However, when I use the module from another brand B, this problem doesn't appear, anyone can help?
CORRUPT HEAP: multi_heap.c:173 detected at 0x3ffcf03c
abort() was called at PC 0x400882fa on core 0
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0010,len:4
load:0x3fff0014,len:5544
load:0x40078000,len:0
ho 12 tail 0 room 4
load:0x40078000,len:12476
entry 0x40078f74
W (72) rtc_clk: Possibly invalid CONFIG_ESP32_XTAL_FREQ setting (40MHz). Detected 40 MHz.
I (38) boot: ESP-IDF v3.0-dev-806-gde750e99 2nd stage bootloader
I (38) boot: compile time 14:38:03
I (38) boot: Enabling RNG early entropy source...
I (44) boot: SPI Speed : 40MHz
I (48) boot: SPI Mode : DIO
I (52) boot: SPI Flash Size : 4MB
I (56) boot: Partition Table:
I (60) boot: ## Label Usage Type ST Offset Length
I (67) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (75) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (82) boot: 2 factory factory app 00 00 00010000 00100000
I (90) boot: End of partition table
I (94) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x2b2cc (176844) map
I (164) esp_image: segment 1: paddr=0x0003b2f4 vaddr=0x3ffc0000 size=0x0274c ( 10060) load
I (168) esp_image: segment 2: paddr=0x0003da48 vaddr=0x40080000 size=0x00400 ( 1024) load
I (171) esp_image: segment 3: paddr=0x0003de50 vaddr=0x40080400 size=0x021c0 ( 8640) load
I (183) esp_image: segment 4: paddr=0x00040018 vaddr=0x400d0018 size=0x67510 (423184) map
I (335) esp_image: segment 5: paddr=0x000a7530 vaddr=0x400825c0 size=0x0f17c ( 61820) load
I (361) esp_image: segment 6: paddr=0x000b66b4 vaddr=0x400c0000 size=0x00000 ( 0) load
I (371) boot: Loaded app from partition at offset 0x10000
I (371) boot: Disabling RNG early entropy source...
I (373) cpu_start: Pro cpu up.
I (376) cpu_start: Starting app cpu, entry point is 0x40081098
I (0) cpu_start: App cpu up.
I (387) heap_init: Initializing. RAM available for dynamic allocation:
I (393) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (399) heap_init: At 3FFC9F80 len 00016080 (88 KiB): DRAM
I (406) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (412) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (418) heap_init: At 4009173C len 0000E8C4 (58 KiB): IRAM
I (425) cpu_start: Pro cpu start user code
I (107) cpu_start: Starting scheduler on PRO CPU.
I (157) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (447) phy: phy_version: 359.0, e79c19d, Aug 31 2017, 17:06:07, 0, 0
E (477) BT: btc_gattc_call_handler()
I (487) GATTC_DEMO: REG_EVT
I (487) GATTC_DEMO: scan start success
I (597) GATTC_DEMO: 00 03 5b 00 15 10
I (597) GATTC_DEMO: searched Adv Data Len 21, Scan Response Len 0
I (597) GATTC_DEMO: searched Device Name Len 3
I (607) GATTC_DEMO: ESS
I (607) GATTC_DEMO:
I (607) GATTC_DEMO: searched device ESS
I (617) GATTC_DEMO: connect to the remote device.
I (617) GATTC_DEMO: 53 6a 63 f3 d6 aa
I (627) GATTC_DEMO: searched Adv Data Len 14, Scan Response Len 0
I (637) GATTC_DEMO: searched Device Name Len 0
I (637) GATTC_DEMO:
I (647) GATTC_DEMO: stop scan successfully
I (747) GATTC_DEMO: ESP_GATTC_CONNECT_EVT conn_id 0, if 3, status 0
I (747) GATTC_DEMO: REMOTE BDA:
I (747) GATTC_DEMO: 00 03 5b 00 15 10
I (757) GATTC_DEMO: open success
I (1537) GATTC_DEMO: ESP_GATTC_CFG_MTU_EVT, Status 0, MTU 23, conn_id 0
I (1537) GATTC_DEMO: ESP_GATTC_SEARCH_RES_EVT
I (1547) GATTC_DEMO: service found
I (1547) GATTC_DEMO: UUID16: 181a
I (1547) GATTC_DEMO: ESP_GATTC_SEARCH_CMPL_EVT
I (1557) GATTC_DEMO: 6 attributes found
CORRUPT HEAP: multi_heap.c:173 detected at 0x3ffd63b8
abort() was called at PC 0x400882f6 on core 0
Backtrace: 0x40088d28:0x3ffd1250 0x40088e27:0x3ffd1270 0x400882f6:0x3ffd1290 0x400887d5:0x3ffd12b0 0x40082292:0x3ffd12d0 0x400825f1:0x3ffd12f0 0x4000bec7:0x3ffd1310 0x400ec8c1:0x3ffd1330 0x400e75e5:0x3ffd1360 0x400d4340:0x3ffd1390 0x400d40a3:0x3ffd13e0 0x400ecba5:0x3ffd1410 0x400e7a1a:0x3ffd1450
Rebooting...
ho 12 tail 0 room 4
entry 0x40078f74
W (73) rtc_clk: Possibly invalid CONFIG_ESP32_XTAL_FREQ setting (40MHz). Detected 40 MHz.
