Page 1 of 2
ESP32 Bluetooth SPP with bidirectional communication (send and receive)
Posted: Fri Apr 06, 2018 10:40 am
by newsettler_AI
I need that ESP can send and receive data over SPP while connected to Android smartphone (let say, using any spp terminal I need to receive and send commands).
In IDF examples there are 2 examples for acceptor and initiator. I have checked acceptor and it works fine. Only one thing - it working only in one directional Android -> ESP.
Is it possible to make comunication bidirectional?
I'm looking over code in both acceptor and initiator and I'm not sure is it even possible, as I see at one example ESP is slave and in another master.
There are essential difference in callbacks for processing SPP events:
acceptor:
static const esp_spp_role_t role_slave = ESP_SPP_ROLE_SLAVE;
    case ESP_SPP_INIT_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_INIT_EVT");
        esp_bt_dev_set_device_name(EXCAMPLE_DEVICE_NAME);
        esp_bt_gap_set_scan_mode(ESP_BT_SCAN_MODE_CONNECTABLE_DISCOVERABLE);
        esp_spp_start_srv(sec_mask,role_slave, 0, SPP_SERVER_NAME);
        break;
    case ESP_SPP_DISCOVERY_COMP_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_DISCOVERY_COMP_EVT");
       // do nothing!!!
        break;
    case ESP_SPP_OPEN_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_OPEN_EVT");
       // do nothing!!!
        break;
initiator
static const esp_spp_role_t role_master = ESP_SPP_ROLE_MASTER;
        esp_bt_gap_start_discovery(inq_mode, inq_len, inq_num_rsps);
        break;
        ESP_LOGI(SPP_TAG, "ESP_SPP_DISCOVERY_COMP_EVT status=%d scn_num=%d",param->disc_comp.status, param->disc_comp.scn_num);
        if (param->disc_comp.status == ESP_SPP_SUCCESS) {
            esp_spp_connect(sec_mask, role_master, param->disc_comp.scn[0], peer_bd_addr);
        break;
        esp_spp_write(param->srv_open.handle, SPP_DATA_LEN, spp_data);
        gettimeofday(&time_old, NULL);
        break;
And which role should be Android smartphone in case bidirectional communication with ESP?
Please advice, maybe there are some ready robust solutions for bidirectional communication over SPP?
Re: ESP32 Bluetooth SPP with bidirectional communication (send and receive)
Posted: Fri Apr 06, 2018 1:11 pm
by loboris
You just have to combine receiving and sending, like in this simple example based on example_spp_acceptor_demo.c
   This example code is in the Public Domain (or CC0 licensed, at your option.)
   Unless required by applicable law or agreed to in writing, this
   software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
   CONDITIONS OF ANY KIND, either express or implied.
#include <stdint.h>
#include <string.h>
#include <stdbool.h>
#include <stdio.h>
#include "nvs.h"
#include "nvs_flash.h"
#include "freertos/task.h"
#include "esp_log.h"
#include "esp_bt.h"
#include "esp_bt_main.h"
#include "esp_gap_bt_api.h"
#include "esp_bt_device.h"
#include "esp_spp_api.h"
#include "time.h"
#include "sys/time.h"
#define SPP_TAG "SPP_ACCEPTOR_DEMO"
#define SPP_SERVER_NAME "SPP_SERVER"
#define EXCAMPLE_DEVICE_NAME "ESP_SPP_ACCEPTOR"
#define SPP_SHOW_DATA 0
#define SPP_SHOW_SPEED 1
#define SPP_SHOW_MODE SPP_SHOW_DATA    /*Choose show mode: show data or speed*/
static const esp_spp_mode_t esp_spp_mode = ESP_SPP_MODE_CB;
static struct timeval time_new, time_old;
static long data_num = 0;
static const esp_spp_sec_t sec_mask = ESP_SPP_SEC_NONE;
static void print_speed(void)
    float time_old_s = time_old.tv_sec + time_old.tv_usec / 1000000.0;
    float time_new_s = time_new.tv_sec + time_new.tv_usec / 1000000.0;
