I've looked in esp32/include/rom/efuse.h, soc/esp32/include/soc/efuse_reg.h and bootloader_support/src/efuse.c and it isn't immediately obvious how one can determine if an efuse has been burnt.
Is the developer supposed to first check whether the efuse has been read/write protected and then if not either then read the fuse and look for non-zero values or is there an api based way to do this?
How to check if an efuse has been burnt?
Re: How to check if an efuse has been burnt?
We don't have a generic API for this in ESP-IDF, although there are some for particular functions (like secure boot & flash encryption), but they tend to be at the "is this feature enabled?" level rather than anything about the efuses.
"espefuse.py summary" will give you this information when connected to a host, though.
Can you explain the use case you have in mind?
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot] and 249 guests