I (39) boot: ESP-IDF v3.0-dev-806-gde750e99 2nd stage bootloader
I (39) boot: compile time 14:38:03
I (49) boot: Enabling RNG early entropy source...
I (49) boot: SPI Speed : 40MHz
I (49) boot: SPI Mode : DIO
I (53) boot: SPI Flash Size : 4MB
I (57) boot: Partition Table:
I (61) boot: ## Label Usage Type ST Offset Length
I (68) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (83) boot: 2 factory factory app 00 00 00010000 00100000
I (95) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x2b2cc (176844) map
I (165) esp_image: segment 1: paddr=0x0003b2f4 vaddr=0x3ffc0000 size=0x0274c ( 10060) load
I (169) esp_image: segment 2: paddr=0x0003da48 vaddr=0x40080000 size=0x00400 ( 1024) load
I (172) esp_image: segment 3: paddr=0x0003de50 vaddr=0x40080400 size=0x021c0 ( 8640) load
I (184) esp_image: segment 4: paddr=0x00040018 vaddr=0x400d0018 size=0x67510 (423184) map
I (336) esp_image: segment 5: paddr=0x000a7530 vaddr=0x400825c0 size=0x0f17c ( 61820) load
I (362) esp_image: segment 6: paddr=0x000b66b4 vaddr=0x400c0000 size=0x00000 ( 0) load
I (372) boot: Loaded app from partition at offset 0x10000
I (372) boot: Disabling RNG early entropy source...
I (377) cpu_start: Starting app cpu, entry point is 0x40081098
I (394) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (400) heap_init: At 3FFC9F80 len 00016080 (88 KiB): DRAM
I (413) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (419) heap_init: At 4009173C len 0000E8C4 (58 KiB): IRAM
I (158) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (418) phy: phy_version: 359.0, e79c19d, Aug 31 2017, 17:06:07, 0, 0
E (468) BT: btc_gattc_call_handler()
I (468) GATTC_DEMO: REG_EVT
I (478) GATTC_DEMO: scan start success
I (588) GATTC_DEMO: 00 03 5b 00 15 10
I (588) GATTC_DEMO: searched Adv Data Len 21, Scan Response Len 0
I (588) GATTC_DEMO: searched Device Name Len 3
I (588) GATTC_DEMO: ESS
I (598) GATTC_DEMO:
I (598) GATTC_DEMO: searched device ESS
I (598) GATTC_DEMO: connect to the remote device.
I (608) GATTC_DEMO: stop scan successfully
I (988) GATTC_DEMO: ESP_GATTC_CONNECT_EVT conn_id 0, if 3, status 0
I (988) GATTC_DEMO: REMOTE BDA:
I (988) GATTC_DEMO: 00 03 5b 00 15 10
I (988) GATTC_DEMO: open success
I (2168) GATTC_DEMO: ESP_GATTC_CFG_MTU_EVT, Status 0, MTU 23, conn_id 0
I (2168) GATTC_DEMO: ESP_GATTC_SEARCH_RES_EVT
I (2168) GATTC_DEMO: service found
I (2178) GATTC_DEMO: UUID16: 181a
I (2178) GATTC_DEMO: ESP_GATTC_SEARCH_CMPL_EVT
I (2188) GATTC_DEMO: 6 attributes found
I (2188) GATTC_DEMO: Temperature char 2a6e found handle 20 props 2
I (2198) GATTC_DEMO: Cleared char_elem_result memory
Someone reply me in github that the code should be written as thisESP_Angus wrote:OK. It looks like there are some hardware differences, for example one module has revision 0 silicon and the other has revision 1. This is almost certainly not the cause of the bug, but it may change timing around a tiny bit - making it enough to trigger on one module.
Suggest following the steps at the link above to try and get more detail about the corruption.
You can also use "make monitor" or xtensa-esp32-elf-addr2line to decode the backtrace which may give some clues. You can find more about these tools here:
esp-idf.readthedocs.io/en/latest/get-started/idf-monitor.html
(addr2line is mentioned in a comment about half way down the page.)
Are you able to post your code anywhere? Check carefully for anything which may be overflowing a buffer.
char_elem_result = (esp_gattc_char_elem_t *) malloc (sizeof (esp_gattc_char_elem_t) * count);
char_elem_result = (esp_gattc_char_elem_t *)malloc(sizeof(char_elem_result) * count);
Users browsing this forum: No registered users and 140 guests
