Download file from presigned url
MaxLink
Postby MaxLink » Fri Apr 28, 2023 10:04 am
I'm trying to download a text-file from a pre-sigend AWS S3 url using the esp http client but I'm running into some issues. With the code-sample appended at the end of the post, I can download the Google logo (the url used), the sequence of events will be something like:
HTTP_EVENT_ON_CONNECTED
HTTP_EVENT_HEADER_SENT
HTTP_EVENT_ON_HEADER
more HTTP_EVENT_ON_HEADER ...
HTTP_EVENT_ON_DATA
more HTTP_EVENT_ON_DATA ...
HTTP_EVENT_ON_FINISH
HTTP_EVENT_DISCONNECTED
While, if I used a pre-signed url for a file on S3 I only get:
HTTP_EVENT_ERROR
I verified both links in Python, and this row works fine for both urls:
requests.get(url, verify=False)
I'm using ESP-IDF 4.4 and I've set the following in the config:
  • Enable ESP-TLS Serve
  • Allow potentially insecure options
  • Skip server certificate verification by default
Anyone who has seen anything similar, has tried downloading from a pre-signed S3 link or has any idea how I can debug this?
BR
Max
esp_err_t _https_event_handle(esp_http_client_event_t *evt) {
    switch(evt->event_id) {
        case HTTP_EVENT_ERROR:
            cout << "HTTP_EVENT_ERROR" << endl;
        case HTTP_EVENT_ON_CONNECTED:
            cout << "HTTP_EVENT_ON_CONNECTED" << endl;
        case HTTP_EVENT_HEADER_SENT:
            cout << "HTTP_EVENT_HEADER_SENT" << endl;
        case HTTP_EVENT_ON_HEADER:
            cout << "HTTP_EVENT_ON_HEADER" << endl;
        case HTTP_EVENT_ON_DATA:
            cout << "HTTP_EVENT_ON_DATA" << endl;
        case HTTP_EVENT_ON_FINISH:
            cout << "HTTP_EVENT_ON_FINISH" << endl;
        case HTTP_EVENT_DISCONNECTED:
            cout << "HTTP_EVENT_DISCONNECTED" << endl;
    return ESP_OK;
void get_data()
    esp_http_client_config_t config = {
        .url = "https://www.google.se/images/branding/googlelogo/2x/googlelogo_light_color_272x92dp.png",
        .cert_pem = NULL,
        .method = HTTP_METHOD_GET,
        .timeout_ms = 10000,
        .event_handler = _https_event_handle,
        .transport_type = HTTP_TRANSPORT_OVER_SSL,
    esp_err_t err = esp_http_client_perform(client);
    esp_http_client_cleanup(client);
MicroController
Re: Download file from presigned url
Postby MicroController » Mon May 01, 2023 3:54 pm
Well, how about starting by logging what error is reported?
MaxLink
Postby MaxLink » Tue May 02, 2023 6:55 am
That would make a lot of sense, yes. Sadly I've done this, just a while ago so I forgot to include it in the post, sorry for that. The error from esp_http_client_perform is just a generic -1.The data in esp_http_client_event_t has length 0. So I am assuming that means no information, but I haven't found any example for how you could get additional error info from the event. And the struct seem to only have id, data, user-data and header(only for header event). Or is there a way of getting something more out of it?
MicroController
Postby MicroController » Sat May 06, 2023 11:40 am
Dharanesh
Postby Dharanesh » Thu Mar 28, 2024 6:28 am
how do you read that file after download!!!!!!!!!!!!
currently am using ESP32c6 with ESP IDF v5.2.1
  1. I (66530) avr: HTTP_EVENT_ON_DATA, len=512
  2. I (66540) avr: HTTP_EVENT_ON_DATA, len=512
  3. I (66540) avr: HTTP_EVENT_ON_DATA, len=512
  4. I (66550) avr: HTTP_EVENT_ON_DATA, len=512
  5. I (66550) avr: HTTP_EVENT_ON_DATA, len=512
  6. I (66560) avr: HTTP_EVENT_ON_DATA, len=512
  7. I (66560) avr: HTTP_EVENT_ON_DATA, len=33
  8. I (66570) avr: HTTP_EVENT_ON_FINISH
  9. I (66570) avr: HTTP_EVENT_HEADER_SENT
i think i download the file but i can't read that file
from s3 bucket i upload the direct bin file of the AVR firmware and i also check the storage.bin (copy that file while build )
here is the way i tried
  1.     uint8_t buffer[BUF_SIZE];
  2.     esp_http_client_config_t config = {
  3.         .url = "",
  4. #ifdef CONFIG_EXAMPLE_USE_CERT_BUNDLE
  5.         .crt_bundle_attach = esp_crt_bundle_attach,
  6. #else
  7.     // .cert_pem = (char *)server_cert_pem_start,
  8. #endif /* CONFIG_EXAMPLE_USE_CERT_BUNDLE */
  9.         // .event_handler = _https_event_handle,
  10.         .keep_alive_enable = true,
  11. #ifdef CONFIG_EXAMPLE_FIRMWARE_UPGRADE_BIND_IF
  12.         .if_name = &ifr,
  13. #endif
  14.     };
  15.
