Functions to display current tasks and memory usage
Posted: Mon Apr 02, 2018 3:03 am
by rwel59
I thought that I had seen references to a couple of functions but having trouble finding them again (or maybe it was my imagination).
- Is there a function that I can call in code to determine what tasks are currently running, or at least if a specific (named) task is running
- Is there a function that I can monitor in code to track a specific task's memory consumption
Re: Functions to display current tasks and memory usage
Posted: Mon Apr 02, 2018 3:27 am
by ESP_igrr
Posted: Mon Apr 02, 2018 11:44 am
by rwel59
I'm assuming that turning on the trace will impact size (and maybe performance)? Are there any non-debugging facilities available to get this info as part of 'normal' code operations?
Posted: Mon Apr 02, 2018 3:03 pm
by kolban
If we take a look at the FreeRTOS underlying API called "vTaskList" ... see:
https://www.freertos.org/a00021.html#vTaskList
we see that FreeRTOS itself requires trace enabled.
Posted: Wed Dec 05, 2018 7:56 pm
by snahmad75
I tried vTaskList. It does not shows cpu usage in percentage.
printf( "Task Name\tStatus\tPrio\tHWM\tTask\tAffinity\n");
char stats_buffer[1024];
vTaskList(stats_buffer);
printf("%s\n", stats_buffer);
Thanks,
Naeem
Posted: Wed Dec 05, 2018 9:42 pm
by fly135
Thanks,
Naeem
https://www.freertos.org/rtos-run-time-stats.html
Posted: Wed Dec 05, 2018 10:22 pm
by snahmad75
I did use vTaskGetRunTimeStats() but was not pretty output.
Give me example to show CPU usage per thread with columns and tabular form.
Thanks,
Naeem
Posted: Thu Jan 31, 2019 1:10 pm
by snahmad75
Kindly help please with nice pretty output of CPU stats.
I need to know CPU IDLE for both cpu0 and cpu1
Thanks,
Naeem
Posted: Thu Jan 31, 2019 1:45 pm
by jagpreetw
Hi
Can someone check my code for deep sleep. I am unable to get it below 9mA. Please help
#define uS_TO_S_FACTOR 1000000 /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP 3 /* Time ESP32 will go to sleep (in seconds) */
RTC_DATA_ATTR int bootCount = 0;
int GREEN_LED_PIN = 25;
int YELLOW_LED_PIN = 26;
void setup(){
pinMode(GREEN_LED_PIN,OUTPUT);
pinMode(YELLOW_LED_PIN,OUTPUT);
delay(500);
if(bootCount == 0) //Run this only the first time
digitalWrite(YELLOW_LED_PIN,HIGH);
bootCount = bootCount+1;
}else
digitalWrite(GREEN_LED_PIN,HIGH);
delay(3000);
digitalWrite(GREEN_LED_PIN,LOW);
digitalWrite(YELLOW_LED_PIN,LOW);
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
esp_deep_sleep_start();
void loop(){
