All the examples in esp-idf examples folder can not run.(In fact,I have tried many of them....).
Emmm,
Help!The output is strange.
Re: Help!The output is strange.
Are you sure your power supply (or USB lead, in case of a devboard) is good enough? Stuff like this tends to happen when the current draw of the ESP32 makes the input voltage sag too much.
Please check the note about XTAL frequency in the following document:
http://esp-idf.readthedocs.io/en/latest ... #configure
Most ESP32 development boards have a 40MHz crystal installed. However, some boards use a 26MHz crystal. If your board uses a 26MHz crystal, or you get garbage output from serial port after code upload, adjust the ESP32_XTAL_FREQ_SEL option in menuconfig.
Users browsing this forum: Majestic-12 [Bot] and 245 guests
