Does enable_directory_listing works for ESP32 WROVER with SD card. Does Web browser shows list of folders and files.Gfast2 wrote: ↑Mon Nov 06, 2017 7:45 pmHi ESP-IDF,
I just wunder, how to let ESP32 plays like a traditional static webserver?
My goal ist to let Mongoose Webserver access the virtual filesystem of SD card, and fetch the file that the webserver need.
I got this idea from Mongoose's stock example HERE
This is the code snippet that do the magic, and which also not works on my machine:---Code: Select all
mg_set_protocol_http_websocket(nc); s_http_server_opts.document_root = "."; // Serve current directory s_http_server_opts.enable_directory_listing = "yes";
The following is actually another question:
Right now i just specify one task for Webserver, one for SD Card I/O.
It that possible to pass file pointer between tasks? If yes, is that good practise?
Gfast2
How to let webserver access file system of the SD Card
Re: How to let webserver access file system of the SD Card
Thanks, I will check this out when I have the next possibility accessing my dev enviroment in near future!snahmad75 wrote: ↑Wed Nov 28, 2018 11:23 amDoes enable_directory_listing works for ESP32 WROVER with SD card. Does Web browser shows list of folders and files.Gfast2 wrote: ↑Mon Nov 06, 2017 7:45 pmHi ESP-IDF,
Gfast2
Thanks again!
LG
Su
Hi I just brought one of these
https://www.ebay.co.uk/itm/Bluetooth-De ... 2749.l2649
I'm hoping to run a web server on it and access the files in the SD card.
What's the best way of doing this with this hardware in 2019?
<edit> This looks promising is it any good
https://github.com/espressif/arduino-es ... DWebServer
Users browsing this forum: OSCPUDEV and 106 guests
