Hello, I'm having a very strange issue with a ESP32 board so, heres the problem:
When I try to communicate to the board via serial (i'm using the CH340G) it works, i see messages that the board sends me and i can send the board messages, but when I try to flash it refuses to work, done the usual (IO0 -> GND, RESET) combination and via serial i get the acknowledgment from the board that is ready to be programmed but it won't work (i'm using the Arduino IDE) here's the acknowledgment message;
20:09:37.978 -> rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_rEO_V2))
20:09:37.978 -> waiting for download
Does anyone know how to fix this issue? is it hardware or software? What i can do?
Problem with CH340G flashing
Re: Problem with CH340G flashing
That looks good. In what way is flashing failing? Perhaps there is an issue between the CH340 and the ESP32 Rx line?
The flashing just times out as it stays on "Connecting..........." and then fails to upload any code, I don't believe it's a problem with the Rx line as I can get regular UART messages without any problems it's the flashing process that failsESP_Sprite wrote: ↑Fri Dec 09, 2022 12:36 amThat looks good. In what way is flashing failing? Perhaps there is an issue between the CH340 and the ESP32 Rx line?
Here is some extra information captured with my oscilloscope
BLUE= ESP32 TX
YELLOW = ESP32 RX
Here, the ESP32 is talking to me and I see the messages from the esp to my computer: Here is when the programmer tries to talk with the esp (the esp is already in programming mode (IO0->GND, RESET)) But the ESP does not respond to the programmer and so, the software on the pc eventually times out
(i tried to change the USB cable and TX RX wires, same result)
I STILL have no clue on why this is happening, the serial communication looks fine.
BLUE= ESP32 TX
YELLOW = ESP32 RX
No, I mean the other line: Tx from the CH340 to Rx of the ESP32. If that's not OK, the ESP32 won't respond to flash commands either.
Your scope images look OK to me. Can you show the schematic of your board?
Sometimes even with devkits from espressif i have to press BOOT to keep IO0 low until flashing start. You can try this.
I "fixed it" I've used a different programming board (as the esp board was a DIY one and it didn't come with an on-board programmer) using a different programmer solved the issue, so the chip in the other programmer must be somehow defective.ESP_Sprite wrote: ↑Sat Dec 10, 2022 2:53 amNo, I mean the other line: Tx from the CH340 to Rx of the ESP32. If that's not OK, the ESP32 won't respond to flash commands either.
The board isn't by espressif, I've made it from scratch, and everything works, the only thing i also wanted to DIY was a programmer, and I wasn't successful at it. I've decided to re draw the programmer, so if anyone sees any problems with it let me know. (i the older one i messed up the clock circuit and maybe this was why it was acting strangely)
if you guys find any mistakes let me know!
Users browsing this forum: No registered users and 236 guests
