Hardware: ESP32-S3-WROOM-2
Software: ESP-IDF 5.0
Configuration of WiFi connect as below:
wifi_cfg.sta.threshold.authmode = WIFI_AUTH_WPA_WPA2_PSK;
wifi_cfg.sta.pmf_cfg.capable = true;
wifi_cfg.sta.pmf_cfg.required = false;
wifi_cfg.sta.sae_pwe_h2e = WPA3_SAE_PWE_BOTH;
SDK configuration of sdkconfig.h:
* Automatically generated file. DO NOT EDIT.
* Espressif IoT Development Framework (ESP-IDF) Configuration Header
#pragma once
#define CONFIG_SOC_LEDC_SUPPORT_APB_CLOCK 1
#define CONFIG_SOC_LEDC_SUPPORT_XTAL_CLOCK 1
#define CONFIG_SOC_LEDC_CHANNEL_NUM 8
#define CONFIG_SOC_LEDC_TIMER_BIT_WIDE_NUM 14
#define CONFIG_SOC_LEDC_SUPPORT_FADE_STOP 1
#define CONFIG_SOC_MPU_MIN_REGION_SIZE 0x20000000
#define CONFIG_SOC_MPU_REGIONS_MAX_NUM 8
#define CONFIG_SOC_ADC_SUPPORTED 1
#define CONFIG_SOC_PCNT_SUPPORTED 1
#define CONFIG_SOC_WIFI_SUPPORTED 1
#define CONFIG_SOC_TWAI_SUPPORTED 1
#define CONFIG_SOC_GDMA_SUPPORTED 1
#define CONFIG_SOC_LCDCAM_SUPPORTED 1
#define CONFIG_SOC_MCPWM_SUPPORTED 1
#define CONFIG_SOC_DEDICATED_GPIO_SUPPORTED 1
#define CONFIG_SOC_CACHE_SUPPORT_WRAP 1
#define CONFIG_SOC_ULP_SUPPORTED 1
#define CONFIG_SOC_RISCV_COPROC_SUPPORTED 1
#define CONFIG_SOC_BT_SUPPORTED 1
#define CONFIG_SOC_USB_OTG_SUPPORTED 1
#define CONFIG_SOC_USB_SERIAL_JTAG_SUPPORTED 1
#define CONFIG_SOC_CCOMP_TIMER_SUPPORTED 1
#define CONFIG_SOC_ASYNC_MEMCPY_SUPPORTED 1
#define CONFIG_SOC_SUPPORTS_SECURE_DL_MODE 1
#define CONFIG_SOC_EFUSE_KEY_PURPOSE_FIELD 1
#define CONFIG_SOC_SDMMC_HOST_SUPPORTED 1
#define CONFIG_SOC_RTC_FAST_MEM_SUPPORTED 1
#define CONFIG_SOC_RTC_SLOW_MEM_SUPPORTED 1
#define CONFIG_SOC_RTC_MEM_SUPPORTED 1
#define CONFIG_SOC_PSRAM_DMA_CAPABLE 1
#define CONFIG_SOC_XT_WDT_SUPPORTED 1
#define CONFIG_SOC_I2S_SUPPORTED 1
#define CONFIG_SOC_RMT_SUPPORTED 1
#define CONFIG_SOC_SDM_SUPPORTED 1
#define CONFIG_SOC_SYSTIMER_SUPPORTED 1
#define CONFIG_SOC_SUPPORT_COEXISTENCE 1
#define CONFIG_SOC_TEMP_SENSOR_SUPPORTED 1
#define CONFIG_SOC_AES_SUPPORTED 1
#define CONFIG_SOC_MPI_SUPPORTED 1
#define CONFIG_SOC_SHA_SUPPORTED 1
#define CONFIG_SOC_HMAC_SUPPORTED 1
#define CONFIG_SOC_DIG_SIGN_SUPPORTED 1
#define CONFIG_SOC_FLASH_ENC_SUPPORTED 1
#define CONFIG_SOC_SECURE_BOOT_SUPPORTED 1
#define CONFIG_SOC_MEMPROT_SUPPORTED 1
#define CONFIG_SOC_TOUCH_SENSOR_SUPPORTED 1
#define CONFIG_SOC_XTAL_SUPPORT_40M 1
#define CONFIG_SOC_APPCPU_HAS_CLOCK_GATING_BUG 1
#define CONFIG_SOC_ADC_RTC_CTRL_SUPPORTED 1
#define CONFIG_SOC_ADC_DIG_CTRL_SUPPORTED 1
#define CONFIG_SOC_ADC_ARBITER_SUPPORTED 1
#define CONFIG_SOC_ADC_FILTER_SUPPORTED 1
#define CONFIG_SOC_ADC_MONITOR_SUPPORTED 1
#define CONFIG_SOC_ADC_DMA_SUPPORTED 1
#define CONFIG_SOC_ADC_PERIPH_NUM 2
#define CONFIG_SOC_ADC_MAX_CHANNEL_NUM 10
#define CONFIG_SOC_ADC_ATTEN_NUM 4
#define CONFIG_SOC_ADC_DIGI_CONTROLLER_NUM 2
#define CONFIG_SOC_ADC_PATT_LEN_MAX 24
#define CONFIG_SOC_ADC_DIGI_MIN_BITWIDTH 12
#define CONFIG_SOC_ADC_DIGI_MAX_BITWIDTH 12
#define CONFIG_SOC_ADC_DIGI_RESULT_BYTES 4
#define CONFIG_SOC_ADC_DIGI_DATA_BYTES_PER_CONV 4
#define CONFIG_SOC_ADC_SAMPLE_FREQ_THRES_HIGH 83333
#define CONFIG_SOC_ADC_SAMPLE_FREQ_THRES_LOW 611
#define CONFIG_SOC_ADC_RTC_MIN_BITWIDTH 12
#define CONFIG_SOC_ADC_RTC_MAX_BITWIDTH 12
#define CONFIG_SOC_RTC_SLOW_CLOCK_SUPPORT_8MD256 1
#define CONFIG_SOC_ADC_CALIBRATION_V1_SUPPORTED 1
#define CONFIG_SOC_APB_BACKUP_DMA 1
#define CONFIG_SOC_BROWNOUT_RESET_SUPPORTED 1
#define CONFIG_SOC_MMU_LINEAR_ADDRESS_REGION_NUM 1
#define CONFIG_SOC_CPU_CORES_NUM 2
#define CONFIG_SOC_CPU_INTR_NUM 32
#define CONFIG_SOC_CPU_HAS_FPU 1
#define CONFIG_SOC_CPU_BREAKPOINTS_NUM 2
#define CONFIG_SOC_CPU_WATCHPOINTS_NUM 2
#define CONFIG_SOC_CPU_WATCHPOINT_SIZE 64
#define CONFIG_SOC_DS_SIGNATURE_MAX_BIT_LEN 4096
#define CONFIG_SOC_DS_KEY_PARAM_MD_IV_LENGTH 16
#define CONFIG_SOC_DS_KEY_CHECK_MAX_WAIT_US 1100
#define CONFIG_SOC_GDMA_GROUPS 1
#define CONFIG_SOC_GDMA_PAIRS_PER_GROUP 5
#define CONFIG_SOC_GDMA_SUPPORT_PSRAM 1
#define CONFIG_SOC_GDMA_PSRAM_MIN_ALIGN 16
#define CONFIG_SOC_GPIO_PORT 1
#define CONFIG_SOC_GPIO_PIN_COUNT 49
#define CONFIG_SOC_GPIO_SUPPORT_RTC_INDEPENDENT 1
#define CONFIG_SOC_GPIO_SUPPORT_FORCE_HOLD 1
#define CONFIG_SOC_GPIO_VALID_GPIO_MASK 0x1FFFFFFFFFFFF
#define CONFIG_SOC_GPIO_SUPPORT_SLP_SWITCH 1
#define CONFIG_SOC_DEDIC_GPIO_OUT_CHANNELS_NUM 8
#define CONFIG_SOC_DEDIC_GPIO_IN_CHANNELS_NUM 8
#define CONFIG_SOC_DEDIC_GPIO_OUT_AUTO_ENABLE 1
#define CONFIG_SOC_I2C_NUM 2
#define CONFIG_SOC_I2C_FIFO_LEN 32
#define CONFIG_SOC_I2C_SUPPORT_SLAVE 1
#define CONFIG_SOC_I2C_SUPPORT_HW_CLR_BUS 1
#define CONFIG_SOC_I2C_SUPPORT_XTAL 1
#define CONFIG_SOC_I2C_SUPPORT_RTC 1
#define CONFIG_SOC_I2S_NUM 2
#define CONFIG_SOC_I2S_HW_VERSION_2 1
#define CONFIG_SOC_I2S_SUPPORTS_PCM 1
#define CONFIG_SOC_I2S_SUPPORTS_PDM 1
#define CONFIG_SOC_I2S_SUPPORTS_PDM_TX 1
#define CONFIG_SOC_I2S_SUPPORTS_PDM_RX 1
#define CONFIG_SOC_I2S_SUPPORTS_PDM_CODEC 1
#define CONFIG_SOC_I2S_SUPPORTS_TDM 1
#define CONFIG_SOC_MCPWM_GROUPS 2
#define CONFIG_SOC_MCPWM_TIMERS_PER_GROUP 3
#define CONFIG_SOC_MCPWM_OPERATORS_PER_GROUP 3
#define CONFIG_SOC_MCPWM_COMPARATORS_PER_OPERATOR 2
#define CONFIG_SOC_MCPWM_GENERATORS_PER_OPERATOR 2
#define CONFIG_SOC_MCPWM_TRIGGERS_PER_OPERATOR 2
#define CONFIG_SOC_MCPWM_GPIO_FAULTS_PER_GROUP 3
#define CONFIG_SOC_MCPWM_CAPTURE_TIMERS_PER_GROUP 1
#define CONFIG_SOC_MCPWM_CAPTURE_CHANNELS_PER_TIMER 3
#define CONFIG_SOC_MCPWM_GPIO_SYNCHROS_PER_GROUP 3
#define CONFIG_SOC_MCPWM_SWSYNC_CAN_PROPAGATE 1
#define CONFIG_SOC_PCNT_GROUPS 1
#define CONFIG_SOC_PCNT_UNITS_PER_GROUP 4
#define CONFIG_SOC_PCNT_CHANNELS_PER_UNIT 2
#define CONFIG_SOC_PCNT_THRES_POINT_PER_UNIT 2
#define CONFIG_SOC_RMT_GROUPS 1
#define CONFIG_SOC_RMT_TX_CANDIDATES_PER_GROUP 4
#define CONFIG_SOC_RMT_RX_CANDIDATES_PER_GROUP 4
#define CONFIG_SOC_RMT_CHANNELS_PER_GROUP 8
#define CONFIG_SOC_RMT_MEM_WORDS_PER_CHANNEL 48
#define CONFIG_SOC_RMT_SUPPORT_RX_PINGPONG 1
#define CONFIG_SOC_RMT_SUPPORT_RX_DEMODULATION 1
