[solved] why nonstop process paused - no continuous output
Postby rudi ;-) » Thu Nov 17, 2016 11:39 pm
simple code:
This simple example stands for several std outputs
void app_main() {
  uint32_t counts = 0;
  nvs_flash_init();
  /// system_init();
  while (-1) {
     printf("Counter: %10d\r", counts);
     counts++;
paused several tacts -
Output on Youtube
does here work a 'hidden' fill in sendbuffer ?
can we change to "each char" to get continuous output`?
thanks for watching and tips
btw:
nonstop continuous printf output example ESP31 ADC
WiFive
Re: why nonstop process paused - no continuous output
Postby WiFive » Fri Nov 18, 2016 12:29 am
It is still a task and buffers
Postby rudi ;-) » Fri Nov 18, 2016 12:35 am
WiFive wrote:It is still a task and buffers
txs, void app_main is a task?
Can we increase the priority of the app_main ?
or better, can we call app_main with arguments?
WiFive
Postby WiFive » Fri Nov 18, 2016 12:43 am
Why not just make a new task with high priority and pinned to single core if you want.
Postby rudi ;-) » Fri Nov 18, 2016 12:55 am
WiFive wrote:Why not just make a new task with high priority and pinned to single core if you want.
txs - ok - this i have thinked too -- give them a try.
btw:
http://www.esp32.com/viewtopic.php?t=272#p1163
but not sure, we can go higher priority like the caller is ?
btw found this too:
http://www.freertos.org/a00125.html
Postby rudi ;-) » Fri Nov 18, 2016 1:04 am
no change
highest priority
xTaskCreatePinnedToCore(&counter_task, "counter_task", 1024, NULL, configMAX_PRIORITIES - 1, NULL, 0);
Postby rudi ;-) » Fri Nov 18, 2016 1:50 am
this i do not understand,
the 1000 ms delay "buffering" the work on counts
and delay time is much much more in real: ( 6-7 times more )
void app_main() {
  nvs_flash_init();
  /// system_init();
  while (-1) {
     counts++;
i tried the same with new Task too - but no change -
Counter Output with 1000 ms delay Youtube Video
WiFive
Postby WiFive » Fri Nov 18, 2016 2:05 am
Did you try to add fflush(stdout)?
Postby rudi ;-) » Fri Nov 18, 2016 2:31 am
WiFive wrote:Did you try to add fflush(stdout)?
since you cursed me i did not use fflush any more :lol: ,
( remember i used it in the ISR )
but you are right, WiFive, this is the buffer clean trick, and now i go on in this!
have forget the important thing, txs WiFive again!
nice run now YouTube Video
btw i tried this in arduino ide too, - without fflash(stdout) -
youtube video
the same effect only was in buffer fill
the time effect was ok with delay ( 1 )
can we fflush(stdout) in arduino? do you know?
will test ..
txs again!
Postby rudi ;-) » Fri Nov 18, 2016 2:37 am
tried in arduino ide with fflush(stdout);
   Serial.println(counter);
  fflush(stdout);
  counter++;
  delay(1);
this do not change the counting right way.
same like in last video.
i am usually not work in the arduino ide
perhabs i do make wrong code
EDIT:
int counter = 0;
  Serial.print(counter);
  Serial.print('\r');
  fflush(stdout);
  counter++;
  delay(10);
now it is ok in arduino ide too
Users browsing this forum: Google [Bot], ok-home and 193 guests
