Dose the ESP32-WROVER-E have embedded Flash and PSRAM?
pabian
Postby pabian » Tue Dec 06, 2022 8:18 am
Dose the ESP32-WROVER-E on the ESP-WROVER-KIT have embedded Flash and PSRAM?
I knew that the chip had embedded PSRAM and Flash.
But I found the chip info by using flash_id (platformio) but there is no embedded Flash and PSRAM features.
The result is below;
esptool.py v4.2.1
Found 1 serial ports
Serial port COM7
Connecting.....
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting....
Detecting chip type... ESP32
Chip is ESP32-D0WD-V3 (revision 3)
Crystal is 40MHz
MAC: 94:e6:86:0f:9c:9c
Uploading stub...
Running stub...
Stub running...
Manufacturer: 5e
Device: 4016
Detected flash size: 4MB
Hard resetting via RTS pin...
ESP_Lvxinyue
Re: Dose the ESP32-WROVER-E have embedded Flash and PSRAM?
Postby ESP_Lvxinyue » Thu Dec 08, 2022 7:47 am
esptool.py v4.2.1
Serial port COM7
Connecting.....
Connecting....
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
Manufacturer: 5e
Device: 4016
According to its datasheet (https://www.espressif.com/sites/default ... eet_en.pdf), yes, it has SPI flash and PSRAM.
Users browsing this forum: Baidu [Spider], fanmen1, rahulbari, Vineethad and 232 guests