#define CONFIG_SOC_RMT_SUPPORT_TX_ASYNC_STOP 1
#define CONFIG_SOC_RMT_SUPPORT_TX_LOOP_COUNT 1
#define CONFIG_SOC_RMT_SUPPORT_TX_LOOP_AUTO_STOP 1
#define CONFIG_SOC_RMT_SUPPORT_TX_SYNCHRO 1
#define CONFIG_SOC_RMT_SUPPORT_TX_CARRIER_DATA_ONLY 1
#define CONFIG_SOC_RMT_SUPPORT_XTAL 1
#define CONFIG_SOC_RMT_SUPPORT_RC_FAST 1
#define CONFIG_SOC_RMT_SUPPORT_APB 1
#define CONFIG_SOC_RMT_SUPPORT_DMA 1
#define CONFIG_SOC_LCD_I80_SUPPORTED 1
#define CONFIG_SOC_LCD_RGB_SUPPORTED 1
#define CONFIG_SOC_LCD_I80_BUSES 1
#define CONFIG_SOC_LCD_RGB_PANELS 1
#define CONFIG_SOC_LCD_I80_BUS_WIDTH 16
#define CONFIG_SOC_LCD_RGB_DATA_WIDTH 16
#define CONFIG_SOC_LCD_SUPPORT_RGB_YUV_CONV 1
#define CONFIG_SOC_RTC_CNTL_CPU_PD_DMA_BUS_WIDTH 128
#define CONFIG_SOC_RTC_CNTL_CPU_PD_REG_FILE_NUM 549
#define CONFIG_SOC_RTC_CNTL_TAGMEM_PD_DMA_BUS_WIDTH 128
#define CONFIG_SOC_RTCIO_PIN_COUNT 22
#define CONFIG_SOC_RTCIO_INPUT_OUTPUT_SUPPORTED 1
#define CONFIG_SOC_RTCIO_HOLD_SUPPORTED 1
#define CONFIG_SOC_RTCIO_WAKE_SUPPORTED 1
#define CONFIG_SOC_SDM_GROUPS 1
#define CONFIG_SOC_SDM_CHANNELS_PER_GROUP 8
#define CONFIG_SOC_SPI_PERIPH_NUM 3
#define CONFIG_SOC_SPI_MAXIMUM_BUFFER_SIZE 64
#define CONFIG_SOC_SPI_SUPPORT_DDRCLK 1
#define CONFIG_SOC_SPI_SLAVE_SUPPORT_SEG_TRANS 1
#define CONFIG_SOC_SPI_SUPPORT_CD_SIG 1
#define CONFIG_SOC_SPI_SUPPORT_CONTINUOUS_TRANS 1
#define CONFIG_SOC_SPI_SUPPORT_SLAVE_HD_VER2 1
#define CONFIG_SOC_SPI_PERIPH_SUPPORT_CONTROL_DUMMY_OUT 1
#define CONFIG_SOC_MEMSPI_IS_INDEPENDENT 1
#define CONFIG_SOC_SPI_MAX_PRE_DIVIDER 16
#define CONFIG_SOC_SPI_SUPPORT_OCT 1
#define CONFIG_SOC_MEMSPI_SRC_FREQ_120M 1
#define CONFIG_SOC_MEMSPI_SRC_FREQ_80M_SUPPORTED 1
#define CONFIG_SOC_MEMSPI_SRC_FREQ_40M_SUPPORTED 1
#define CONFIG_SOC_MEMSPI_SRC_FREQ_20M_SUPPORTED 1
#define CONFIG_SOC_SPIRAM_SUPPORTED 1
#define CONFIG_SOC_SYSTIMER_COUNTER_NUM 2
#define CONFIG_SOC_SYSTIMER_ALARM_NUM 3
#define CONFIG_SOC_SYSTIMER_BIT_WIDTH_LO 32
#define CONFIG_SOC_SYSTIMER_BIT_WIDTH_HI 20
#define CONFIG_SOC_SYSTIMER_FIXED_DIVIDER 1
#define CONFIG_SOC_SYSTIMER_INT_LEVEL 1
#define CONFIG_SOC_SYSTIMER_ALARM_MISS_COMPENSATE 1
#define CONFIG_SOC_TIMER_GROUPS 2
#define CONFIG_SOC_TIMER_GROUP_TIMERS_PER_GROUP 2
#define CONFIG_SOC_TIMER_GROUP_COUNTER_BIT_WIDTH 54
#define CONFIG_SOC_TIMER_GROUP_SUPPORT_XTAL 1
#define CONFIG_SOC_TIMER_GROUP_SUPPORT_APB 1
#define CONFIG_SOC_TIMER_GROUP_TOTAL_TIMERS 4
#define CONFIG_SOC_TOUCH_VERSION_2 1
#define CONFIG_SOC_TOUCH_SENSOR_NUM 15
#define CONFIG_SOC_TOUCH_PROXIMITY_CHANNEL_NUM 3
#define CONFIG_SOC_TOUCH_PROXIMITY_MEAS_DONE_SUPPORTED 1
#define CONFIG_SOC_TOUCH_PAD_THRESHOLD_MAX 0x1FFFFF
#define CONFIG_SOC_TOUCH_PAD_MEASURE_WAIT_MAX 0xFF
#define CONFIG_SOC_UART_NUM 3
#define CONFIG_SOC_UART_FIFO_LEN 128
#define CONFIG_SOC_UART_BITRATE_MAX 5000000
#define CONFIG_SOC_UART_SUPPORT_FSM_TX_WAIT_SEND 1
#define CONFIG_SOC_UART_SUPPORT_WAKEUP_INT 1
#define CONFIG_SOC_UART_SUPPORT_APB_CLK 1
#define CONFIG_SOC_UART_SUPPORT_RTC_CLK 1
#define CONFIG_SOC_UART_SUPPORT_XTAL_CLK 1
#define CONFIG_SOC_UART_REQUIRE_CORE_RESET 1
#define CONFIG_SOC_USB_PERIPH_NUM 1
#define CONFIG_SOC_SHA_DMA_MAX_BUFFER_SIZE 3968
#define CONFIG_SOC_SHA_SUPPORT_DMA 1
#define CONFIG_SOC_SHA_SUPPORT_RESUME 1
#define CONFIG_SOC_SHA_GDMA 1
#define CONFIG_SOC_SHA_SUPPORT_SHA1 1
#define CONFIG_SOC_SHA_SUPPORT_SHA224 1
#define CONFIG_SOC_SHA_SUPPORT_SHA256 1
#define CONFIG_SOC_SHA_SUPPORT_SHA384 1
#define CONFIG_SOC_SHA_SUPPORT_SHA512 1
#define CONFIG_SOC_SHA_SUPPORT_SHA512_224 1
#define CONFIG_SOC_SHA_SUPPORT_SHA512_256 1
#define CONFIG_SOC_SHA_SUPPORT_SHA512_T 1
#define CONFIG_SOC_RSA_MAX_BIT_LEN 4096
#define CONFIG_SOC_AES_SUPPORT_DMA 1
#define CONFIG_SOC_AES_GDMA 1
#define CONFIG_SOC_AES_SUPPORT_AES_128 1
#define CONFIG_SOC_AES_SUPPORT_AES_256 1
#define CONFIG_SOC_PM_SUPPORT_EXT_WAKEUP 1
#define CONFIG_SOC_PM_SUPPORT_WIFI_WAKEUP 1
#define CONFIG_SOC_PM_SUPPORT_BT_WAKEUP 1
#define CONFIG_SOC_PM_SUPPORT_CPU_PD 1
#define CONFIG_SOC_PM_SUPPORT_TAGMEM_PD 1
#define CONFIG_SOC_PM_SUPPORT_RTC_PERIPH_PD 1
#define CONFIG_SOC_PM_SUPPORT_TOUCH_SENSOR_WAKEUP 1
#define CONFIG_SOC_PM_SUPPORT_DEEPSLEEP_CHECK_STUB_ONLY 1
#define CONFIG_SOC_SECURE_BOOT_V2_RSA 1
#define CONFIG_SOC_EFUSE_SECURE_BOOT_KEY_DIGESTS 3
#define CONFIG_SOC_EFUSE_REVOKE_BOOT_KEY_DIGESTS 1
#define CONFIG_SOC_SUPPORT_SECURE_BOOT_REVOKE_KEY 1
#define CONFIG_SOC_FLASH_ENCRYPTED_XTS_AES_BLOCK_MAX 64
#define CONFIG_SOC_FLASH_ENCRYPTION_XTS_AES 1
#define CONFIG_SOC_FLASH_ENCRYPTION_XTS_AES_OPTIONS 1
#define CONFIG_SOC_FLASH_ENCRYPTION_XTS_AES_128 1
#define CONFIG_SOC_FLASH_ENCRYPTION_XTS_AES_256 1
#define CONFIG_SOC_MEMPROT_CPU_PREFETCH_PAD_SIZE 16
#define CONFIG_SOC_MEMPROT_MEM_ALIGN_SIZE 256
#define CONFIG_SOC_PHY_DIG_REGS_MEM_SIZE 21
#define CONFIG_SOC_MAC_BB_PD_MEM_SIZE 192
#define CONFIG_SOC_WIFI_LIGHT_SLEEP_CLK_WIDTH 12
#define CONFIG_SOC_SPI_MEM_SUPPORT_AUTO_WAIT_IDLE 1
#define CONFIG_SOC_SPI_MEM_SUPPORT_AUTO_SUSPEND 1
#define CONFIG_SOC_SPI_MEM_SUPPORT_AUTO_RESUME 1
#define CONFIG_SOC_SPI_MEM_SUPPORT_SW_SUSPEND 1
#define CONFIG_SOC_SPI_MEM_SUPPORT_OPI_MODE 1
#define CONFIG_SOC_SPI_MEM_SUPPORT_TIME_TUNING 1
#define CONFIG_SOC_SPI_MEM_SUPPORT_CONFIG_GPIO_BY_EFUSE 1
#define CONFIG_SOC_COEX_HW_PTI 1
#define CONFIG_SOC_SDMMC_USE_GPIO_MATRIX 1
#define CONFIG_SOC_SDMMC_NUM_SLOTS 2
#define CONFIG_SOC_SDMMC_SUPPORT_XTAL_CLOCK 1
#define CONFIG_SOC_TEMPERATURE_SENSOR_SUPPORT_FAST_RC 1
#define CONFIG_SOC_WIFI_HW_TSF 1
#define CONFIG_SOC_WIFI_FTM_SUPPORT 1
#define CONFIG_SOC_WIFI_GCMP_SUPPORT 1
#define CONFIG_SOC_WIFI_WAPI_SUPPORT 1
#define CONFIG_SOC_WIFI_CSI_SUPPORT 1
#define CONFIG_SOC_WIFI_MESH_SUPPORT 1
#define CONFIG_SOC_BLE_SUPPORTED 1
#define CONFIG_SOC_BLE_MESH_SUPPORTED 1
#define CONFIG_SOC_TWAI_BRP_MIN 2
#define CONFIG_SOC_TWAI_BRP_MAX 16384
#define CONFIG_SOC_TWAI_SUPPORTS_RX_STATUS 1
#define CONFIG_IDF_CMAKE 1
#define CONFIG_IDF_TARGET_ARCH_XTENSA 1
#define CONFIG_IDF_TARGET_ARCH "xtensa"