    float time_interval = time_new_s - time_old_s;
    float speed = data_num * 8 / time_interval / 1000.0;
    ESP_LOGI(SPP_TAG, "speed(%fs ~ %fs): %f kbit/s" , time_old_s, time_new_s, speed);
    data_num = 0;
    time_old.tv_sec = time_new.tv_sec;
    time_old.tv_usec = time_new.tv_usec;
static void esp_spp_cb(esp_spp_cb_event_t event, esp_spp_cb_param_t *param)
    char buf[1024];
    char spp_data[256];
    switch (event) {
        break;
        break;
        break;
    case ESP_SPP_CLOSE_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_CLOSE_EVT");
        break;
    case ESP_SPP_START_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_START_EVT");
        break;
    case ESP_SPP_CL_INIT_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_CL_INIT_EVT");
        break;
    case ESP_SPP_DATA_IND_EVT:
#if (SPP_SHOW_MODE == SPP_SHOW_DATA)
        ESP_LOGI(SPP_TAG, "ESP_SPP_DATA_IND_EVT len=%d handle=%d",
                 param->data_ind.len, param->data_ind.handle);
        if (param->data_ind.len < 1023) {
            snprintf(buf, (size_t)param->data_ind.len, (char *)param->data_ind.data);
            printf("%s\n", buf);
            sprintf(spp_data, "Receined characters: %d\n", param->data_ind.len);
            esp_spp_write(param->write.handle, strlen(spp_data), (uint8_t *)spp_data);
        else {
            esp_log_buffer_hex("",param->data_ind.data,param->data_ind.len);
#else
        gettimeofday(&time_new, NULL);
        data_num += param->data_ind.len;
        if (time_new.tv_sec - time_old.tv_sec >= 3) {
            print_speed();
#endif
        break;
    case ESP_SPP_CONG_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_CONG_EVT");
        break;
    case ESP_SPP_WRITE_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_WRITE_EVT");
        break;
    case ESP_SPP_SRV_OPEN_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_SRV_OPEN_EVT");
        break;
    default:
        break;
void app_main()
    esp_err_t ret = nvs_flash_init();
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES) {
        ESP_ERROR_CHECK(nvs_flash_erase());
    ESP_ERROR_CHECK( ret );
    esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
    if (esp_bt_controller_init(&bt_cfg) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s initialize controller failed\n", __func__);
        return;
    if (esp_bt_controller_enable(ESP_BT_MODE_CLASSIC_BT) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s enable controller failed\n", __func__);
        return;
    if (esp_bluedroid_init() != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s initialize bluedroid failed\n", __func__);
        return;
    if (esp_bluedroid_enable() != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s enable bluedroid failed\n", __func__);
        return;
    if (esp_spp_register_callback(esp_spp_cb) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s spp register failed\n", __func__);
        return;
    if (esp_spp_init(esp_spp_mode) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s spp init failed\n", __func__);
        return;
Tested with Bluetooth terminal Android application.
Posted: Wed Oct 10, 2018 3:52 am
by oclyke
Thanks loboris, worked great.
Posted: Sat Oct 27, 2018 10:18 pm
by PawelJalocha
Hello, I need the SPP mode too and actually I am not able to make it to work at all.
With some older ESP-IDF I was able to get to a point where the BT was reported as audio device thus could not connect it as serial port
with the newer ESP-IDF it is still reported as audio but is mostly dead thus no callbacks, etc.
Would appreciate help to make it work.
Pawel.
