I2C drivers seems to be corrupting memory
rwel59
Postby rwel59 » Thu Nov 16, 2017 2:08 am
Kind of a strange one that I have been fighting all day. When I perform an operation on bytes read from i2c before shutting i2c down, the bytes get corrupted.
    cmd = i2c_cmd_link_create();
    i2c_master_start(cmd);
    i2c_master_write_byte(cmd, i2c_addr << 1 | READ_BIT, ACK_CHECK_EN);
    i2c_master_read_byte(cmd, &bytes[0], ACK_VAL);
    i2c_master_read_byte(cmd, &bytes[1], NACK_VAL);
    i2c_master_stop(cmd);
    ret = i2c_master_cmd_begin(i2c_num, cmd, 1000 / portTICK_RATE_MS);
    i2c_cmd_link_delete(cmd);
    bytes[0] = bytes[0] & mask;
	if(low_first) data[0] = bytes[1] << 8 | bytes[0];
	else data[0] = bytes[0] << 8 | bytes[1];
And here is a snippet of code that does NOT work - only difference is the order of operations
WiFive
Re: I2C drivers seems to be corrupting memory
Postby WiFive » Thu Nov 16, 2017 2:23 am
i2c_master_read_byte does not actually perform a read until i2c_master_cmd_begin is called
rwel59
Postby rwel59 » Thu Nov 16, 2017 12:51 pm
thanks. I see now. Pulling my hair out over this one.
Users browsing this forum: Bing [Bot], ESP_igrr and 15 guests
