I'am using Arduino IDE 1.8.19 and ESP32 dev board 4MB.
with ESP32 arduino core 2.0.5 the size of my sketch was 1 945 673 Bytes
But with the new ESP32 arduino core 2.0.6 the size has grown to 1 977 001 Bytes.
the max size with 'minimal spiffs' is 1 966 080 Bytes, so I can't flash the sketch.
I created this 'partitions.csv'
nvs, data, nvs, 0x9000, 0x5000,
otadata, data, ota, 0xe000, 0x2000,
app0, app, ota_0, 0x10000, 0x1F0000,
app1, app, ota_1, 0x200000,0x1F0000,
spiffs, data, spiffs, 0x3F0000,0x10000,
I saved this file next to the .ino file and named it 'partitions.csv'
In the AppData\\Local\\Temp\\arduino_build_xxxxxx the partitions.csv is the good one (2 097 152 Bytes expected).
but when complilation is done the maximum size is always the same (1 966 080 Bytes).
Can you help me?
Partitions.csv not taken into account
Re: Partitions.csv not taken into account
I found the answer.
There is a limitation associated to 'Minimal SPIFFS' in 'boards.txt'
If I use 'Huge APP' and my own 'partitions.csv' it's working perfectly
But I don't understand why the limitation of 'boards.txt' is used while I define my own partitions
Users browsing this forum: Baidu [Spider], maaamc and 115 guests