Posted: Sun Oct 28, 2018 2:19 pm
by tommeyers
This worked for me:
#include "BluetoothSerial.h"
//===== Preferences Manager:  (hack so that I can return a preference data type)
//                            see: https://playground.arduino.cc/Code/Struct#Creation
#include "name.h"
BluetoothSerial SerialBT;
void setup() {
  //add:     PreferenceAdd(preferenceName,preferenceLabel,defaultValue,regexValidation (javascript regex),description);
  preferenceAdd("wifiname",      "WiFi SSID",     "Wireless-N",         "^[A-Z|a-z|-]{5}$",                              "WiFi SSID");
  preferenceAdd("wifipwd",       "WiFi Password", "xyzzy3585",          "^[A-Z|a-z|0-9]{10}$",                           "WiFi Password");
  preferenceAdd("mqttip",        "MQTT IP",       "192.168.1.250",      "^[0-9|.{15}$",                                  "MQTT Broker IP");
  preferenceAdd("nodename",      "MQTT Node",     "Node01",             "^[A-Z|a-z|0-9]{5}$",                            "Node name for MQTT");
  Serial.begin(115200);
  setupBT();
String receivedSerialString   = "";
void loop() {
  processBT();
//==  BT interface for preferences/nvs ======================================================
String receivedSerialBTString = "";
void setupBT() {
  SerialBT.begin("ESP32test"); //Bluetooth device name
  SerialBT.flush();
  Serial.println("The device started, now you can pair it and connect from another bluetooth");
void processBT() {
  char receivedBTChar;
  while (SerialBT.available()) {
    receivedBTChar = SerialBT.read();
    receivedSerialBTString = receivedSerialBTString + receivedBTChar;
    if (receivedBTChar == '\n') {
      // ===== hello
      if (receivedSerialBTString.startsWith("hello")) {
          SerialBT.print("hello\n");
          continue;
      // ===== reboot
      if (receivedSerialBTString.startsWith("reboot")) {
          SerialBT.print("rebooting      - reconnect\n");
          //SerialBT.flush();
          //delay(1000);
          esp_restart();
      // ===== preferences get and update
      if (receivedSerialBTString.startsWith("preferences")) {
          if(receivedSerialBTString.substring(12).startsWith("get") ) {
            Serial.print("preferences/get");Serial.print(" senting: "); Serial.println(preferenceGetCount());
                            //        1         1         1         1
                            //0         1         2         3         4         5         6         7         8         9         0         1         2         1
                            //01234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
                            //                   name           label         value              regex                                     description
                            //preferences gotten wifiname       WiFi SSID     Wireless-N         /.*/                                      WiFi SSID\n");
            for (int i = 0; i < preferenceGetCount(); i++) {
              SerialBT.print("preferences gotten "
                             + (preferenceGetInfo(i).preferenceName   + "                                             ").substring(0,15)
                             + (preferenceGetInfo(i).preferenceLabel  + "                                             ").substring(0,14)
                             + (preferenceGetInfo(i).actualValue      + "                                             ").substring(0,19)
                             + (preferenceGetInfo(i).regexValidation  + "                                             ").substring(0,41)
                             + (preferenceGetInfo(i).description      + "                                             ").substring(0,23)
                             + "\n");
            continue;
          // ===== preferences update
          if(receivedSerialBTString.substring(12).startsWith("update") ) {
              //        1         1         1         1
              //                   name           value
              //preferences update wifiname       Wireless-N
              receivedSerialBTString = receivedSerialBTString + "                    ";  // trailing spaces so substring(19,33) is in range
              String nameString = receivedSerialBTString.substring(19,33);
              String valueString = receivedSerialBTString.substring(34);
              nameString.trim();  //because trim() modifies in-place see: https://www.arduino.cc/reference/en/language/variables/data-types/string/functions/trim/
              valueString.trim(); //because trim() modifies in-place see: https://www.arduino.cc/reference/en/language/variables/data-types/string/functions/trim/
              preferenceUpdate(nameString, valueString);
              continue;
          // ===== defaults
          if(receivedSerialBTString.substring(15).startsWith("defaults") ) {
            preferenceReset();
            continue;