#define CONFIG_IDF_TARGET "esp32s3"
#define CONFIG_IDF_TARGET_ESP32S3 1
#define CONFIG_IDF_FIRMWARE_CHIP_ID 0x0009
#define CONFIG_APP_BUILD_TYPE_APP_2NDBOOT 1
#define CONFIG_APP_BUILD_GENERATE_BINARIES 1
#define CONFIG_APP_BUILD_BOOTLOADER 1
#define CONFIG_APP_BUILD_USE_FLASH_SECTIONS 1
#define CONFIG_BOOTLOADER_OFFSET_IN_FLASH 0x0
#define CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_SIZE 1
#define CONFIG_BOOTLOADER_LOG_LEVEL_VERBOSE 1
#define CONFIG_BOOTLOADER_LOG_LEVEL 5
#define CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_9V 1
#define CONFIG_BOOTLOADER_REGION_PROTECTION_ENABLE 1
#define CONFIG_BOOTLOADER_RESERVE_RTC_SIZE 0x0
#define CONFIG_BOOTLOADER_FLASH_XMC_SUPPORT 1
#define CONFIG_SECURE_BOOT_V2_RSA_SUPPORTED 1
#define CONFIG_SECURE_BOOT_V2_PREFERRED 1
#define CONFIG_SECURE_ROM_DL_MODE_ENABLED 1
#define CONFIG_APP_COMPILE_TIME_DATE 1
#define CONFIG_APP_RETRIEVE_LEN_ELF_SHA 16
#define CONFIG_ESP_ROM_HAS_CRC_LE 1
#define CONFIG_ESP_ROM_HAS_CRC_BE 1
#define CONFIG_ESP_ROM_HAS_JPEG_DECODE 1
#define CONFIG_ESP_ROM_SUPPORT_MULTIPLE_UART 1
#define CONFIG_ESP_ROM_UART_CLK_IS_XTAL 1
#define CONFIG_ESP_ROM_HAS_RETARGETABLE_LOCKING 1
#define CONFIG_ESP_ROM_USB_SERIAL_DEVICE_NUM 4
#define CONFIG_ESP_ROM_HAS_ERASE_0_REGION_BUG 1
#define CONFIG_ESP_ROM_GET_CLK_FREQ 1
#define CONFIG_ESP_ROM_HAS_HAL_WDT 1
#define CONFIG_ESP_ROM_NEEDS_SWSETUP_WORKAROUND 1
#define CONFIG_BOOT_ROM_LOG_ALWAYS_ON 1
#define CONFIG_ESPTOOLPY_OCT_FLASH 1
#define CONFIG_ESPTOOLPY_FLASHMODE_OPI 1
#define CONFIG_ESPTOOLPY_FLASH_SAMPLE_MODE_STR 1
#define CONFIG_ESPTOOLPY_FLASHMODE "dout"
#define CONFIG_ESPTOOLPY_FLASHFREQ_40M 1
#define CONFIG_ESPTOOLPY_FLASHFREQ "40m"
#define CONFIG_ESPTOOLPY_FLASHSIZE_4MB 1
#define CONFIG_ESPTOOLPY_FLASHSIZE "4MB"
#define CONFIG_ESPTOOLPY_BEFORE_RESET 1
#define CONFIG_ESPTOOLPY_BEFORE "default_reset"
#define CONFIG_ESPTOOLPY_AFTER_RESET 1
#define CONFIG_ESPTOOLPY_AFTER "hard_reset"
#define CONFIG_ESPTOOLPY_MONITOR_BAUD 115200
#define CONFIG_PARTITION_TABLE_CUSTOM 1
#define CONFIG_PARTITION_TABLE_CUSTOM_FILENAME "partitions.csv"
#define CONFIG_PARTITION_TABLE_FILENAME "partitions.csv"
#define CONFIG_PARTITION_TABLE_OFFSET 0x8000
#define CONFIG_PARTITION_TABLE_MD5 1
#define CONFIG_COMPILER_OPTIMIZATION_SIZE 1
#define CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_ENABLE 1
#define CONFIG_COMPILER_FLOAT_LIB_FROM_GCCLIB 1
#define CONFIG_COMPILER_OPTIMIZATION_ASSERTION_LEVEL 2
#define CONFIG_COMPILER_HIDE_PATHS_MACROS 1
#define CONFIG_COMPILER_STACK_CHECK_MODE_NONE 1
#define CONFIG_APPTRACE_DEST_NONE 1
#define CONFIG_APPTRACE_DEST_UART_NONE 1
#define CONFIG_APPTRACE_UART_TASK_PRIO 1
#define CONFIG_APPTRACE_LOCK_ENABLE 1
#define CONFIG_BT_ENABLED 1
#define CONFIG_BT_NIMBLE_ENABLED 1
#define CONFIG_BT_CONTROLLER_ENABLED 1
#define CONFIG_BT_NIMBLE_MEM_ALLOC_MODE_INTERNAL 1
#define CONFIG_BT_NIMBLE_LOG_LEVEL_INFO 1
#define CONFIG_BT_NIMBLE_LOG_LEVEL 1
#define CONFIG_BT_NIMBLE_MAX_CONNECTIONS 3
#define CONFIG_BT_NIMBLE_MAX_BONDS 3
#define CONFIG_BT_NIMBLE_MAX_CCCDS 8
#define CONFIG_BT_NIMBLE_L2CAP_COC_MAX_NUM 0
#define CONFIG_BT_NIMBLE_PINNED_TO_CORE_0 1
#define CONFIG_BT_NIMBLE_PINNED_TO_CORE 0
#define CONFIG_BT_NIMBLE_HOST_TASK_STACK_SIZE 4096
#define CONFIG_BT_NIMBLE_ROLE_CENTRAL 1
#define CONFIG_BT_NIMBLE_ROLE_PERIPHERAL 1
#define CONFIG_BT_NIMBLE_ROLE_BROADCASTER 1
#define CONFIG_BT_NIMBLE_ROLE_OBSERVER 1
#define CONFIG_BT_NIMBLE_SECURITY_ENABLE 1
#define CONFIG_BT_NIMBLE_SM_LEGACY 1
#define CONFIG_BT_NIMBLE_SM_SC 1
#define CONFIG_BT_NIMBLE_LL_CFG_FEAT_LE_ENCRYPTION 1
#define CONFIG_BT_NIMBLE_SVC_GAP_DEVICE_NAME "nimble"
#define CONFIG_BT_NIMBLE_GAP_DEVICE_NAME_MAX_LEN 31
#define CONFIG_BT_NIMBLE_ATT_PREFERRED_MTU 256
#define CONFIG_BT_NIMBLE_SVC_GAP_APPEARANCE 0x0
#define CONFIG_BT_NIMBLE_MSYS_1_BLOCK_COUNT 12
#define CONFIG_BT_NIMBLE_MSYS_1_BLOCK_SIZE 256
#define CONFIG_BT_NIMBLE_MSYS_2_BLOCK_COUNT 24
#define CONFIG_BT_NIMBLE_MSYS_2_BLOCK_SIZE 320
#define CONFIG_BT_NIMBLE_ACL_BUF_COUNT 24
#define CONFIG_BT_NIMBLE_ACL_BUF_SIZE 255
#define CONFIG_BT_NIMBLE_HCI_EVT_BUF_SIZE 70
#define CONFIG_BT_NIMBLE_HCI_EVT_HI_BUF_COUNT 30
#define CONFIG_BT_NIMBLE_HCI_EVT_LO_BUF_COUNT 8
#define CONFIG_BT_NIMBLE_GATT_MAX_PROCS 4
#define CONFIG_BT_NIMBLE_RPA_TIMEOUT 900
#define CONFIG_BT_NIMBLE_CRYPTO_STACK_MBEDTLS 1
#define CONFIG_BT_NIMBLE_HS_STOP_TIMEOUT_MS 2000
#define CONFIG_BT_NIMBLE_ENABLE_CONN_REATTEMPT 1
#define CONFIG_BT_NIMBLE_MAX_CONN_REATTEMPT 3
#define CONFIG_BT_NIMBLE_50_FEATURE_SUPPORT 1
#define CONFIG_BT_NIMBLE_LL_CFG_FEAT_LE_2M_PHY 1
#define CONFIG_BT_NIMBLE_LL_CFG_FEAT_LE_CODED_PHY 1
#define CONFIG_BT_NIMBLE_MAX_PERIODIC_SYNCS 0
#define CONFIG_BT_NIMBLE_COEX_PHY_CODED_TX_RX_TLIM_DIS 1
#define CONFIG_BT_NIMBLE_COEX_PHY_CODED_TX_RX_TLIM_EFF 0
#define CONFIG_BT_NIMBLE_WHITELIST_SIZE 12
#define CONFIG_BT_NIMBLE_USE_ESP_TIMER 1
#define CONFIG_BT_NIMBLE_LEGACY_VHCI_ENABLE 1
#define CONFIG_BT_CTRL_MODE_EFF 1
#define CONFIG_BT_CTRL_BLE_MAX_ACT 10
#define CONFIG_BT_CTRL_BLE_MAX_ACT_EFF 10
#define CONFIG_BT_CTRL_BLE_STATIC_ACL_TX_BUF_NB 0
#define CONFIG_BT_CTRL_PINNED_TO_CORE_0 1
#define CONFIG_BT_CTRL_PINNED_TO_CORE 0
#define CONFIG_BT_CTRL_HCI_MODE_VHCI 1
#define CONFIG_BT_CTRL_HCI_TL 1
#define CONFIG_BT_CTRL_ADV_DUP_FILT_MAX 30
#define CONFIG_BT_CTRL_HW_CCA_VAL 20
#define CONFIG_BT_CTRL_HW_CCA_EFF 0
#define CONFIG_BT_CTRL_CE_LENGTH_TYPE_ORIG 1
#define CONFIG_BT_CTRL_CE_LENGTH_TYPE_EFF 0
#define CONFIG_BT_CTRL_TX_ANTENNA_INDEX_0 1
#define CONFIG_BT_CTRL_TX_ANTENNA_INDEX_EFF 0
#define CONFIG_BT_CTRL_RX_ANTENNA_INDEX_0 1
#define CONFIG_BT_CTRL_RX_ANTENNA_INDEX_EFF 0
#define CONFIG_BT_CTRL_DFT_TX_POWER_LEVEL_P3 1
#define CONFIG_BT_CTRL_DFT_TX_POWER_LEVEL_EFF 9
#define CONFIG_BT_CTRL_BLE_ADV_REPORT_FLOW_CTRL_SUPP 1
#define CONFIG_BT_CTRL_BLE_ADV_REPORT_FLOW_CTRL_NUM 100
#define CONFIG_BT_CTRL_BLE_ADV_REPORT_DISCARD_THRSHOLD 20
#define CONFIG_BT_CTRL_BLE_SCAN_DUPL 1
#define CONFIG_BT_CTRL_SCAN_DUPL_TYPE_DEVICE 1
