Many Problems : ESP32 communicate to RC522 with SPI
yang278851511
Postby yang278851511 » Tue Oct 10, 2017 11:21 am
Recent time ,I use ESP32 communicate with RC522,but ,I have a very serious problem abaut it !!
I use the SPI master examples to modify my code,and Compiled success.But when I write a byte to the RC522'register,Then,I read it,I found that the value I wrote is inconsistent with the value I read ,I think my spi communicate must be many problem,here are my code ,please help me to make it work.
SPI Connectors
#define PIN_NUM_MISO GPIO_NUM_25
#define PIN_NUM_MOSI GPIO_NUM_23
#define PIN_NUM_CLK  GPIO_NUM_19
#define PIN_NUM_CS   GPIO_NUM_22
#define PIN_NUM_RST  GPIO_NUM_18
GPIO init
	GPIO_input_init(PIN_NUM_MISO);
	GPIO_output_init(PIN_NUM_MOSI);
	GPIO_output_init(PIN_NUM_CLK);
	GPIO_output_init(PIN_NUM_CS);
	GPIO_output_init(PIN_NUM_RST);
	gpio_set_direction(PIN_NUM_MISO, GPIO_MODE_INPUT);
	gpio_set_pull_mode(PIN_NUM_MISO, GPIO_PULLUP_ONLY);
SPI init
spi_device_handle_t spi;
    spi_bus_config_t buscfg={
        .miso_io_num=PIN_NUM_MISO,
        .mosi_io_num=PIN_NUM_MOSI,
        .sclk_io_num=PIN_NUM_CLK,
        .quadwp_io_num=-1,
        .quadhd_io_num=-1,
//		.max_transfer_sz =2048,
    spi_device_interface_config_t devcfg={
    	.command_bits     =0,
		.address_bits     =0,
    	.dummy_bits       =0,
		.mode             =0,        //SPI mode 0
		.duty_cycle_pos   =0,
		.cs_ena_pretrans  =0,
		.cs_ena_posttrans =0,
        .clock_speed_hz   =10*1000*1000,               //Clock out at 10 MHz
        .spics_io_num     =PIN_NUM_CS,               //CS pin
		.flags            =0,
        .queue_size       =1,                          //We want to be able to queue 7 transactions at a time
		.pre_cb           =NULL, 		 //Specify pre-transfer callback to handle D/C line
		.post_cb		  =NULL,
    //Initialize the SPI bus
    ret=spi_bus_initialize(HSPI_HOST, &buscfg, 1);
    ESP_ERROR_CHECK(ret);
    ret=spi_bus_add_device(HSPI_HOST, &devcfg, &spi);
Then I use SPI to read and write,but ,I only need to write one byte to The RC522,at the same time ,I only need to read one byte from the RC522.
RC522 CMD
This code for write same one cmd to RC522
void RC522_cmd(spi_device_handle_t spi, uint8_t cmd)
    esp_err_t ret;
    spi_transaction_t t;
    memset(&t, 0, sizeof(t));           //Zero out the transaction
    t.addr        =0;
    t.cmd         =0;
    t.flags       =0;
    t.length      =8;			  		//Command is 8 bits
    t.rxlength    =8;
    t.tx_buffer   =&cmd;                   //The data is the cmd itself
//    t.user=(void*)0;                    //D/C needs to be set to 0
    ret=spi_device_transmit(spi, &t);   //Transmit!
    assert(ret==ESP_OK);                //Should have had no issues.
RC522 write byte to RC522 ----ONLY one byte is necessary
void RC522_write_byte(spi_device_handle_t spi,uint8_t value)
    esp_err_t ret;
    t.addr        =0;
	t.cmd         =0;
    t.rxlength    =8;
    t.tx_buffer        =&value;             //The data is the cmd itself
    t.flags = SPI_TRANS_USE_TXDATA;
    ESP_ERROR_CHECK(ret);            		//Should have had no issues.
RC522_write_addr_value the code for write the value to a addr,for example :
RC522_write_addr_value(spi,TxAutoReg,0x40);
write 0x40 to the addr of "TxAutoReg"
void RC522_write_addr_value(spi_device_handle_t spi,  uint8_t Address, uint8_t Value)
//	uint8_t   ucAddr=0;
	Address = ((Address<<1)&0x7E);
	RC522_cmd(spi,Address);
	RC522_write_byte(spi,Value);
RC522_read_data ---this code need to read the data from the address
uint8_t RC522_read_data(spi_device_handle_t spi, uint8_t Address)
//	uint8_t rxdata[];
	Address = ((Address<<1)&0x7E)|0x80;
	t.addr        =0;
	t.cmd         =0;
	t.rxlength    =8;
    t.flags = SPI_TRANS_USE_RXDATA;
//    t.user = (void*)0;
    esp_err_t ret = spi_device_transmit(spi, &t);
    assert( ret == ESP_OK );
   return *(uint8_t*) t.rx_data;
above is the main code ,but when I write a byte to the addr,and then read it,I found it is wrong!!!
printf("read TxAutoReg 0 value = %08x \n",RC522_read_data(spi,TxAutoReg));
I write 0x40,but the read value is "read TxAutoReg 0 value = 00000000"
hear are some info for RC522
https://wenku.baidu.com/view/6c881266d ... afb4.html
I have no ways to solve this problems ,please help me ,thank you very much !!
kolban
Re: Many Problems : ESP32 communicate to RC522 with SPI
Postby kolban » Sun Nov 19, 2017 4:16 pm
In case it helps, here is an RC522 port that seems to work for me.
https://github.com/nkolban/esp32-snippe ... FRC522.cpp
chegewara
Postby chegewara » Sun Nov 19, 2017 6:52 pm
I think this is the problem:
You need to set rx buffer and ther return that buffer address:
uint8_t data;
t.rx = &data;
return data; // or
return &data; // watever suits you
Or issue may be here:
    esp_err_t ret;
    t.addr        =0;
    t.cmd         =0;
    t.flags       =0;
    t.rxlength    =8;   <--- issue
You are sending command and reading value in one spi transfer, its synchronous transfer, so next transfer when you are trying to read value is reading from nowhere. Best option is to use logic analyzer and see what you read on miso pin in each transfer.
Users browsing this forum: Google [Bot], MicroController and 206 guests
