Is there any app to upgrade the code by using OTA?
Dear anyone:
I have a project which must upgrad through OTA, so Is there any app or demo to upgrade the code by using OTA?For example, nrf Toolbox is very useful app to upgrade code for NRF51822. And what I need app is like the nrf Toolbox.Thank you.
Best wishes!
Daniel.
Best wishes!
Daniel.
Re: Is there any app to upgrade the code by using OTA?
Hi Daniel,
do you mean just a demo or a app running on smartphone?
If you means just a OTA demo:
is a demo update esp32 from a simple http webserver.
cheers
gfast2
~/esp/esp-idf/examples/system/ota
cheers
gfast2
Dear gfast2Gfast2 wrote:Hi Daniel,
If you means just a OTA demo:is a demo update esp32 from a simple http webserver.Code: Select all
cheers
gfast2
Thank you very much for your reply.The demo does not seem to be so easy to upgrade code as I image.If the customers want to upgrade the program, it's not so convenient.So,Is there a more convenient app running on smartphone ?Thanks.
You can modify demo code a bit and write some client app on android or iPhone that can let user to provide server address and port, path and file name that will be used to OTA update.
This is my OTA example which is based on OTA demo:
https://github.com/chegewara/esp32-ota-with-ble-setup
and this is simple demo app on android that works with esp32 code:
https://play.google.com/store/apps/deta ... 2_ota_demo
(sometimes can be issue to update from this app because all bin images are hosted on my home server)
- Vader_Mester
- Contact:
Maaaaaaaaan this is something I was looking for, for a long time!chegewara wrote:You can modify demo code a bit and write some client app on android or iPhone that can let user to provide server address and port, path and file name that will be used to OTA update.
task_t coffeeTask()
while(atWork){
coffeeDrink(mug);
vTaskDelete(NULL);
Feel free to reuse it, modify or do whatever you want.Vader_Mester wrote: Maaaaaaaaan this is something I was looking for, for a long time!
Thank you very much.That's what I want .You do better than the official.But I can't successfully compile the source code. ,It looks like the file CPPNVS.h is missing .chegewara wrote:You can modify demo code a bit and write some client app on android or iPhone that can let user to provide server address and port, path and file name that will be used to OTA update.
you need to use this library in place components/cpp_utils
https://github.com/nkolban/esp32-snippe ... /cpp_utils
chegewara wrote:Hi,
Thank you very much, although I didn't make it like you said. That is your code not mine.
It does not matter how you do it, the only matter is if it works for you.
Users browsing this forum: No registered users and 100 guests
