OTA on ESP32-S3, working with WiFi but not ethernet?
mowglihaha
Postby mowglihaha » Mon Mar 20, 2023 7:53 am
Hello, i have made a webserver running on the ESP32-S3, where i can update firmware. It works if i configure the device to start a softAP(WiFi). If i configure the device to run as ethernet through USB, as RNDIS device. It does not work ?
Do some have experience or knowledge within this ?
Here are some of the transmit and recieve in the USB part :
bool tud_network_recv_cb(const uint8_t *src, uint16_t size) {
	if (src == NULL) {
		ESP_LOGE(TAG, "Invalid source pointer");
		return false;
	if (size == 0) {
		ESP_LOGE(TAG, "Invalid data size: %d", size);
		return false;
	if (tud_rx_len < 1) {
		memcpy(tud_rx_buf, src, size);
		tud_rx_len = size; //set tud_rx_len ONLY after finish copying
		// "Give" the semaphore, signalling that data was received:
		xSemaphoreGive(tud_data_recd_sem);
		return true;
	}else{
		//unable to receive, busy
		ESP_LOGW(TAG, "tud_network_recv_cb busy.");
		return false;
static void task(void *arg){
	esp_netif_t *netif = (esp_netif_t *) arg;
	size_t hs;
	while(1){
		/* Try and "take" the semaphore. This task will "sleep" until either the
		           semaphore is "given" by another task/ISR or the timeout (e.g. 10000ms) elapses. */
		if ( xSemaphoreTake(tud_data_recd_sem, 10000 / portTICK_PERIOD_MS) == pdTRUE ) {
			// Data was received!
			if (tud_rx_len > 0){
				esp_netif_receive(netif, tud_rx_buf, tud_rx_len, NULL);
				//ESP_LOGI(TAG,"%x, %x, %x, %x, %x, %x, %x, %x",tud_rx_buf[0],tud_rx_buf[1],tud_rx_buf[2],tud_rx_buf[3],tud_rx_buf[4], tud_rx_buf[5], tud_rx_buf[6], tud_rx_buf[7]);
				tud_network_recv_renew();
				tud_rx_len = 0; //indicate buf is now read
				hs = xPortGetFreeHeapSize();
				//ESP_LOGI(TAG, "rx heap check (%u).", hs);
			// Semaphore take timed out after 10000ms, i.e. no data received within 10000ms. Do we care?
			ESP_LOGI(TAG, "no data received in the last 10s, will continue to wait.");
static esp_err_t netsuite_io_transmit(void *h, void *buffer, size_t len) {
	for (;;) {
		if (!tud_ready()) {
			return ESP_FAIL;
		if (tud_network_can_xmit()) {
			struct pbuf *p = pbuf_alloc(PBUF_RAW, len, PBUF_POOL);
			if (p) {
				memcpy(p->payload, buffer, len);
				tud_network_xmit(p, 0);
				pbuf_free(p);
				return ESP_OK;
				return ESP_FAIL;
Users browsing this forum: No registered users and 118 guests