#define CONFIG_BT_CTRL_SCAN_DUPL_TYPE 0
#define CONFIG_BT_CTRL_SCAN_DUPL_CACHE_SIZE 100
#define CONFIG_BT_CTRL_COEX_PHY_CODED_TX_RX_TLIM_DIS 1
#define CONFIG_BT_CTRL_COEX_PHY_CODED_TX_RX_TLIM_EFF 0
#define CONFIG_BT_CTRL_SLEEP_MODE_EFF 0
#define CONFIG_BT_CTRL_SLEEP_CLOCK_EFF 0
#define CONFIG_BT_CTRL_HCI_TL_EFF 1
#define CONFIG_SPI_MASTER_ISR_IN_IRAM 1
#define CONFIG_SPI_SLAVE_ISR_IN_IRAM 1
#define CONFIG_EFUSE_MAX_BLK_LEN 256
#define CONFIG_ESP_ERR_TO_NAME_LOOKUP 1
#define CONFIG_ETH_ENABLED 1
#define CONFIG_ETH_USE_SPI_ETHERNET 1
#define CONFIG_ESP_EVENT_POST_FROM_ISR 1
#define CONFIG_ESP_EVENT_POST_FROM_IRAM_ISR 1
#define CONFIG_ESP_MAC_ADDR_UNIVERSE_WIFI_STA 1
#define CONFIG_ESP_MAC_ADDR_UNIVERSE_WIFI_AP 1
#define CONFIG_ESP_MAC_ADDR_UNIVERSE_BT 1
#define CONFIG_ESP_MAC_ADDR_UNIVERSE_ETH 1
#define CONFIG_ESP32S3_UNIVERSAL_MAC_ADDRESSES_FOUR 1
#define CONFIG_ESP32S3_UNIVERSAL_MAC_ADDRESSES 4
#define CONFIG_ESP_SLEEP_RTC_BUS_ISO_WORKAROUND 1
#define CONFIG_ESP_SLEEP_FLASH_LEAKAGE_WORKAROUND 1
#define CONFIG_ESP_SLEEP_DEEP_SLEEP_WAKEUP_DELAY 2000
#define CONFIG_RTC_CLK_SRC_INT_RC 1
#define CONFIG_RTC_CLK_CAL_CYCLES 1024
#define CONFIG_RTC_CLOCK_BBPLL_POWER_ON_WITH_USB 1
#define CONFIG_MMU_PAGE_SIZE_64KB 1
#define CONFIG_MMU_PAGE_MODE "64KB"
#define CONFIG_MMU_PAGE_SIZE 0x10000
#define CONFIG_XTAL_FREQ_40 1
#define CONFIG_XTAL_FREQ 40
#define CONFIG_LCD_PANEL_IO_FORMAT_BUF_SIZE 32
#define CONFIG_ESP_NETIF_IP_LOST_TIMER_INTERVAL 120
#define CONFIG_ESP_NETIF_TCPIP_LWIP 1
#define CONFIG_ESP_PHY_CALIBRATION_AND_DATA_STORAGE 1
#define CONFIG_ESP_PHY_MAX_WIFI_TX_POWER 20
#define CONFIG_ESP_PHY_MAX_TX_POWER 20
#define CONFIG_ESP_PHY_REDUCE_TX_POWER 1
#define CONFIG_ESP_PHY_ENABLE_USB 1
#define CONFIG_PM_POWER_DOWN_CPU_IN_LIGHT_SLEEP 1
#define CONFIG_PM_POWER_DOWN_TAGMEM_IN_LIGHT_SLEEP 1
#define CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_160 1
#define CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ 160
#define CONFIG_ESP32S3_INSTRUCTION_CACHE_16KB 1
#define CONFIG_ESP32S3_INSTRUCTION_CACHE_SIZE 0x4000
#define CONFIG_ESP32S3_INSTRUCTION_CACHE_8WAYS 1
#define CONFIG_ESP32S3_ICACHE_ASSOCIATED_WAYS 8
#define CONFIG_ESP32S3_INSTRUCTION_CACHE_LINE_32B 1
#define CONFIG_ESP32S3_INSTRUCTION_CACHE_LINE_SIZE 32
#define CONFIG_ESP32S3_DATA_CACHE_32KB 1
#define CONFIG_ESP32S3_DATA_CACHE_SIZE 0x8000
#define CONFIG_ESP32S3_DATA_CACHE_8WAYS 1
#define CONFIG_ESP32S3_DCACHE_ASSOCIATED_WAYS 8
#define CONFIG_ESP32S3_DATA_CACHE_LINE_32B 1
#define CONFIG_ESP32S3_DATA_CACHE_LINE_SIZE 32
#define CONFIG_ESP32S3_TRACEMEM_RESERVE_DRAM 0x0
#define CONFIG_ESP_SYSTEM_PANIC_PRINT_REBOOT 1
#define CONFIG_ESP_SYSTEM_RTC_FAST_MEM_AS_HEAP_DEPCHECK 1
#define CONFIG_ESP_SYSTEM_ALLOW_RTC_FAST_MEM_AS_HEAP 1
#define CONFIG_ESP_SYSTEM_MEMPROT_FEATURE 1
#define CONFIG_ESP_SYSTEM_MEMPROT_FEATURE_LOCK 1
#define CONFIG_ESP_SYSTEM_EVENT_QUEUE_SIZE 32
#define CONFIG_ESP_SYSTEM_EVENT_TASK_STACK_SIZE 2304
#define CONFIG_ESP_MAIN_TASK_STACK_SIZE 3584
#define CONFIG_ESP_MAIN_TASK_AFFINITY_CPU0 1
#define CONFIG_ESP_MAIN_TASK_AFFINITY 0x0
#define CONFIG_ESP_MINIMAL_SHARED_STACK_SIZE 2048
#define CONFIG_ESP_CONSOLE_UART_CUSTOM 1
#define CONFIG_ESP_CONSOLE_SECONDARY_USB_SERIAL_JTAG 1
#define CONFIG_ESP_CONSOLE_UART 1
#define CONFIG_ESP_CONSOLE_MULTIPLE_UART 1
#define CONFIG_ESP_CONSOLE_UART_CUSTOM_NUM_0 1
#define CONFIG_ESP_CONSOLE_UART_NUM 0
#define CONFIG_ESP_CONSOLE_UART_TX_GPIO 43
#define CONFIG_ESP_CONSOLE_UART_RX_GPIO 44
#define CONFIG_ESP_CONSOLE_UART_BAUDRATE 115200
#define CONFIG_ESP_DEBUG_STUBS_ENABLE 1
#define CONFIG_ESP_DEBUG_OCDAWARE 1
#define CONFIG_ESP_SYSTEM_CHECK_INT_LEVEL_4 1
#define CONFIG_ESP_BROWNOUT_DET 1
#define CONFIG_ESP_BROWNOUT_DET_LVL_SEL_7 1
#define CONFIG_ESP_BROWNOUT_DET_LVL 7
#define CONFIG_ESP_SYSTEM_BROWNOUT_INTR 1
#define CONFIG_ESP_IPC_TASK_STACK_SIZE 1024
#define CONFIG_ESP_IPC_USES_CALLERS_PRIORITY 1
#define CONFIG_ESP_IPC_ISR_ENABLE 1
#define CONFIG_ESP_TIME_FUNCS_USE_RTC_TIMER 1
#define CONFIG_ESP_TIME_FUNCS_USE_ESP_TIMER 1
#define CONFIG_ESP_TIMER_TASK_STACK_SIZE 3584
#define CONFIG_ESP_TIMER_INTERRUPT_LEVEL 1
#define CONFIG_ESP_TIMER_IMPL_SYSTIMER 1
#define CONFIG_ESP32_WIFI_ENABLED 1
#define CONFIG_ESP32_WIFI_SW_COEXIST_ENABLE 1
#define CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM 10
#define CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM 32
#define CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER 1
#define CONFIG_ESP32_WIFI_TX_BUFFER_TYPE 1
#define CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER_NUM 32
#define CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED 1
#define CONFIG_ESP32_WIFI_TX_BA_WIN 6
#define CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED 1
#define CONFIG_ESP32_WIFI_RX_BA_WIN 6
#define CONFIG_ESP32_WIFI_NVS_ENABLED 1
#define CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_0 1
#define CONFIG_ESP32_WIFI_SOFTAP_BEACON_MAX_LEN 752
#define CONFIG_ESP32_WIFI_MGMT_SBUF_NUM 32
#define CONFIG_ESP32_WIFI_IRAM_OPT 1
#define CONFIG_ESP32_WIFI_RX_IRAM_OPT 1
#define CONFIG_ESP32_WIFI_ENABLE_WPA3_SAE 1
#define CONFIG_ESP_WIFI_SOFTAP_SUPPORT 1
#define CONFIG_ESP_COREDUMP_ENABLE_TO_UART 1
#define CONFIG_ESP_COREDUMP_DATA_FORMAT_ELF 1
#define CONFIG_ESP_COREDUMP_CHECKSUM_CRC32 1
#define CONFIG_ESP_COREDUMP_ENABLE 1
#define CONFIG_ESP_COREDUMP_MAX_TASKS_NUM 64
#define CONFIG_ESP_COREDUMP_UART_DELAY 1000
#define CONFIG_ESP_COREDUMP_STACK_SIZE 0
#define CONFIG_ESP_COREDUMP_DECODE_INFO 1
#define CONFIG_ESP_COREDUMP_DECODE "info"
#define CONFIG_FATFS_VOLUME_COUNT 2
#define CONFIG_FATFS_SECTOR_4096 1
#define CONFIG_FATFS_SECTORS_PER_CLUSTER_1 1
#define CONFIG_FATFS_CODEPAGE_437 1
#define CONFIG_FATFS_AUTO_TYPE 1
#define CONFIG_FATFS_CODEPAGE 437
#define CONFIG_FATFS_LFN_NONE 1
#define CONFIG_FATFS_FS_LOCK 0
#define CONFIG_FATFS_TIMEOUT_MS 10000
#define CONFIG_FATFS_PER_FILE_CACHE 1
#define CONFIG_FREERTOS_HZ 100