  16.     char url_buffer[MAX_URL_LEN];
  17.     // snprintf(url_buffer, MAX_URL_LEN, "%s%s%s%s%s%s",OTA_URL, ENVIRONMENT,VARIANT,GLASS_MM,AVR_MCU, avr_ota_version);
  18.     snprintf(url_buffer, MAX_URL_LEN, "%s%s%s%s%s%s",OTA_URL, ENVIRONMENT,VARIANT,GLASS_MM,AVR_MCU, "/storage.bin");
  19.     config.url = (const char *)malloc(strlen(url_buffer) + 1);
  20.     if (config.url != NULL) {
  21.         strcpy((char *)config.url, url_buffer);
  22.         ESP_LOGI("OTA", "%s", config.url);
  23.     }
  24.     config.method = HTTP_METHOD_GET;
  25.     config.timeout_ms = 10000;
  26.     config.event_handler = _https_event_handle;
  27.     config.transport_type = HTTP_TRANSPORT_OVER_SSL;
  28.
  29.
  30.     ESP_LOGI("hiii", "block 1");
  31.     esp_http_client_handle_t client = esp_http_client_init(&config);
  32.     esp_http_client_perform(client);
  33.     esp_err_t err = esp_http_client_open(client, 0);
  34.     if (err != ESP_OK) {
  35.         ESP_LOGE("avr", "Failed to open HTTP connection (%s)", esp_err_to_name(err));
  36.         esp_http_client_cleanup(client);
  37.     }else{
  38.         ESP_LOGI("avr", "HTTP connection opened");
  39.     }
  40.     ESP_LOGI("hiii", "block 2");
  41.
  42.     char spiff_file[1024];
  43.     snprintf(spiff_file, sizeof(spiff_file), "/firm%s", avr_ota_version);
  44.
  45.     esp_err_t ret;
  46.     size_t total_bytes, used_bytes;
  47.     ret = esp_spiffs_info(spiff_file, &total_bytes, &used_bytes);
  48.     if(ret == ESP_OK){
  49.         printf("File '%s' exists\n", spiff_file);
  50.     }else{
  51.         printf("File '%s' does not exist\n", spiff_file);
  52.     }
  53.
  54.     FILE* file = fopen(spiff_file, "wb");
  55.     if (file == NULL) {
  56.         ESP_LOGE("avr", "Failed to open file for writing");
  57.         esp_http_client_cleanup(client);
  58.     }
  59.
  60.     esp_http_client_fetch_headers(client);
  61.     int content_length = esp_http_client_get_content_length(client);
  62.     if(content_length <= 0){
  63.         printf("Invalid content length\n");
  64.         fclose(file);
  65.         esp_http_client_cleanup(client);
  66.         // return;
  67.     }
AND here is the LOG
  1. I (66560) avr: HTTP_EVENT_ON_DATA, len=512
  2. I (66560) avr: HTTP_EVENT_ON_DATA, len=33
  3. I (66570) avr: HTTP_EVENT_ON_FINISH
  4. I (66570) avr: HTTP_EVENT_HEADER_SENT
  5. I (66570) avr: HTTP connection opened
  6. I (66580) hiii: block 2
  7. File '/firm/io-6s2f-atc6.bin' does not exist
  8. I (66640) avr: HTTP_EVENT_ON_HEADER, key=x-amz-id-2, value=n4WpQ5GZ+2vw9bsdVUQFWff8a3ZSf6HmVDQNRBMfB6QzqE4qDcrvrsMtzIwV91AwYpAJ7/Y3SnE=
  9. I (66640) avr: HTTP_EVENT_ON_HEADER, key=x-amz-request-id, value=FR80R2X9W5H45AVA
  10. I (66650) avr: HTTP_EVENT_ON_HEADER, key=Date, value=Thu, 28 Mar 2024 05:38:14 GMT
  11. I (66660) avr: HTTP_EVENT_ON_HEADER, key=Last-Modified, value=Wed, 27 Mar 2024 11:59:02 GMT
  12. I (66670) avr: HTTP_EVENT_ON_HEADER, key=ETag, value="9c3b7ab01d1b3499844cdcf7904bb98c"
  13. I (66680) avr: HTTP_EVENT_ON_HEADER, key=x-amz-server-side-encryption, value=AES256
  14. I (66690) avr: HTTP_EVENT_ON_HEADER, key=x-amz-meta-sha256, value=6b3eaf7957c9a8c8722307b378ed6f4fc982b08de749b1db4f88e0990a20a47e
  15. I (66700) avr: HTTP_EVENT_ON_HEADER, key=x-amz-meta-s3b-last-modified, value=20240327T115509Z
  16. I (66710) avr: HTTP_EVENT_ON_HEADER, key=Accept-Ranges, value=bytes
  17. I (66710) avr: HTTP_EVENT_ON_HEADER, key=Content-Type, value=application/octet-stream
  18. I (66720) avr: HTTP_EVENT_ON_HEADER, key=Server, value=Ama
  19. I (66730) avr: HTTP_EVENT_ON_HEADER, key=Content-Length, value=983040
  20. I (66740) hiii: block 3
  21. I (66740) hiii: block 4
  22. I (66740) hiii: block 5
  23. I (66740) avr: Reading file /firm/io-6s2f-atc6.bin
  24. I (66750) hiii: block 5.1
  25. File '/firm/io-6s2f-atc6.bin' does not exist
Users browsing this forum: No registered users and 153 guests
