Is there any port there is easy to use with ESP8685 chip?
And how?
/Rapzak
ESP8685 micropython port?
Re: ESP8685 micropython port?
You can use Micropython binaries for ESP32-C3. ESP8685 is basically an ESP32-C3 with Flash inside the package. The difference from ESP32-C3F* chip is that the package is smaller. From software perspective these differences don't matter, so ESP32-C3 binaries should work just fine.
I have been trying, but because i have a 2mbyte device, it is not working.
I have tried to copy the generic_c3_usb port and changed it to use the 2mbyte partition table with no luck.
I can start up, but the flash is not working.
/rapzak
/rapzak
I got it working, think the change is correct.
I thought the partition and bootloader was merged into the file, which seems not to be the case.
/rapzak
/rapzak
Users browsing this forum: No registered users and 81 guests