#define CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY 1
#define CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS 1
#define CONFIG_FREERTOS_IDLE_TASK_STACKSIZE 1536
#define CONFIG_FREERTOS_MAX_TASK_NAME_LEN 16
#define CONFIG_FREERTOS_TIMER_TASK_PRIORITY 1
#define CONFIG_FREERTOS_TIMER_TASK_STACK_DEPTH 2048
#define CONFIG_FREERTOS_TIMER_QUEUE_LENGTH 10
#define CONFIG_FREERTOS_QUEUE_REGISTRY_SIZE 0
#define CONFIG_FREERTOS_TASK_FUNCTION_WRAPPER 1
#define CONFIG_FREERTOS_CHECK_MUTEX_GIVEN_BY_OWNER 1
#define CONFIG_FREERTOS_ISR_STACKSIZE 2096
#define CONFIG_FREERTOS_INTERRUPT_BACKTRACE 1
#define CONFIG_FREERTOS_TICK_SUPPORT_SYSTIMER 1
#define CONFIG_FREERTOS_CORETIMER_SYSTIMER_LVL1 1
#define CONFIG_FREERTOS_SYSTICK_USES_SYSTIMER 1
#define CONFIG_FREERTOS_ASSERT_ON_UNTESTED_FUNCTION 1
#define CONFIG_FREERTOS_ENABLE_TASK_SNAPSHOT 1
#define CONFIG_FREERTOS_NO_AFFINITY 0x7FFFFFFF
#define CONFIG_FREERTOS_SUPPORT_STATIC_ALLOCATION 1
#define CONFIG_FREERTOS_DEBUG_OCDAWARE 1
#define CONFIG_HAL_ASSERTION_EQUALS_SYSTEM 1
#define CONFIG_HAL_DEFAULT_ASSERTION_LEVEL 2
#define CONFIG_HAL_WDT_USE_ROM_IMPL 1
#define CONFIG_HEAP_POISONING_DISABLED 1
#define CONFIG_HEAP_TRACING_OFF 1
#define CONFIG_LOG_DEFAULT_LEVEL_VERBOSE 1
#define CONFIG_LOG_DEFAULT_LEVEL 5
#define CONFIG_LOG_MAXIMUM_EQUALS_DEFAULT 1
#define CONFIG_LOG_MAXIMUM_LEVEL 5
#define CONFIG_LOG_COLORS 1
#define CONFIG_LOG_TIMESTAMP_SOURCE_SYSTEM 1
#define CONFIG_LWIP_LOCAL_HOSTNAME "espressif"
#define CONFIG_LWIP_DNS_SUPPORT_MDNS_QUERIES 1
#define CONFIG_LWIP_TIMERS_ONDEMAND 1
#define CONFIG_LWIP_MAX_SOCKETS 10
#define CONFIG_LWIP_SO_REUSE 1
#define CONFIG_LWIP_SO_REUSE_RXTOALL 1
#define CONFIG_LWIP_IP4_FRAG 1
#define CONFIG_LWIP_IP6_FRAG 1
#define CONFIG_LWIP_ESP_GRATUITOUS_ARP 1
#define CONFIG_LWIP_GARP_TMR_INTERVAL 60
#define CONFIG_LWIP_TCPIP_RECVMBOX_SIZE 32
#define CONFIG_LWIP_DHCP_DOES_ARP_CHECK 1
#define CONFIG_LWIP_DHCP_DISABLE_VENDOR_CLASS_ID 1
#define CONFIG_LWIP_DHCP_OPTIONS_LEN 68
#define CONFIG_LWIP_NUM_NETIF_CLIENT_DATA 0
#define CONFIG_LWIP_DHCPS 1
#define CONFIG_LWIP_DHCPS_LEASE_UNIT 60
#define CONFIG_LWIP_DHCPS_MAX_STATION_NUM 8
#define CONFIG_LWIP_IPV6 1
#define CONFIG_LWIP_IPV6_NUM_ADDRESSES 3
#define CONFIG_LWIP_NETIF_LOOPBACK 1
#define CONFIG_LWIP_LOOPBACK_MAX_PBUFS 8
#define CONFIG_LWIP_MAX_ACTIVE_TCP 16
#define CONFIG_LWIP_MAX_LISTENING_TCP 16
#define CONFIG_LWIP_TCP_HIGH_SPEED_RETRANSMISSION 1
#define CONFIG_LWIP_TCP_MAXRTX 12
#define CONFIG_LWIP_TCP_SYNMAXRTX 6
#define CONFIG_LWIP_TCP_MSS 1440
#define CONFIG_LWIP_TCP_TMR_INTERVAL 250
#define CONFIG_LWIP_TCP_MSL 60000
#define CONFIG_LWIP_TCP_FIN_WAIT_TIMEOUT 20000
#define CONFIG_LWIP_TCP_SND_BUF_DEFAULT 5744
#define CONFIG_LWIP_TCP_WND_DEFAULT 5744
#define CONFIG_LWIP_TCP_RECVMBOX_SIZE 6
#define CONFIG_LWIP_TCP_QUEUE_OOSEQ 1
#define CONFIG_LWIP_TCP_OVERSIZE_MSS 1
#define CONFIG_LWIP_TCP_RTO_TIME 1500
#define CONFIG_LWIP_MAX_UDP_PCBS 16
#define CONFIG_LWIP_UDP_RECVMBOX_SIZE 6
#define CONFIG_LWIP_CHECKSUM_CHECK_ICMP 1
#define CONFIG_LWIP_TCPIP_TASK_STACK_SIZE 3072
#define CONFIG_LWIP_TCPIP_TASK_AFFINITY_NO_AFFINITY 1
#define CONFIG_LWIP_TCPIP_TASK_AFFINITY 0x7FFFFFFF
#define CONFIG_LWIP_IPV6_MEMP_NUM_ND6_QUEUE 3
#define CONFIG_LWIP_IPV6_ND6_NUM_NEIGHBORS 5
#define CONFIG_LWIP_ICMP 1
#define CONFIG_LWIP_MAX_RAW_PCBS 16
#define CONFIG_LWIP_SNTP_MAX_SERVERS 1
#define CONFIG_LWIP_SNTP_UPDATE_DELAY 3600000
#define CONFIG_LWIP_BRIDGEIF_MAX_PORTS 7
#define CONFIG_LWIP_ESP_LWIP_ASSERT 1
#define CONFIG_LWIP_HOOK_TCP_ISN_DEFAULT 1
#define CONFIG_LWIP_HOOK_IP6_ROUTE_NONE 1
#define CONFIG_LWIP_HOOK_ND6_GET_GW_NONE 1
#define CONFIG_LWIP_HOOK_NETCONN_EXT_RESOLVE_NONE 1
#define CONFIG_LWIP_HOOK_IP6_INPUT_NONE 1
#define CONFIG_NEWLIB_STDOUT_LINE_ENDING_CRLF 1
#define CONFIG_NEWLIB_STDIN_LINE_ENDING_CR 1
#define CONFIG_NEWLIB_TIME_SYSCALL_USE_RTC_HRT 1
#define CONFIG_PTHREAD_TASK_PRIO_DEFAULT 5
#define CONFIG_PTHREAD_TASK_STACK_SIZE_DEFAULT 3072
#define CONFIG_PTHREAD_STACK_MIN 768
#define CONFIG_PTHREAD_DEFAULT_CORE_NO_AFFINITY 1
#define CONFIG_PTHREAD_TASK_CORE_DEFAULT -1
#define CONFIG_PTHREAD_TASK_NAME_DEFAULT "pthread"
#define CONFIG_SPI_FLASH_VERIFY_WRITE 1
#define CONFIG_SPI_FLASH_ROM_DRIVER_PATCH 1
#define CONFIG_SPI_FLASH_HAS_ROM_IMPL 1
#define CONFIG_SPI_FLASH_DANGEROUS_WRITE_ABORTS 1
#define CONFIG_SPI_FLASH_YIELD_DURING_ERASE 1
#define CONFIG_SPI_FLASH_ERASE_YIELD_DURATION_MS 20
#define CONFIG_SPI_FLASH_ERASE_YIELD_TICKS 1
#define CONFIG_SPI_FLASH_WRITE_CHUNK_SIZE 8192
#define CONFIG_SPI_FLASH_BROWNOUT_RESET_XMC 1
#define CONFIG_SPI_FLASH_BROWNOUT_RESET 1
#define CONFIG_SPI_FLASH_SUPPORT_ISSI_CHIP 1
#define CONFIG_SPI_FLASH_SUPPORT_MXIC_CHIP 1
#define CONFIG_SPI_FLASH_SUPPORT_GD_CHIP 1
#define CONFIG_SPI_FLASH_SUPPORT_WINBOND_CHIP 1
#define CONFIG_SPI_FLASH_SUPPORT_MXIC_OPI_CHIP 1
#define CONFIG_SPI_FLASH_ENABLE_ENCRYPTED_READ_WRITE 1
#define CONFIG_SPIFFS_MAX_PARTITIONS 3
#define CONFIG_SPIFFS_CACHE 1
#define CONFIG_SPIFFS_CACHE_WR 1
#define CONFIG_SPIFFS_PAGE_CHECK 1
#define CONFIG_SPIFFS_GC_MAX_RUNS 10
#define CONFIG_SPIFFS_PAGE_SIZE 256
#define CONFIG_SPIFFS_OBJ_NAME_LEN 32
#define CONFIG_SPIFFS_USE_MAGIC 1
#define CONFIG_SPIFFS_USE_MAGIC_LENGTH 1
#define CONFIG_SPIFFS_META_LENGTH 4
#define CONFIG_SPIFFS_USE_MTIME 1
#define CONFIG_UNITY_ENABLE_FLOAT 1
#define CONFIG_UNITY_ENABLE_DOUBLE 1
#define CONFIG_UNITY_ENABLE_IDF_TEST_RUNNER 1
#define CONFIG_USB_OTG_SUPPORTED 1
#define CONFIG_USB_HOST_CONTROL_TRANSFER_MAX_SIZE 256
#define CONFIG_USB_HOST_HW_BUFFER_BIAS_BALANCED 1
#define CONFIG_VFS_SUPPORT_IO 1
#define CONFIG_VFS_SUPPORT_DIR 1
#define CONFIG_VFS_SUPPORT_SELECT 1
#define CONFIG_VFS_SUPPRESS_SELECT_DEBUG_OUTPUT 1
#define CONFIG_VFS_SUPPORT_TERMIOS 1
#define CONFIG_VFS_SEMIHOSTFS_MAX_MOUNT_POINTS 1
#define CONFIG_WL_SECTOR_SIZE_4096 1
#define CONFIG_WL_SECTOR_SIZE 4096
#define CONFIG_WPA_MBEDTLS_CRYPTO 1
/* List of deprecated options */
#define CONFIG_BROWNOUT_DET CONFIG_ESP_BROWNOUT_DET
