boot: segment 1: paddr=0x00020008 vaddr=0x3f400010 size=0x1b1d8 (111064) map
I (1336) boot: segment 2: paddr=0x0003b1e8 vaddr=0x3ffb0000 size=0x02ebc ( 11964) load
I (1368) boot: segment 3: paddr=0x0003e0ac vaddr=0x40080000 size=0x00400 ( 1024) load
I (1390) boot: segment 4: paddr=0x0003e4b4 vaddr=0x40080400 size=0x12f0c ( 77580) load
I (1453) boot: segment 5: paddr=0x000513c8 vaddr=0x400c0000 size=0x00000 ( 0) load
I (1454) boot: segment 6: paddr=0x000513d0 vaddr=0x00000000 size=0x0ec38 ( 60472)
I (1475) boot: segment 7: paddr=0x00060010 vaddr=0x400d0018 size=0x6a240 (434752) map
I (1501) cpu_start: Pro cpu up.
I (1512) cpu_start: Starting app cpu, entry point is 0x40080eac
I (0) cpu_start: App cpu up.
I (1545) heap_init: Initializing. RAM available for dynamic allocation:
I (1566) heap_init: At 3FFAE2A0 len 00001D60 (7 KiB): DRAM
I (1585) heap_init: At 3FFB81C8 len 00027E38 (159 KiB): DRAM
I (1604) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (1624) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1644) heap_init: At 4009330C len 0000CCF4 (51 KiB): IRAM
I (1663) cpu_start: Pro cpu start user code
I (1722) cpu_start: Starting scheduler on PRO CPU.
I (193) cpu_start: Starting scheduler on APP CPU.
I (223) wifi: wifi firmware version: f092575
I (223) wifi: config NVS flash: enabled
I (223) wifi: config nano formating: disabled
I (223) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (233) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (263) wifi: Init dynamic tx buffer num: 32
I (263) wifi: Init dynamic rx buffer num: 32
I (263) wifi: wifi driver task: 3ffbe7b8, prio:23, stack:4096
I (263) wifi: Init static rx buffer num: 10
I (273) wifi: Init rx ampdu len mblock:7
I (273) wifi: Init lldesc rx ampdu entry mblock:4
I (273) wifi: wifi power manager task: 0x3ffc3b1c prio: 21 stack: 2560
I (283) Openssl_example: start the WIFI SSID:[xxxxxx] password:[xxxxxxxxx]
I (293) wifi: wifi timer task: 3ffc4b88, prio:22, stack:3584
Brownout detector was triggered
OpenSSL Server Example generates 'Brownout detector was triggered'
Re: OpenSSL Server Example generates 'Brownout detector was triggered'
The brownout detector detects if the 3.3V power supply rails to the ESP32 becomes unacceptably low. In your case, I'd look at your power supply infrastructure: if you are using an existing devboard, usually the USB cable is prime suspect.
That is exactly what it was. Bad cable. I am not using a USB cable instead I am going into a UART to USB converter. Swapped out the cables and did not have any issues.
either disable the brownout detection or connect with a external 5V supply.
FWIW, disabling the brown-out detector is a bad idea here. A brown-out detector that gets triggered usually means the power supply is inadequate for the ESP. Disabling the brown-out detector may allow you to not get a reset because of this, but there's a high chance of weird crashes or malfunctions later on.
Users browsing this forum: No registered users and 119 guests
