Remove a connected station
Fugazi
Postby Fugazi » Wed Feb 28, 2018 9:35 pm
Any ideas how to forceably remove a connected wifi station ?
vibnwis
Re: Remove a connected station
Postby vibnwis » Wed Feb 28, 2018 10:09 pm
The following code is not fully tested.
static void stop_wifi(){
esp_wifi_disconnect();
esp_wifi_stop();
esp_wifi_deinit();
Fugazi
Postby Fugazi » Wed Feb 28, 2018 10:41 pm
Thanks, but isnt that to disconnect the esp32 from an access point, not disconnect a station connected to the access point? I want to keep the wifi up on the esp32, just disconnect one of the connected stations
vibnwis
Postby vibnwis » Thu Mar 01, 2018 3:16 am
My application is a webRadio. It connects to an AP. I wanted to stop/remote WiFi completely which I think it is better to start fresh. I don't quite understand your applications and your definition of the term station.
Fugazi
Postby Fugazi » Thu Mar 01, 2018 7:57 am
A station is a device that connects to the esp32 access point on wifi.
Basically theres an issue with the esp32 that if a station connects to it when the wifi is coming up an IP is not assigned and left as 0.0.0.0, if theres 1 second delay and then connect, an ip is assigned.
I wanted to disconnect any station which hasnt been assigned a valid ip, so it will reconnect and be assigned a proper IP.
Just a way around the issue.....
Any other ideas would be appreciated or how to fix the issue !
vibnwis
Postby vibnwis » Thu Mar 01, 2018 8:09 am
The logic I used for my application is reverse the process. If you have an event handler for each connection, then you should able to reverse the process disconnecting it.
Fugazi
Postby Fugazi » Thu Mar 01, 2018 11:43 am
Thank you for the reply, not sure what you mean by reversing the process, thought the event handler notified us of the wifi events?
How do I reverse this and disconnect the station ?
vibnwis
Postby vibnwis » Thu Mar 01, 2018 7:27 pm
Sorry, those are beyond my knowledge. Good luck
kolban
Postby kolban » Mon Mar 12, 2018 8:45 pm
It may be a call to esp_wifi_deauth_sta may be what we seek.
Users browsing this forum: Bing [Bot] and 33 guests