#define CONFIG_BROWNOUT_DET_LVL CONFIG_ESP_BROWNOUT_DET_LVL
#define CONFIG_BROWNOUT_DET_LVL_SEL_7 CONFIG_ESP_BROWNOUT_DET_LVL_SEL_7
#define CONFIG_BT_NIMBLE_MSYS1_BLOCK_COUNT CONFIG_BT_NIMBLE_MSYS_1_BLOCK_COUNT
#define CONFIG_BT_NIMBLE_TASK_STACK_SIZE CONFIG_BT_NIMBLE_HOST_TASK_STACK_SIZE
#define CONFIG_COMPILER_OPTIMIZATION_LEVEL_RELEASE CONFIG_COMPILER_OPTIMIZATION_SIZE
#define CONFIG_CONSOLE_UART CONFIG_ESP_CONSOLE_UART
#define CONFIG_CONSOLE_UART_BAUDRATE CONFIG_ESP_CONSOLE_UART_BAUDRATE
#define CONFIG_CONSOLE_UART_CUSTOM CONFIG_ESP_CONSOLE_UART_CUSTOM
#define CONFIG_CONSOLE_UART_CUSTOM_NUM_0 CONFIG_ESP_CONSOLE_UART_CUSTOM_NUM_0
#define CONFIG_CONSOLE_UART_NUM CONFIG_ESP_CONSOLE_UART_NUM
#define CONFIG_CONSOLE_UART_RX_GPIO CONFIG_ESP_CONSOLE_UART_RX_GPIO
#define CONFIG_CONSOLE_UART_TX_GPIO CONFIG_ESP_CONSOLE_UART_TX_GPIO
#define CONFIG_ESP32S3_BROWNOUT_DET CONFIG_ESP_BROWNOUT_DET
#define CONFIG_ESP32S3_BROWNOUT_DET_LVL CONFIG_ESP_BROWNOUT_DET_LVL
#define CONFIG_ESP32S3_BROWNOUT_DET_LVL_SEL_7 CONFIG_ESP_BROWNOUT_DET_LVL_SEL_7
#define CONFIG_ESP32S3_DEBUG_OCDAWARE CONFIG_ESP_DEBUG_OCDAWARE
#define CONFIG_ESP32S3_DEEP_SLEEP_WAKEUP_DELAY CONFIG_ESP_SLEEP_DEEP_SLEEP_WAKEUP_DELAY
#define CONFIG_ESP32S3_DEFAULT_CPU_FREQ_160 CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_160
#define CONFIG_ESP32S3_DEFAULT_CPU_FREQ_MHZ CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ
#define CONFIG_ESP32S3_RTC_CLK_CAL_CYCLES CONFIG_RTC_CLK_CAL_CYCLES
#define CONFIG_ESP32S3_RTC_CLK_SRC_INT_RC CONFIG_RTC_CLK_SRC_INT_RC
#define CONFIG_ESP32S3_TIME_SYSCALL_USE_RTC_FRC1 CONFIG_NEWLIB_TIME_SYSCALL_USE_RTC_HRT
#define CONFIG_ESP32S3_TIME_SYSCALL_USE_RTC_SYSTIMER CONFIG_NEWLIB_TIME_SYSCALL_USE_RTC_HRT
#define CONFIG_ESP32_APPTRACE_DEST_NONE CONFIG_APPTRACE_DEST_NONE
#define CONFIG_ESP32_APPTRACE_LOCK_ENABLE CONFIG_APPTRACE_LOCK_ENABLE
#define CONFIG_ESP32_COREDUMP_CHECKSUM_CRC32 CONFIG_ESP_COREDUMP_CHECKSUM_CRC32
#define CONFIG_ESP32_COREDUMP_DATA_FORMAT_ELF CONFIG_ESP_COREDUMP_DATA_FORMAT_ELF
#define CONFIG_ESP32_CORE_DUMP_DECODE CONFIG_ESP_COREDUMP_DECODE
#define CONFIG_ESP32_CORE_DUMP_DECODE_INFO CONFIG_ESP_COREDUMP_DECODE_INFO
#define CONFIG_ESP32_CORE_DUMP_MAX_TASKS_NUM CONFIG_ESP_COREDUMP_MAX_TASKS_NUM
#define CONFIG_ESP32_CORE_DUMP_STACK_SIZE CONFIG_ESP_COREDUMP_STACK_SIZE
#define CONFIG_ESP32_CORE_DUMP_UART_DELAY CONFIG_ESP_COREDUMP_UART_DELAY
#define CONFIG_ESP32_DEBUG_STUBS_ENABLE CONFIG_ESP_DEBUG_STUBS_ENABLE
#define CONFIG_ESP32_DEFAULT_PTHREAD_CORE_NO_AFFINITY CONFIG_PTHREAD_DEFAULT_CORE_NO_AFFINITY
#define CONFIG_ESP32_ENABLE_COREDUMP CONFIG_ESP_COREDUMP_ENABLE
#define CONFIG_ESP32_ENABLE_COREDUMP_TO_UART CONFIG_ESP_COREDUMP_ENABLE_TO_UART
#define CONFIG_ESP32_PHY_CALIBRATION_AND_DATA_STORAGE CONFIG_ESP_PHY_CALIBRATION_AND_DATA_STORAGE
#define CONFIG_ESP32_PHY_MAX_TX_POWER CONFIG_ESP_PHY_MAX_TX_POWER
#define CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER CONFIG_ESP_PHY_MAX_WIFI_TX_POWER
#define CONFIG_ESP32_PTHREAD_STACK_MIN CONFIG_PTHREAD_STACK_MIN
#define CONFIG_ESP32_PTHREAD_TASK_CORE_DEFAULT CONFIG_PTHREAD_TASK_CORE_DEFAULT
#define CONFIG_ESP32_PTHREAD_TASK_NAME_DEFAULT CONFIG_PTHREAD_TASK_NAME_DEFAULT
#define CONFIG_ESP32_PTHREAD_TASK_PRIO_DEFAULT CONFIG_PTHREAD_TASK_PRIO_DEFAULT
#define CONFIG_ESP32_PTHREAD_TASK_STACK_SIZE_DEFAULT CONFIG_PTHREAD_TASK_STACK_SIZE_DEFAULT
#define CONFIG_ESP32_REDUCE_PHY_TX_POWER CONFIG_ESP_PHY_REDUCE_TX_POWER
#define CONFIG_ESP_GRATUITOUS_ARP CONFIG_LWIP_ESP_GRATUITOUS_ARP
#define CONFIG_ESP_SYSTEM_PM_POWER_DOWN_CPU CONFIG_PM_POWER_DOWN_CPU_IN_LIGHT_SLEEP
#define CONFIG_GARP_TMR_INTERVAL CONFIG_LWIP_GARP_TMR_INTERVAL
#define CONFIG_IPC_TASK_STACK_SIZE CONFIG_ESP_IPC_TASK_STACK_SIZE
#define CONFIG_LOG_BOOTLOADER_LEVEL CONFIG_BOOTLOADER_LOG_LEVEL
#define CONFIG_LOG_BOOTLOADER_LEVEL_VERBOSE CONFIG_BOOTLOADER_LOG_LEVEL_VERBOSE
#define CONFIG_MAIN_TASK_STACK_SIZE CONFIG_ESP_MAIN_TASK_STACK_SIZE
#define CONFIG_MONITOR_BAUD CONFIG_ESPTOOLPY_MONITOR_BAUD
#define CONFIG_NIMBLE_ACL_BUF_COUNT CONFIG_BT_NIMBLE_ACL_BUF_COUNT
#define CONFIG_NIMBLE_ACL_BUF_SIZE CONFIG_BT_NIMBLE_ACL_BUF_SIZE
#define CONFIG_NIMBLE_ATT_PREFERRED_MTU CONFIG_BT_NIMBLE_ATT_PREFERRED_MTU
#define CONFIG_NIMBLE_CRYPTO_STACK_MBEDTLS CONFIG_BT_NIMBLE_CRYPTO_STACK_MBEDTLS
#define CONFIG_NIMBLE_ENABLED CONFIG_BT_NIMBLE_ENABLED
#define CONFIG_NIMBLE_GAP_DEVICE_NAME_MAX_LEN CONFIG_BT_NIMBLE_GAP_DEVICE_NAME_MAX_LEN
#define CONFIG_NIMBLE_HCI_EVT_BUF_SIZE CONFIG_BT_NIMBLE_HCI_EVT_BUF_SIZE
#define CONFIG_NIMBLE_HCI_EVT_HI_BUF_COUNT CONFIG_BT_NIMBLE_HCI_EVT_HI_BUF_COUNT
#define CONFIG_NIMBLE_HCI_EVT_LO_BUF_COUNT CONFIG_BT_NIMBLE_HCI_EVT_LO_BUF_COUNT
#define CONFIG_NIMBLE_L2CAP_COC_MAX_NUM CONFIG_BT_NIMBLE_L2CAP_COC_MAX_NUM
#define CONFIG_NIMBLE_MAX_BONDS CONFIG_BT_NIMBLE_MAX_BONDS
#define CONFIG_NIMBLE_MAX_CCCDS CONFIG_BT_NIMBLE_MAX_CCCDS
#define CONFIG_NIMBLE_MAX_CONNECTIONS CONFIG_BT_NIMBLE_MAX_CONNECTIONS
#define CONFIG_NIMBLE_MEM_ALLOC_MODE_INTERNAL CONFIG_BT_NIMBLE_MEM_ALLOC_MODE_INTERNAL
#define CONFIG_NIMBLE_PINNED_TO_CORE CONFIG_BT_NIMBLE_PINNED_TO_CORE
#define CONFIG_NIMBLE_PINNED_TO_CORE_0 CONFIG_BT_NIMBLE_PINNED_TO_CORE_0
#define CONFIG_NIMBLE_ROLE_BROADCASTER CONFIG_BT_NIMBLE_ROLE_BROADCASTER
#define CONFIG_NIMBLE_ROLE_CENTRAL CONFIG_BT_NIMBLE_ROLE_CENTRAL
#define CONFIG_NIMBLE_ROLE_OBSERVER CONFIG_BT_NIMBLE_ROLE_OBSERVER
#define CONFIG_NIMBLE_ROLE_PERIPHERAL CONFIG_BT_NIMBLE_ROLE_PERIPHERAL
#define CONFIG_NIMBLE_RPA_TIMEOUT CONFIG_BT_NIMBLE_RPA_TIMEOUT
#define CONFIG_NIMBLE_SM_LEGACY CONFIG_BT_NIMBLE_SM_LEGACY
#define CONFIG_NIMBLE_SM_SC CONFIG_BT_NIMBLE_SM_SC
#define CONFIG_NIMBLE_SVC_GAP_APPEARANCE CONFIG_BT_NIMBLE_SVC_GAP_APPEARANCE
#define CONFIG_NIMBLE_SVC_GAP_DEVICE_NAME CONFIG_BT_NIMBLE_SVC_GAP_DEVICE_NAME
#define CONFIG_NIMBLE_TASK_STACK_SIZE CONFIG_BT_NIMBLE_HOST_TASK_STACK_SIZE
#define CONFIG_OPTIMIZATION_ASSERTIONS_ENABLED CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_ENABLE
