Hi guys,
I know that the ESP32-S3 has a random number generator which I can use to generate a 128-bit GUID upon powerup.
However, I would like the GUID to be generated on the host computer as I need to be aware of this number before using the ESP32-S3. There will be thousands of GUIDs generated on the host computer.
Is there a systematic way of supplying the host computer with all these GUIDs, to then individually program each ESP32-S3 to contain one of the GUIDs, which the ESP32-S3 can read it is powered on?
For example, there can be a .hex or .bin file containing these GUIDs to then be used by the programmer to individually select one of the GUIDs to program into the ESP32-S3 to be read by the software when powered on.
Any instructions on how to do this, or links containing explanations of how this could done would be great.
How to program host generated 128-bit GUID into thousands of ESP32-S3?
Users browsing this forum: Google [Bot] and 117 guests
