I've just laid hands on the ESP-Launcher dev kit, which I believe has at least one pushbutton and one LED available for experimentation. I'd like to create a "really simple" demo, one in which I can see the pushbutton being pressed and make the LED blink via the Internet. I've gotta believe someone's already done this, but haven't been able to find it yet. Any ideas?
Another example which would also be really useful: simply configure the Launcher to be a Serial-to-WiFi adapter. That is connect three pins (RXD, TXD, Ground) to the device under test and have the WiFi section of the ESP8266 connect to my network. Sounds like a no brainer, right? Not necessarily, for a noob like me.
Any leads or suggestions will be much appreciated.
Larry O.
ESP_Launcher: Simple IoT Demo/Example/Sample
Re: ESP_Launcher: Simple IoT Demo/Example/Sample
Howdy Larry,
Do you have a link to the "ESP-Launcher" dev kit?
As for sample ESP32 apps, there is a wealth of documentation available here about getting started with ESP32 development.
http://esp-idf.readthedocs.io/en/latest/
Esp-launcher is for esp8266 but this forum is for esp32 so you may want to try esp8266.com or bbs.espressif.com
Users browsing this forum: No registered users and 113 guests