#define CONFIG_OPTIMIZATION_ASSERTION_LEVEL CONFIG_COMPILER_OPTIMIZATION_ASSERTION_LEVEL
#define CONFIG_OPTIMIZATION_LEVEL_RELEASE CONFIG_COMPILER_OPTIMIZATION_SIZE
#define CONFIG_POST_EVENTS_FROM_IRAM_ISR CONFIG_ESP_EVENT_POST_FROM_IRAM_ISR
#define CONFIG_POST_EVENTS_FROM_ISR CONFIG_ESP_EVENT_POST_FROM_ISR
#define CONFIG_REDUCE_PHY_TX_POWER CONFIG_ESP_PHY_REDUCE_TX_POWER
#define CONFIG_SEMIHOSTFS_MAX_MOUNT_POINTS CONFIG_VFS_SEMIHOSTFS_MAX_MOUNT_POINTS
#define CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORTS CONFIG_SPI_FLASH_DANGEROUS_WRITE_ABORTS
#define CONFIG_STACK_CHECK_NONE CONFIG_COMPILER_STACK_CHECK_MODE_NONE
#define CONFIG_SUPPORT_TERMIOS CONFIG_VFS_SUPPORT_TERMIOS
#define CONFIG_SUPPRESS_SELECT_DEBUG_OUTPUT CONFIG_VFS_SUPPRESS_SELECT_DEBUG_OUTPUT
#define CONFIG_SW_COEXIST_ENABLE CONFIG_ESP32_WIFI_SW_COEXIST_ENABLE
#define CONFIG_SYSTEM_EVENT_QUEUE_SIZE CONFIG_ESP_SYSTEM_EVENT_QUEUE_SIZE
#define CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE CONFIG_ESP_SYSTEM_EVENT_TASK_STACK_SIZE
#define CONFIG_TCPIP_RECVMBOX_SIZE CONFIG_LWIP_TCPIP_RECVMBOX_SIZE
#define CONFIG_TCPIP_TASK_AFFINITY CONFIG_LWIP_TCPIP_TASK_AFFINITY
#define CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY CONFIG_LWIP_TCPIP_TASK_AFFINITY_NO_AFFINITY
#define CONFIG_TCPIP_TASK_STACK_SIZE CONFIG_LWIP_TCPIP_TASK_STACK_SIZE
#define CONFIG_TCP_MAXRTX CONFIG_LWIP_TCP_MAXRTX
#define CONFIG_TCP_MSL CONFIG_LWIP_TCP_MSL
#define CONFIG_TCP_MSS CONFIG_LWIP_TCP_MSS
#define CONFIG_TCP_OVERSIZE_MSS CONFIG_LWIP_TCP_OVERSIZE_MSS
#define CONFIG_TCP_QUEUE_OOSEQ CONFIG_LWIP_TCP_QUEUE_OOSEQ
#define CONFIG_TCP_RECVMBOX_SIZE CONFIG_LWIP_TCP_RECVMBOX_SIZE
#define CONFIG_TCP_SND_BUF_DEFAULT CONFIG_LWIP_TCP_SND_BUF_DEFAULT
#define CONFIG_TCP_SYNMAXRTX CONFIG_LWIP_TCP_SYNMAXRTX
#define CONFIG_TCP_WND_DEFAULT CONFIG_LWIP_TCP_WND_DEFAULT
#define CONFIG_TIMER_QUEUE_LENGTH CONFIG_FREERTOS_TIMER_QUEUE_LENGTH
#define CONFIG_TIMER_TASK_PRIORITY CONFIG_FREERTOS_TIMER_TASK_PRIORITY
#define CONFIG_TIMER_TASK_STACK_DEPTH CONFIG_FREERTOS_TIMER_TASK_STACK_DEPTH
#define CONFIG_TIMER_TASK_STACK_SIZE CONFIG_ESP_TIMER_TASK_STACK_SIZE
#define CONFIG_UDP_RECVMBOX_SIZE CONFIG_LWIP_UDP_RECVMBOX_SIZE
It cannot connect to WPA2-AES's AP, the error logs as below:
[19:32:00]I (20034) wifi:flush txq
[19:32:00]D (00:00:18.834) esp_netif_lwip: call api in lwip: ret=0x5002, give sem
[19:32:00]I (20064) wifi:stop sw txq
[19:32:00]D (20064) wifi:filter: set rx policy=0
[19:32:00]I (20074) wifi:lmac stop hw txq
[19:32:00]V (00:00:18.861) esp_adapter: thread sem get: sem=0x3fcbe884
[19:32:00]V (00:00:18.862) esp_adapter: thread sem get: sem=0x3fcbe884
[19:32:00]D (20084) wifi:clear blacklist
[19:32:00]V (00:00:18.874) esp_adapter: thread sem get: sem=0x3fcbe884
[19:32:00]V (20094) wifi:ht20 freq=2412, chan=1
[19:32:00]D (20094) wifi:filter: set rx policy=0
[19:32:00]I (20104) wifi:mode : sta (68:b6:b3:3c:d6:7c)
[19:32:00]I (20104) wifi:enable tsf
[19:32:00]D (20104) wifi:filter: set rx policy=1
[19:32:00]D (20104) wifi:connect status 0 -> 0
[19:32:00]D (00:00:18.892) event: running post WIFI_EVENT:2 with handler 0x4205b85c and context 0x3fcaf5e4 on loop 0x3fcae684
[19:32:00]V (00:00:18.892) esp_adapter: thread sem get: sem=0x3fcbe884
[19:32:00]V (00:00:18.905) esp_adapter: thread sem get: sem=0x3fcbe778
[19:32:00]D (20134) wifi:Start wifi connect
[19:32:00]D (20134) wifi:connect status 0 -> 0
[19:32:00]D (20144) wifi:connect chan=0
[19:32:00]V (20144) wifi:nvs=0, ssid=6F-S-09-04, channel=255
[19:32:00]V (20144) wifi:ssid=6F-S-09-04 match nvs 0, channel=255
[19:32:00]D (20154) wifi:first chan=1
[19:32:00]D (20154) wifi:connect status 0 -> 1
[19:32:00]D (20154) wifi:filter: set rx policy=3
[19:32:00]D (20164) wifi:clear scan ap list
[19:32:00]D (20174) wifi:start scan: type=0x50f, priority=2, cb=0x4209c06c, arg=0x0, ss_state=0x1, time=20190820, index=0
[19:32:00]V (20174) wifi:inter_channel_timeout: arg=0x0, ss_state=0x1
[19:32:00]D (20184) wifi:perform scan: ss_state=0x9, chan<1,0>, dur<0,120>
[19:32:00]V (20184) wifi:change: chan<1,0>, dur<0,240>
[19:32:00]V (20184) wifi:enter start op, arg=0x3fca41f6
[19:32:00]V (20194) wifi:scan operation: state=0x3, chan<1,0>, arg=0x3fca41f6, status=0
[19:32:00]V (20194) wifi:scan specific ssid=6F-S-09-04
[19:32:00]V (20214) wifi:start max timer
[19:32:00]I (20214) wifi:Set ps type: 1
[19:32:00]
[19:32:00]D (00:00:18.995) event: running post WIFI_EVENT:2 with handler 0x42084ff8 and context 0x3fcebeb4 on loop 0x3fcae684
[19:32:00]D (00:00:19.008) wifi_init_default: wifi_start esp-netif:0x3fcae1dc event-id2
[19:32:00]D (00:00:19.009) wifi_init_default: WIFI mac address: 68 b6 b3 3c d6 7c
[19:32:00]V (00:00:19.021) esp_adapter: thread sem get: sem=0x3fcbe778
[19:32:00]D (00:00:19.023) esp_netif_handlers: esp_netif action has started with netif0x3fcae1dc from event_id=2
[19:32:00]D (00:00:19.035) esp_netif_lwip: check: remote, if=0x3fcae1dc fn=0x42082c38
[19:32:00]
[19:32:00]D (00:00:19.037) esp_netif_lwip: esp_netif_start_api 0x3fcae1dc flags 0x19
[19:32:00]D (00:00:19.048) esp_netif_lwip: esp_netif_get_hostname esp_netif:0x3fcae1dc
[19:32:00]I (00:00:19.060) WLANIF: low_level_init:48 netif 0x3fcae250 mtu 1500
[19:32:00]I (00:00:19.062) LWIP: netif_add:451 netif 0x3fcae250 mtu 1500
[19:32:00]D (00:00:19.073) esp_netif_lwip: check: local, if=0x3fcae1dc fn=0x42083ad8
[19:32:00]
[19:32:00]D (00:00:19.075) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3fcae1dc
[19:32:00]V (00:00:19.087) esp_netif_lwip: esp_netif_is_netif_up esp_netif:0x3fcae1dc
[19:32:00]D (00:00:19.088) esp_netif_lwip: call api in lwip: ret=0x0, give sem
[19:32:00]D (20454) wifi:scan end: arg=0x0, status=0, ss_state=0x3
[19:32:00]D (20454) wifi:perform scan: ss_state=0x9, chan<2,0>, dur<0,120>
[19:32:00]V (20454) wifi:change: chan<2,0>, dur<0,240>
[19:32:00]V (20464) wifi:ht20 freq=2417, chan=2
[19:32:00]V (20464) wifi:enter start op, arg=0x3fca41f6
