Problems flashing ESP-32
kartikkman
Postby kartikkman » Wed Jan 03, 2018 12:48 pm
Hi I am working on a project , where I have to flash the Bare ESP-32 using Flasher Tool . No the problem is that when I flash the ESP-32 , it flashes but when I run the "make monitor " command , it only shows garbage value plus ESP-32 is resetting .
I know the program that I am flashing is correct as I have also tried IDF given Examples as well . I am here by attaching the Image of the output :
Could you please help me out in the problem ??
WiFive
Re: Problems flashing ESP-32
Postby WiFive » Wed Jan 03, 2018 1:23 pm
What do you mean bare esp-32? Is it wroom-32 module or custom design?
It seem like crystal problem
kartikkman
Postby kartikkman » Thu Jan 04, 2018 11:03 am
Hii , WiFive thanks for looking into my issue . I found that I was not flashing the bootloader , partition table into esp-32 that's why error occured . I was only flashing the app .
Again a Big Thanks for looking into my issue .
Users browsing this forum: aseemsethi and 25 guests
