1. With host CPU Trying to activate AT command for PWM with module ESP32-C3-mini-1 but I all the time receive ERROR. Other commands work fine.
2. I tried changing GPIO but nothing helps. Am I missing something?
3. For example I tried the following command:
AT+DRVPWMINIT=1000,1,3
ERROR
4. The module is running following standard FW:
AT version:2.4.2.0(fb731d2 - ESP32C3 - Aug 25 2022 03:47:31)
compile time(67966ba):Aug 26 2022 07:46:13
Bin version:2.4.2(MINI-1)
SDK version:qa-test-v4.3.3-20220423
At command AT+DRVPWMINIT failing
Re: At command AT+DRVPWMINIT failing
I just found out the AT command I am using is not supported because it is not configured. How can I configure the AT commands? Do I need to create a my project for that or just download an updated configuration file from somewhere?
Users browsing this forum: fanmen1, Google [Bot], MicroController and 144 guests