[19:32:00]V (20464) wifi:scan operation: state=0x3, chan<2,0>, arg=0x3fca41f6, status=0
[19:32:00]V (20474) wifi:scan specific ssid=6F-S-09-04
[19:32:00]V (20474) wifi:start max timer
[19:32:00]D (20714) wifi:scan end: arg=0x0, status=0, ss_state=0x3
[19:32:00]D (20724) wifi:perform scan: ss_state=0x9, chan<3,0>, dur<0,120>
[19:32:00]V (20724) wifi:change: chan<3,0>, dur<0,240>
[19:32:00]V (20734) wifi:ht20 freq=2422, chan=3
[19:32:00]V (20734) wifi:enter start op, arg=0x3fca41f6
[19:32:00]V (20734) wifi:scan operation: state=0x3, chan<3,0>, arg=0x3fca41f6, status=0
[19:32:00]V (20744) wifi:scan specific ssid=6F-S-09-04
[19:32:00]V (20744) wifi:start max timer
[19:32:01]D (20984) wifi:scan end: arg=0x0, status=0, ss_state=0x3
[19:32:01]D (20984) wifi:perform scan: ss_state=0x9, chan<4,0>, dur<0,120>
[19:32:01]V (20994) wifi:change: chan<4,0>, dur<0,240>
[19:32:01]V (21004) wifi:ht20 freq=2427, chan=4
[19:32:01]V (21004) wifi:enter start op, arg=0x3fca41f6
[19:32:01]V (21004) wifi:scan operation: state=0x3, chan<4,0>, arg=0x3fca41f6, status=0
[19:32:01]V (21014) wifi:scan specific ssid=6F-S-09-04
[19:32:01]V (21014) wifi:start max timer
[19:32:01]D (21254) wifi:scan end: arg=0x0, status=0, ss_state=0x3
[19:32:01]D (21254) wifi:perform scan: ss_state=0x9, chan<5,0>, dur<0,120>
[19:32:01]V (21254) wifi:change: chan<5,0>, dur<0,240>
[19:32:01]V (21274) wifi:ht20 freq=2432, chan=5
[19:32:01]V (21274) wifi:enter start op, arg=0x3fca41f6
[19:32:01]V (21274) wifi:scan operation: state=0x3, chan<5,0>, arg=0x3fca41f6, status=0
[19:32:01]V (21284) wifi:scan specific ssid=6F-S-09-04
[19:32:01]V (21284) wifi:start max timer
[19:32:01]D (21524) wifi:scan end: arg=0x0, status=0, ss_state=0x3
[19:32:01]D (21524) wifi:perform scan: ss_state=0x9, chan<6,0>, dur<0,120>
[19:32:01]V (21524) wifi:change: chan<6,0>, dur<0,240>
[19:32:01]V (21534) wifi:ht20 freq=2437, chan=6
[19:32:01]V (21534) wifi:enter start op, arg=0x3fca41f6
[19:32:01]V (21544) wifi:scan operation: state=0x3, chan<6,0>, arg=0x3fca41f6, status=0
[19:32:01]V (21554) wifi:scan specific ssid=6F-S-09-04
[19:32:01]V (21554) wifi:start max timer
[19:32:01]D (21794) wifi:scan end: arg=0x0, status=0, ss_state=0x3
[19:32:01]D (21794) wifi:perform scan: ss_state=0x9, chan<7,0>, dur<0,120>
[19:32:01]V (21794) wifi:change: chan<7,0>, dur<0,240>
[19:32:01]V (21804) wifi:ht20 freq=2442, chan=7
[19:32:01]V (21814) wifi:enter start op, arg=0x3fca41f6
[19:32:01]V (21814) wifi:scan operation: state=0x3, chan<7,0>, arg=0x3fca41f6, status=0
[19:32:01]V (21814) wifi:scan specific ssid=6F-S-09-04
[19:32:01]V (21824) wifi:start max timer
[19:32:02]D (22064) wifi:scan end: arg=0x0, status=0, ss_state=0x3
[19:32:02]D (22064) wifi:perform scan: ss_state=0x9, chan<8,0>, dur<0,120>
[19:32:02]V (22064) wifi:change: chan<8,0>, dur<0,240>
[19:32:02]V (22074) wifi:ht20 freq=2447, chan=8
[19:32:02]V (22074) wifi:enter start op, arg=0x3fca41f6
[19:32:02]V (22084) wifi:scan operation: state=0x3, chan<8,0>, arg=0x3fca41f6, status=0
[19:32:02]V (22094) wifi:scan specific ssid=6F-S-09-04
[19:32:02]V (22094) wifi:start max timer
[19:32:02]D (22334) wifi:scan end: arg=0x0, status=0, ss_state=0x3
[19:32:02]D (22334) wifi:perform scan: ss_state=0x9, chan<9,0>, dur<0,120>
[19:32:02]V (22334) wifi:change: chan<9,0>, dur<0,240>
[19:32:02]V (22344) wifi:ht20 freq=2452, chan=9
[19:32:02]V (22344) wifi:enter start op, arg=0x3fca41f6
[19:32:02]V (22354) wifi:scan operation: state=0x3, chan<9,0>, arg=0x3fca41f6, status=0
[19:32:02]V (22364) wifi:scan specific ssid=6F-S-09-04
[19:32:02]V (22364) wifi:start max timer
[19:32:02]D (22604) wifi:scan end: arg=0x0, status=0, ss_state=0x3
[19:32:02]D (22604) wifi:perform scan: ss_state=0x9, chan<10,0>, dur<0,120>
[19:32:02]V (22604) wifi:change: chan<10,0>, dur<0,240>
[19:32:02]V (22614) wifi:ht20 freq=2457, chan=10
[19:32:02]V (22614) wifi:enter start op, arg=0x3fca41f6
[19:32:02]V (22614) wifi:scan operation: state=0x3, chan<10,0>, arg=0x3fca41f6, status=0
[19:32:02]V (22634) wifi:scan specific ssid=6F-S-09-04
[19:32:02]V (22634) wifi:start max timer
[19:32:02]I (00:00:21.533) TKL_LOG: [01-01 08:00:20 ty D][tuya_devos_health.c:70] feed watchdog
[19:32:02]
[19:32:02]D (22874) wifi:scan end: arg=0x0, status=0, ss_state=0x3
[19:32:02]D (22874) wifi:perform scan: ss_state=0x9, chan<11,0>, dur<0,120>
[19:32:03]V (22874) wifi:change: chan<11,0>, dur<0,240>
[19:32:03]V (22884) wifi:ht20 freq=2462, chan=11
[19:32:03]V (22884) wifi:enter start op, arg=0x3fca41f6
[19:32:03]V (22884) wifi:scan operation: state=0x3, chan<11,0>, arg=0x3fca41f6, status=0
[19:32:03]V (22904) wifi:scan specific ssid=6F-S-09-04
[19:32:03]V (22904) wifi:start max timer
[19:32:03]D (22914) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
[19:32:03]
[19:32:03]
[19:32:03]D (23014) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
[19:32:03]
[19:32:03]D (23114) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
[19:32:03]
[19:32:03]D (23144) wifi:scan end: arg=0x0, status=0, ss_state=0x3
[19:32:03]V (23144) wifi:back home chan=<1,0>, current chan=<11,0>
[19:32:03]V (23144) wifi:ht20 freq=2412, chan=1
[19:32:03]D (23144) wifi:filter: set rx policy=4
[19:32:03]D (23154) wifi:first chan=1
[19:32:03]V (23154) wifi:scan_done: arg=0x0, status=0, cur_time=23176564, scan_id=128, scan state=0
[19:32:03]V (23164) wifi:call scan_done cb, arg=0x0
[19:32:03]D (23164) wifi:handoff_cb: status=0
[19:32:03]D (23174) wifi:clear rc list
[19:32:03]D (23174) wifi:clear blacklist
[19:32:03]D (23174) wifi:send disconnect event
[19:32:03]D (23184) wifi:connect status 1 -> 3
[19:32:03]D (23184) wifi:disable connect timer
[19:32:03]D (23184) wifi:clear scan ap list
[19:32:03]D (00:00:21.968) event: running post WIFI_EVENT:5 with handler 0x4205b85c and context 0x3fcaf7c4 on loop 0x3fcae684
ESP32S3 ESP-IDF5.0 WPA3-Personal cannot work
Users browsing this forum: ESP_Sprite and 170 guests
