What is the data rate of esp_now?Can esp_now be used as a large amount of data transmission?
jason2
Postby jason2 » Fri Mar 16, 2018 2:04 am
ESP-NOW is widely used in smart light, remote controlling, sensor, etc.
According to this sentence,the transmission rate of esp_now is slow.So ,How much is the transmission rate of esp_now?
I just made a little change on the example of esp_now.Each 115200bytes (480 packets, each packet contains 240bytes) statistics tansimission time.The following is my sample code:
/* ESPNOW Example
   This example shows how to use ESPNOW.
   Prepare two device, one for sending ESPNOW data and another for receiving
   ESPNOW data.
#include <stdlib.h>
#include <time.h>
#include <string.h>
#include <assert.h>
#include "freertos/semphr.h"
#include "freertos/timers.h"
#include "nvs_flash.h"
#include "esp_event_loop.h"
#include "tcpip_adapter.h"
#include "esp_wifi.h"
#include "esp_log.h"
#include "esp_system.h"
#include "esp_now.h"
#include "rom/ets_sys.h"
#include "rom/crc.h"
#include "espnow_example.h"
static const char *TAG = "espnow_example";
static xQueueHandle example_espnow_queue;
static uint8_t example_broadcast_mac[ESP_NOW_ETH_ALEN] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
static uint16_t s_example_espnow_seq[EXAMPLE_ESPNOW_DATA_MAX] = { 0, 0 };
struct timeval timestart;
struct timeval timeend;
static void example_espnow_deinit(example_espnow_send_param_t *send_param);
static esp_err_t example_event_handler(void *ctx, system_event_t *event)
    switch(event->event_id) {
    case SYSTEM_EVENT_STA_START:
        ESP_LOGI(TAG, "WiFi started");
    default:
    return ESP_OK;
/* WiFi should start before using ESPNOW */
static void example_wifi_init(void)
    tcpip_adapter_init();
    ESP_ERROR_CHECK( esp_event_loop_init(example_event_handler, NULL) );
    ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
    ESP_ERROR_CHECK( esp_wifi_set_mode(ESPNOW_WIFI_MODE) );
    ESP_ERROR_CHECK( esp_wifi_start());
    /* In order to simplify example, channel is set after WiFi started.
     * This is not necessary in real application if the two devices have
     * been already on the same channel.
    ESP_ERROR_CHECK( esp_wifi_set_channel(CONFIG_ESPNOW_CHANNEL, 0) );
/* ESPNOW sending or receiving callback function is called in WiFi task.
 * Users should not do lengthy operations from this task. Instead, post
 * necessary data to a queue and handle it from a lower priority task. */
static void example_espnow_send_cb(const uint8_t *mac_addr, esp_now_send_status_t status)
    example_espnow_event_t evt;
    example_espnow_event_send_cb_t *send_cb = &evt.info.send_cb;
    if (mac_addr == NULL) {
        ESP_LOGE(TAG, "Send cb arg error");
        return;
    evt.id = EXAMPLE_ESPNOW_SEND_CB;
    memcpy(send_cb->mac_addr, mac_addr, ESP_NOW_ETH_ALEN);
    send_cb->status = status;
    if (xQueueSend(example_espnow_queue, &evt, portMAX_DELAY) != pdTRUE) {
        ESP_LOGW(TAG, "Send send queue fail");
static void example_espnow_recv_cb(const uint8_t *mac_addr, const uint8_t *data, int len)
    example_espnow_event_recv_cb_t *recv_cb = &evt.info.recv_cb;
    if (mac_addr == NULL || data == NULL || len <= 0) {
        ESP_LOGE(TAG, "Receive cb arg error");
        return;
    evt.id = EXAMPLE_ESPNOW_RECV_CB;
    memcpy(recv_cb->mac_addr, mac_addr, ESP_NOW_ETH_ALEN);
    recv_cb->data = malloc(len);
    if (recv_cb->data == NULL) {
        ESP_LOGE(TAG, "Malloc receive data fail");
        return;
    memcpy(recv_cb->data, data, len);
    recv_cb->data_len = len;
        ESP_LOGW(TAG, "Send receive queue fail");
        free(recv_cb->data);
/* Parse received ESPNOW data. */
int example_espnow_data_parse(uint8_t *data, uint16_t data_len, uint8_t *state, uint16_t *seq, int *magic)
    example_espnow_data_t *buf = (example_espnow_data_t *)data;
    uint16_t crc, crc_cal = 0;
    if (data_len < sizeof(example_espnow_data_t)) {
        ESP_LOGE(TAG, "Receive ESPNOW data too short, len:%d", data_len);
        return -1;
    *state = buf->state;
    *seq = buf->seq_num;
    *magic = buf->magic;
    crc = buf->crc;
    buf->crc = 0;
    crc_cal = crc16_le(UINT16_MAX, (uint8_t const *)buf, data_len);
    if (crc_cal == crc) {
        return buf->type;
    return -1;
/* Prepare ESPNOW data to be sent. */
void example_espnow_data_prepare(example_espnow_send_param_t *send_param)
    example_espnow_data_t *buf = (example_espnow_data_t *)send_param->buffer;
    int i = 0;
    assert(send_param->len >= sizeof(example_espnow_data_t));
