I had posted a while ago about a unique id on the ESP32 for use in authenticating commands.
Using espefuse.py I burnt a key to BLK3 like:
$IDF_PATH/components/esptool_py/esptool/espefuse.py --port /dev/ttyUSB0 burn_key BLK3 blk3_key.bin
Note that I used 'burn_key' because it seemed like the best approach but now the key isn't readable, even by the micro:
BLK1 Flash encryption key
= 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
BLK2 Secure boot key
BLK3 Variable Block 3
= 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -/-
Should I have used 'burn_efuse' instead to avoid READ and WRITE from being cleared?
I'm asking because I only have so many esp-wroom-32 modules here and I'd prefer not to lock myself out of a second one
Can you use BLK3 to store an arbitrary unique id?
Re: Can you use BLK3 to store an arbitrary unique id?
Apparently I should have added '--no-protect-key' at the end of the command! Would be great if that option was documented in the espefuse.py help but I should have read the wiki page more carefully in any case.
I'm going to swap the module out for another one and see how that option works.
Users browsing this forum: No registered users and 167 guests
