Page 2 of 2
Re: RMT based NeoPixels (WS2812B) flickers when WiFi is used
Posted: Mon Oct 22, 2018 7:34 am
by tltltl
This problem sadly never got resolved.
We tried many different things. We used different pieces of SW, different libraries, different approaches (RMT, separate pinned task, etc).
As far as we could tell, we couldn't make any progress except that some approaches flickered a bit more and some a bit less.
An interesting fact is, that we use multiple identical devices and IF it flickers, it flickers on all of them in the exact and identical pattern. ESP32 rev0 vs rev1 didn't make a difference either.
Also we investigated the signal and we're certain that, the RMT-signal comes out scrambled on the level of ESP. So we're certain that the flickering isn't because of our HW.
We're certain as well that it correlates with WiFi. If not using WiFi we *never* had any issue. If using WiFi (regardless of what: udp, tcp, sta, ap, etc) the issues randomly appears.
I'd really appreciate it, if you could post any news you find along the way - maybe I can try some of your approaches as well and I'm happy to answer any question you may have...:-)
cheers!
Posted: Tue Oct 23, 2018 2:37 am
by ESP_Sprite
Is there any chance you can build a minimal application that shows this issue, so we can reproduce it easily?
Posted: Tue Oct 30, 2018 5:02 pm
by cranphin
Right, I think I actually fixed my problem..
I created the interrupt handler (rmt_driver_install for RMT, digitalLeds_initStrands for the WS2812 library) from the main task (app_main), which apparently defaults to being on core 0. This also makes the interrupt handler being handled on core 0 (as documented on https://docs.espressif.com/projects/esp ... ore-issues).
Changing things so that the interrupt handler is created from core 1 seems to solve my issue! :) Still testing though.
Posted: Sat Dec 08, 2018 11:10 pm
by nokeyboard
Hello!
I have the same issue - ws2812b pixels glitches when wifi transferring data.
I've tried use another core following the advice given by @cranphin but no success.
There is my part of code for leds. It makes simple rainbow effect. And when esp32 transferring data pixels start flickers with wrong colours. I use this lib for pixels: https://github.com/FozzTexx/ws2812-demo.
wifi logic
void strip_init();
void app_main(void) {
    // Initialize NVS
    esp_err_t ret = nvs_flash_init();
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES) {
        ESP_ERROR_CHECK(nvs_flash_erase());
    ESP_ERROR_CHECK( ret );
    wifi_init();
    wifi_remote_control_init();
    strip_init();
#define WS2812_PIN  18
#define LED_COUNT 132            // this is the number of WS2812B leds on the strip
#define delay_ms(ms) vTaskDelay((ms) / portTICK_RATE_MS)
// rgbVal pixels[LED_COUNT];
void rainbow(void *pvParameters)
  const uint8_t anim_step = 10;
  const uint8_t anim_max = 100;
  const uint8_t pixel_count = LED_COUNT; // Number of your "pixels"
  const uint8_t delay = 25; // duration between color changes
  rgbVal color = makeRGBVal(anim_max, 0, 0);
  uint8_t step = 0;
  rgbVal color2 = makeRGBVal(anim_max, 0, 0);
  uint8_t step2 = 0;
  rgbVal *pixels;
  pixels = malloc(sizeof(rgbVal) * pixel_count);
  memset(pixels, 0, sizeof(rgbVal) * pixel_count);
  while (1) {
    color = color2;
    step = step2;
    for (uint8_t i = 0; i < pixel_count; i++) {
      pixels[i] = color;
      if (i == 1) {
        color2 = color;
        step2 = step;
      switch (step) {
      case 0:
        color.g += anim_step;
        if (color.g >= anim_max)
          step++;
        break;
      case 1:
        color.r -= anim_step;
        if (color.r == 0)
          step++;
        break;
      case 2:
        color.b += anim_step;
        if (color.b >= anim_max)
          step++;
        break;
      case 3:
        color.g -= anim_step;
        if (color.g == 0)
          step++;
        break;
      case 4:
        color.r += anim_step;
        if (color.r >= anim_max)
          step++;
        break;
      case 5:
        color.b -= anim_step;
        if (color.b == 0)
          step = 0;
        break;
    ws2812_setColors(pixel_count, pixels);
    delay_ms(delay);
void on_cpu_1(void *pvParameters) {
    printf("Init on CPU 1\n");
    ws2812_init(WS2812_PIN);
    xTaskCreate(rainbow, "ws2812 rainbow demo", 4096, NULL, 10, NULL);
    vTaskDelete(NULL);
void strip_init() {
    printf("Start strip\n");
    nvs_flash_init();
    xTaskCreatePinnedToCore(on_cpu_1, "on_cpu_1", 4096, NULL, 10, NULL, 1);
I'm new to using esp32 and RTOS and I will be grateful for any answer and the more detailed the better.
Thanks!
Posted: Mon Dec 17, 2018 4:54 pm
by cranphin
Hi!
I don't know if it will help, but be mindful that with this line:
The rainbow task might still run on any/either core. So I'd recommend using:
xTaskCreatePinnedToCore(rainbow, "ws2812 rainbow demo", 4096, NULL, 10, NULL, 1);
instead.
Cheers!
Posted: Fri Oct 11, 2019 4:05 pm
by mirronelli
I had the same problem too and after reading a ton of posts have decided not to use wifi directly on the RMT host and instead made it receive commands via serial from another wifi enabled esp board.
this did increase the project costs by about 5 dollars but saved me hours and hours of trying everything possible.
the leds are now flicker free and fast.
there is a sample project for the led driving board as well as for the remote at:
https://github.com/mirronelli/neopixel
feel free to use or extend it
Posted: Tue Nov 05, 2019 7:22 am
by gryphon
I also had a similar problem while driving SK6812 leds with the RMT interface. Root cause for me was that the dynamic frequency scaling being set from 40MHz to 160MHz while RMT was attended to use 80MHz APB clock. When CPU clock dropped to 40MHz the automatic APB divider could not keep up and RMT ref clock dropped also to 40MHz. Setting pm_config.min_freq_mhz = 80 solved my issue.
Posted: Fri Nov 15, 2019 12:54 pm
by fanhuanji
Thanks for reminding, before reading this post, I've checked the data-line(which was directly probed at esp32 output) with oscilloscope and found some of the pulses was obviously wider than others, and that wrong signal caused the WS2812B to display wrong color.
Then I've compared the power management config with another project(which was working fine and finished one years ago).
After DISABLE the POWER MANAGEMENT from menu-config, the problem was gone.
The driver code I'm using for WS2812x series:https://github.com/CalinRadoni/esp32_digitalLEDs
Thank you.
