problem using uart read byte on UART0
voomdisc2
Postby voomdisc2 » Mon Dec 11, 2017 11:44 am
hello everyone
using esp32 on Adafruit HUZZAH32 board.
I want to implement UART0 readbyte using the esp-idf toolchain, and manipulating the example on
[uart rx tx async][https://github.com/espressif/esp-idf/tr ... _rxtxtasks],
to work with UART0 (the UART on the USB bridge).
I get the UART Tx messages, but could NOT detect incoming bytes on the esp32.
any idea what could be the problem?
I will appreciate your help :D
adding here my modified code:
[/* UART asynchronous example, that uses separate RX and TX tasks
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_log.h"
#include "driver/uart.h"
#include "soc/uart_struct.h"
#include "string.h"
static const int RX_BUF_SIZE = 1024;
#define TXD_PIN (GPIO_NUM_4) // GPIO_NUM_4
#define RXD_PIN (GPIO_NUM_5) // GPIO_NUM_5
#define UART_CH (UART_NUM_0)
#define UART_TX_PERIOS_MS (5000)
void init() {
    const uart_config_t uart_config = {
        .baud_rate = 115200,
        .flow_ctrl = UART_HW_FLOWCTRL_DISABLE
    uart_param_config(UART_CH, &uart_config);
    uart_set_pin(UART_CH, TXD_PIN, RXD_PIN, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
    // We won't use a buffer for sending data.
    uart_driver_install(UART_CH, RX_BUF_SIZE * 2, 0, 0, NULL, 0);
    ESP_LOGI("MY_DEBUG:", "Init Uart %d", UART_CH);
int sendData(const char* logName, const char* data)
    const int len = strlen(data);
    const int txBytes = uart_write_bytes(UART_CH, data, len);
    ESP_LOGI(logName, "Wrote voom %d bytes: %s", txBytes, data);
    return txBytes;
static void tx_task()
    static const char *TX_TASK_TAG = "TX_TASK";
    esp_log_level_set(TX_TASK_TAG, ESP_LOG_INFO);
    while (1) {
        sendData(TX_TASK_TAG, "Hello world");
        vTaskDelay(UART_TX_PERIOS_MS / portTICK_PERIOD_MS);
static void rx_task()
    static const char *RX_TASK_TAG = "RX_TASK";
    esp_log_level_set(RX_TASK_TAG, ESP_LOG_INFO);
    uint8_t* data = (uint8_t*) malloc(RX_BUF_SIZE+1);
    ESP_LOGI("MY_DEBUG:", "reading Uart %d", UART_CH);
    while (1) {
        const int rxBytes = uart_read_bytes(UART_CH, data, RX_BUF_SIZE, 1000 / portTICK_RATE_MS);
        if (rxBytes > 0) {
            data[rxBytes] = 0;
            ESP_LOGI(RX_TASK_TAG, "Read %d bytes: '%s'", rxBytes, data);
            ESP_LOG_BUFFER_HEXDUMP(RX_TASK_TAG, data, rxBytes, ESP_LOG_INFO);
    free(data);
void app_main()
    init();
    xTaskCreate(rx_task, "uart_rx_task", 1024*2, NULL, configMAX_PRIORITIES, NULL);
    xTaskCreate(tx_task, "uart_tx_task", 1024*2, NULL, configMAX_PRIORITIES-1, NULL);
Users browsing this forum: aygh4266, Baidu [Spider] and 135 guests
