Hi All,
So I was reading on the technical ref that there is a 320MHz clock in the ESP, but most sources state that the maximum core frequency is 240MHz.
So question in short: If I provide some sort of heatsink for the ESP32, is it possible to configure the chip for a higher clock frequency, let's say 320MHz?
Also is it possible to use software as "clock throttle" in the ESP, so I can change the clock devider on the fly depending on the needs of the application, so it's only running full clock only when I need it to.
Thanks for the answers.
Ben
Maximum possible CPU clock with heatsink and clock throttling.
- Vader_Mester
- Contact:
task_t coffeeTask()
while(atWork){
coffeeDrink(mug);
vTaskDelete(NULL);
Re: Maximum possible CPU clock with heatsink and clock throttling.
Regarding the first question: the official answer is "not possible". However, the source code of clock selection functions is provided inside rtc_clk.c in rtc component, so feel free to poke there...
Regarding clock throttling: we call this "dynamic frequency scaling", it is explained in http://esp-idf.readthedocs.io/en/latest ... ement.html.
- Vader_Mester
- Contact:
Thanks for the support!
task_t coffeeTask()
while(atWork){
coffeeDrink(mug);
vTaskDelete(NULL);
Users browsing this forum: No registered users and 155 guests
