Using espnow to control a brushless rc car
Nandhesh1
Postby Nandhesh1 » Mon Mar 18, 2024 6:23 am
This the code I am using
#include <esp_now.h>
#include <WiFi.h>
#include <ESP32Servo.h>
#define SIGNAL_TIMEOUT 1000  // This is signal timeout in milli seconds. We will reset the data if no signal
unsigned long lastRecvTime = 0;
typedef struct PacketData
  byte lxAxisValue;
  byte lyAxisValue;
}PacketData;
PacketData receiverData;
Servo servo;
Servo esc;
//Assign default input received values
void setInputDefaultValues()
  // The middle position for joystick. (254/2=127)
  receiverData.lxAxisValue = 127;
  receiverData.lyAxisValue = 127;
void mapAndWriteValues()
  esc.write(map(receiverData.lxAxisValue, 0, 254, 0, 180));
  servo.write(map(receiverData.lyAxisValue, 0, 254, 0, 180));
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len)
  if (len == 0)
    return;
  memcpy(&receiverData, incomingData, sizeof(receiverData));
  String inputData ;
  inputData = inputData + "values " + receiverData.lxAxisValue + "  " + receiverData.lyAxisValue ;
  Serial.println(inputData);
  mapAndWriteValues();
  lastRecvTime = millis();
void setUpPinModes()
  servo.attach(27, 1000, 2000);
  esc.attach(26, 1000, 2000);
  setInputDefaultValues();
void setup()
  setUpPinModes();
  WiFi.mode(WIFI_STA);
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK)
    Serial.println("Error initializing ESP-NOW");
    return;
  esp_now_register_recv_cb(OnDataRecv);
void loop()
  //Check Signal lost.
  unsigned long now = millis();
  if ( now - lastRecvTime > SIGNAL_TIMEOUT )
for the revicer is it okay I am using 50 generic bilateral esc
Users browsing this forum: Google [Bot] and 192 guests
