Sometimes,my system has restart due to watchdog.Debug print can see as below:
rst:0x8 (TG1WDT_SYS_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
So,what would be the reason to reset the system.
Any functions to disable watchdog.
how can disable watchdog
Re: how can disable watchdog
You tried to disable both wdt (INT/TASK) by menuconfig?kishan patel wrote:Hello,
I have checked Menuconfig.
How can i disabled it?
Which key i have to press to remove '*' ?.......
I have attached one image.Please,check it.
- MAKE_MENUCONFIG.png (172.64 KiB) Viewed 15139 times
Arrow keys move around, space selects/deselects.
I suggest, however, that you find out what causes the watchdog to trigger: chances are that with the watchdog disables, you end up with an unresponsive ESP32 instead of a rebooting ESP32.
Okay.
Thanks for reply.
Means if i will find the reason behind triggering watchdog.It is better than disable by menuconfig. Right?.
Thanks for reply.
I wouldn't say 'better'. I would say that is likely the only way to get your program to work.
The watchdog that is resetting its code is the timer (group 1). I advise you to review your code if you are using something with timer's or related
Hello friends,
Now,i am very near about this issue.I am sending you some code and its output so,you can also understand.
If any mistake or something let me check.
void wifi_send_data_kt(char *wifi_data_send)
const struct addrinfo hints = {
.ai_family = AF_INET,
.ai_socktype = SOCK_STREAM,
struct addrinfo *res;
struct in_addr *addr;
int s;
fd_set readfds;
struct timeval tv;
int rv, n;
char recv_buf[550];
memset(response_buffer,'\0',strlen(response_buffer));
xEventGroupWaitBits(wifi_event_group, CONNECTED_BIT,false, true, 6000 / portTICK_PERIOD_MS);
#if (defined WIFI_DEBUG_PRINT) && (defined WIFI_LINK_STATUS)
ESP_LOGI(Display, "Connected to AP");
#endif
int err = getaddrinfo(WEB_SERVER,WEB_PORT, &hints, &res);
if(err == 0 || res != NULL)
addr = &((struct sockaddr_in *)res->ai_addr)->sin_addr;
#if (defined WIFI_DEBUG_PRINT) && (defined WIFI_SERVER_LINK_STATUS)
ESP_LOGI(Display, "DNS lookup succeeded. IP=%s", inet_ntoa(*addr));
#endif
s = socket(res->ai_family, res->ai_socktype, 0);
ESP_LOGI(Display,"\nsocket_id = %d\n",s);
#endif
if(s >= 0)
FD_ZERO(&readfds);
FD_SET(s, &readfds);
n = s + 1;
tv.tv_sec = 2;
tv.tv_usec = 000000;
ESP_LOGI(Display, "... allocated socket\r\n");
#endif
if(connect(s, res->ai_addr, res->ai_addrlen) == 0)
//flags = fcntl(s, F_GETFL, 0);
//fcntl(s, F_SETFL, flags | O_NONBLOCK);
ESP_LOGI(Display, "... connected");
#endif
freeaddrinfo(res);
if (write(s, wifi_data_send, strlen(wifi_data_send)) >= 0)
ESP_LOGI(Display, "... socket send success");
#endif
do{
rv = select(n, &readfds, NULL, NULL, &tv);
ESP_LOGI(Display, "\n\nselect returns= %d\n\n",rv);
#endif
if (rv > 0)
if (FD_ISSET(s, &readfds))
bzero(recv_buf, sizeof(recv_buf));
read(s, recv_buf, sizeof(recv_buf)-1);
strcat(response_buffer,recv_buf);
}while(rv>0);
#if (defined WIFI_DEBUG_PRINT) && (defined WIFI_SERVER_RESPONSE)
ESP_LOGI(Display,"\nresponse_buffer=%s\n",response_buffer);
#endif
//-------check that server has saved client data or not-------//
if(strstr(response_buffer,"data saved"))
server_saved_data_flag = True;
// #ifdef TEST_CASES_INDICATION
indicate_server_communication_done_kt();
// #endif
else
server_saved_data_flag = False;
indicate_server_communication_issue_kt();
#endif
if(strstr(response_buffer,"deactivated"))
ESP_LOGE(Display,"\nsystem is deactivated\n");
#endif
paired_tags_status = DEACTIVATED;
system_software_reset_kt();
else
paired_tags_status = ACTIVATED;
else
indicate_server_communication_issue_to_write_kt();
#endif
server_saved_data_flag = False; // server has been not saved client data
else
indicate_server_connection_issue_kt();
#endif
else
close(s);
else
freeaddrinfo(res);
This is code about the process of sending data to the server.
Before i have not added below line to debug.
#endif
so,when my device was hang then i can read debug print continuously as below:
[0m
[0;3Task watchdog got triggered. The following tasks did not feed the watchdog in time:
Tasks currently running:
CPU 0: main
now,i can see debug print as below:
[0m
CPU 0: main
2mI (9681526) WIFI >> DEBUG-PRINT:
select returns= 1
[0m
[0;32mI (9681543) WIFI >> DEBUG-PRINT:
select returns= 1
[0m
[0;32mI (9681549) WIFI >> DEBUG-PRINT:
select returns= 1
[0m
[0;32mI (9681555) WIFI >> DEBUG-PRINT:
select returns= 1
[0m
[0;32mI (9681562) WIFI >> DEBUG-PRINT:
select returns= 1
Means my device has hanging in this do while loop.
But i have not used TIMER_GROUP1
see my timer code as below:
#define TIMER_GROUP TIMER_GROUP_0
#define TIMER_ID TIMER_0
void timer_init_kt(void)
timer_config_t timer_config;
timer_config.alarm_en = 0;
timer_config.auto_reload = 1;
timer_config.counter_dir = TIMER_COUNT_UP;
timer_config.divider = 16;
timer_config.intr_type = TIMER_INTR_LEVEL;
timer_config.counter_en = TIMER_START;
timer_init(TIMER_GROUP,TIMER_ID,&timer_config);
Please,tell me if any suggestions.
int s;
fd_set readfds;
struct timeval tv;
int rv, n;
char recv_buf[550];
#endif
#endif
#endif
if(s >= 0)
FD_ZERO(&readfds);
n = s + 1;
tv.tv_sec = 2;
#endif
#endif
freeaddrinfo(res);
#endif
do{
#endif
if (rv > 0)
}while(rv>0);
#endif
// #endif
else
#endif
#endif
else
else
#endif
else
#endif
else
close(s);
else
freeaddrinfo(res);
#endif
[0m
CPU 0: main
[0m
CPU 0: main
select returns= 1
[0m
select returns= 1
[0m
select returns= 1
[0m
select returns= 1
[0m
select returns= 1
Users browsing this forum: Baidu [Spider] and 123 guests