    buf->type = IS_BROADCAST_ADDR(send_param->dest_mac) ? EXAMPLE_ESPNOW_DATA_BROADCAST : EXAMPLE_ESPNOW_DATA_UNICAST;
    buf->state = send_param->state;
    buf->seq_num = s_example_espnow_seq[buf->type]++;
    buf->crc = 0;
    buf->magic = send_param->magic;
    for (i = 0; i < send_param->len - sizeof(example_espnow_data_t); i++) {
        buf->payload[i] = (uint8_t)esp_random();
    buf->crc = crc16_le(UINT16_MAX, (uint8_t const *)buf, send_param->len);
static void example_espnow_task(void *pvParameter)
    uint8_t recv_state = 0;
    uint16_t recv_seq = 0;
    int recv_magic = 0;
    bool is_broadcast = false;
    int ret;
    vTaskDelay(5000 / portTICK_RATE_MS);
    ESP_LOGI(TAG, "Start sending broadcast data");
    /* Start sending broadcast ESPNOW data. */
    example_espnow_send_param_t *send_param = (example_espnow_send_param_t *)pvParameter;
    if (esp_now_send(send_param->dest_mac, send_param->buffer, send_param->len) != ESP_OK) {
        ESP_LOGE(TAG, "Send error");
        example_espnow_deinit(send_param);
        vTaskDelete(NULL);
    while (xQueueReceive(example_espnow_queue, &evt, portMAX_DELAY) == pdTRUE) {
        switch (evt.id) {
            case EXAMPLE_ESPNOW_SEND_CB:
                is_broadcast = IS_BROADCAST_ADDR(send_cb->mac_addr);
                ESP_LOGD(TAG, "Send data to "MACSTR", status1: %d", MAC2STR(send_cb->mac_addr), send_cb->status);
                if (is_broadcast && (send_param->broadcast == false)) {
                if (!is_broadcast) {
					if(send_param->count == 479)
						gettimeofday(&timestart,NULL);
                    send_param->count--;
                    if (send_param->count == 0) {
						gettimeofday(&timeend,NULL);
						int time_send_pic=(timeend.tv_sec-timestart.tv_sec)*1000+(timeend.tv_usec-timestart.tv_usec)/1000;
						ESP_LOGI(TAG, "send_picture time %dms\n",time_send_pic);
                        ESP_LOGI(TAG, "Send done");
                        vTaskDelete(NULL);
                /* Delay a while before sending the next data. */
                if (send_param->delay > 0) {
                    vTaskDelay(send_param->delay/portTICK_RATE_MS);
             //   ESP_LOGI(TAG, "send data to "MACSTR"", MAC2STR(send_cb->mac_addr));
                memcpy(send_param->dest_mac, send_cb->mac_addr, ESP_NOW_ETH_ALEN);
                example_espnow_data_prepare(send_param);
                /* Send the next data after the previous data is sent. */
                    vTaskDelete(NULL);
            case EXAMPLE_ESPNOW_RECV_CB:
                ret = example_espnow_data_parse(recv_cb->data, recv_cb->data_len, &recv_state, &recv_seq, &recv_magic);
                if (ret == EXAMPLE_ESPNOW_DATA_BROADCAST) {
                   ESP_LOGI(TAG, "Receive %dth broadcast data from: "MACSTR", len: %d", recv_seq, MAC2STR(recv_cb->mac_addr), recv_cb->data_len);
                    /* If MAC address does not exist in peer list, add it to peer list. */
                    if (esp_now_is_peer_exist(recv_cb->mac_addr) == false) {
                        esp_now_peer_info_t *peer = malloc(sizeof(esp_now_peer_info_t));
                        if (peer == NULL) {
                            ESP_LOGE(TAG, "Malloc peer information fail");
                            vTaskDelete(NULL);
                        memset(peer, 0, sizeof(esp_now_peer_info_t));
                        peer->channel = CONFIG_ESPNOW_CHANNEL;
                        peer->ifidx = ESPNOW_WIFI_IF;
                        peer->encrypt = true;
                        memcpy(peer->lmk, CONFIG_ESPNOW_LMK, ESP_NOW_KEY_LEN);
                        memcpy(peer->peer_addr, recv_cb->mac_addr, ESP_NOW_ETH_ALEN);
                        ESP_ERROR_CHECK( esp_now_add_peer(peer) );
                        free(peer);
                    /* Indicates that the device has received broadcast ESPNOW data. */
                    if (send_param->state == 0) {
                        send_param->state = 1;
                    /* If receive broadcast ESPNOW data which indicates that the other device has received
                     * broadcast ESPNOW data and the local magic number is bigger than that in the received
                     * broadcast ESPNOW data, stop sending broadcast ESPNOW data and start sending unicast
                     * ESPNOW data.
                    if (recv_state == 1) {
                        /* The device which has the bigger magic number sends ESPNOW data, the other one
                         * receives ESPNOW data.
                        if (send_param->unicast == false && send_param->magic >= recv_magic) {
                    	    ESP_LOGI(TAG, "Start sending unicast data");
                    	    ESP_LOGI(TAG, "send data to "MACSTR"", MAC2STR(recv_cb->mac_addr));
                    	    /* Start sending unicast ESPNOW data. */
                            memcpy(send_param->dest_mac, recv_cb->mac_addr, ESP_NOW_ETH_ALEN);
                                vTaskDelete(NULL);
                            else {
                                send_param->broadcast = false;
                                send_param->unicast = true;
                else if (ret == EXAMPLE_ESPNOW_DATA_UNICAST) {
                //    ESP_LOGI(TAG, "Receive %dth unicast data from: "MACSTR", len: %d", recv_seq, MAC2STR(recv_cb->mac_addr), recv_cb->data_len);
                    /* If receive unicast ESPNOW data, also stop sending broadcast ESPNOW data. */
                else {
                    ESP_LOGI(TAG, "Receive error data from: "MACSTR"", MAC2STR(recv_cb->mac_addr));
            default:
                ESP_LOGE(TAG, "Callback type error: %d", evt.id);
static esp_err_t example_espnow_init(void)
    example_espnow_send_param_t *send_param;
    example_espnow_queue = xQueueCreate(ESPNOW_QUEUE_SIZE, sizeof(example_espnow_event_t));
    if (example_espnow_queue == NULL) {
        ESP_LOGE(TAG, "Create mutex fail");
        return ESP_FAIL;
    /* Initialize ESPNOW and register sending and receiving callback function. */
    ESP_ERROR_CHECK( esp_now_init() );
    ESP_ERROR_CHECK( esp_now_register_send_cb(example_espnow_send_cb) );
    ESP_ERROR_CHECK( esp_now_register_recv_cb(example_espnow_recv_cb) );
    /* Set primary master key. */
    ESP_ERROR_CHECK( esp_now_set_pmk((uint8_t *)CONFIG_ESPNOW_PMK) );
    /* Add broadcast peer information to peer list. */
    if (peer == NULL) {
        vSemaphoreDelete(example_espnow_queue);
        esp_now_deinit();
        return ESP_FAIL;
    peer->encrypt = false;
    memcpy(peer->peer_addr, example_broadcast_mac, ESP_NOW_ETH_ALEN);
    free(peer);
    /* Initialize sending parameters. */
    send_param = malloc(sizeof(example_espnow_send_param_t));
    memset(send_param, 0, sizeof(example_espnow_send_param_t));
    if (send_param == NULL) {
        ESP_LOGE(TAG, "Malloc send parameter fail");
        esp_now_deinit();
        return ESP_FAIL;
    send_param->unicast = false;
    send_param->broadcast = true;
    send_param->state = 0;
    send_param->magic = esp_random();
    send_param->count = CONFIG_ESPNOW_SEND_COUNT;
    send_param->delay = CONFIG_ESPNOW_SEND_DELAY;
    send_param->len = CONFIG_ESPNOW_SEND_LEN;
    send_param->buffer = malloc(CONFIG_ESPNOW_SEND_LEN);
    if (send_param->buffer == NULL) {
        ESP_LOGE(TAG, "Malloc send buffer fail");
        free(send_param);
        esp_now_deinit();
        return ESP_FAIL;
    memcpy(send_param->dest_mac, example_broadcast_mac, ESP_NOW_ETH_ALEN);
    xTaskCreate(example_espnow_task, "example_espnow_task", 2048, send_param, 15, NULL);
    return ESP_OK;
    free(send_param->buffer);
    free(send_param);
    esp_now_deinit();
void app_main()
    // Initialize NVS
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES) {
        ESP_ERROR_CHECK( nvs_flash_erase() );
    ESP_ERROR_CHECK( ret );
    example_wifi_init();
    example_espnow_init();
According to test,the transimission data rate of esp_now is 460kbps。Is that the max data rate of esp_now,Can it be improved?Can esp_now be used as a large amount of data transmission?
Best wishes?
Vader_Mester
Contact:
Re: What is the data rate of esp_now?Can esp_now be used as a large amount of data transmission?
Postby Vader_Mester » Sun Mar 18, 2018 9:14 am
The ESP Now is not intended to be used with high data rate... however maybe there are ways to do.
It's a MAC layer transmission protocol, which means that the realiability of the data getting through is not guaranteed.
You must experiment with this, to see how fast can you transmit.
Vader[BEN]
task_t coffeeTask()
	while(atWork){
			coffeeDrink(mug);
	vTaskDelete(NULL);
Users browsing this forum: Baidu [Spider] and 102 guests