      Serial.println("Unknown: " + receivedSerialBTString);
      continue;
// ===== Preferences Manager" Access to preference Name/Values in NVS
//       implements: Add (to list and NVS); Reset: (all values in list are set to defaults and NVS too); update: (change list value and NVS value)
//                   getCount and getPreference
#include <FS.h>
#include <Preferences.h>
Preferences preferences;
preferenceInfo preferenceList[20];
int preferenceCount = 0;
//===== Preferences Manager:  return one of the array
preferenceInfo preferenceGetInfo(int index) {
  return preferenceList[index];
//===== Preferences Manager:  return the count of preferences in the array
int preferenceGetCount() {
  return preferenceCount;
//===== Preferences Manager:  Adds a preference to the list and to the NVS "preferences"
void preferenceAdd(String preferenceName,String preferenceLabel,String defaultValue,String regexValidation,String description) { // Add an item and put its value (or default) in table
           // Serial.print(preferenceGetInfo[0].description);
            preferenceList[preferenceCount].preferenceName  = preferenceName;
            preferenceList[preferenceCount].preferenceLabel  = preferenceLabel;
            preferenceList[preferenceCount].defaultValue    = defaultValue;
            preferenceList[preferenceCount].regexValidation = regexValidation;
            preferenceList[preferenceCount].description     = description;
            preferences.begin("preferences",false);
            preferenceList[preferenceCount].actualValue = preferences.getString(preferenceName.c_str(), defaultValue.c_str());
            preferences.end();
            preferenceCount++;
//===== Preference Manager: Sets all preferences in the list to their default (does not clear/change others in NVS but not in list)
void preferenceReset() {                                               //clear all and set the list of values to their default
              for (int i = 0; i < preferenceCount; i++) {
                preferences.putString(preferenceList[i].preferenceName.c_str(), preferenceList[i].defaultValue.c_str());
                preferenceList[i].actualValue = preferences.getString(preferenceList[i].preferenceName.c_str(), preferenceList[i].defaultValue.c_str());
              preferences.end();
              return;
//===== Preference Manager: Changes the preference value in NVS and sets the actualValue in the list
void preferenceUpdate(String preferenceName,String preferenceValue) {  // Change an items value and update the table
              //Serial.println("compare:" + preferenceList[i].preferenceName + "/" + preferenceName + "/" +  preferenceValue);
              if (preferenceList[i].preferenceName == preferenceName) {
                //Serial.print("Changed:  "); Serial.print(preferenceName.c_str()); Serial.print("/"); Serial.println(preferenceValue.c_str());
                preferenceList[i].actualValue = preferenceValue;
                preferences.putString(preferenceName.c_str(),preferenceValue.c_str());
                //Serial.println("Verify:" +  preferences.getString(preferenceList[i].preferenceName.c_str(), "999"));
          preferences.end();
          return;
I access it with a my chrome add-in.
Posted: Sun Oct 28, 2018 3:32 pm
by PawelJalocha
OK, I am working with ESP-IDF and I actually got to the stage where I can see and pair the BT of my ESP32 in classic BT mode.
But, it refuses to connect, which I suspect is because the ESP32 is seen as audio-card and not a serial port.
Is there a way to resolve this situation ?
Are there any parameters on the ESP32 which affect the way external devices like laptops or tablets see the BT object ?
Pawel.
Posted: Sun Oct 28, 2018 4:48 pm
by tommeyers
You might try a BT sniffer to get more info.
I used BT Serial library and my esp32 presented SPP.
I also used a BT Sniffer in the process.
Posted: Sun Oct 28, 2018 5:06 pm
by PawelJalocha
Here is what I see with the Linux bluetoothctl:
Class: 0x2c0414
Icon: audio-card
Paired: yes
Trusted: no
Blocked: no
Connected: no
LegacyPairing: no
UUID: Serial Port (00001101-0000-1000-8000-00805f9b34fb)
RSSI: -54
the problem is the "audio-card" - this way laptops and tablets see this BT device.
Connection attempts fail with the message:
Failed to connect: org.bluez.Error.NotAvailable
Posted: Fri Feb 01, 2019 10:15 am
by georgecarlo
#include <stdint.h>
#include <string.h>
#include <stdio.h>
#include "nvs.h"
#include "esp_bt.h"
#include "time.h"
    data_num = 0;
    char buf[1024];
    char spp_data[256];
    switch (event) {
        break;
        break;
        break;
        break;
        break;
        break;
        else {
#else
            print_speed();
#endif
        break;
        break;
        break;
        break;
    default:
        break;
void app_main()
        return;
        return;
        return;
        return;
        return;
        return;
sorry for the bump, but i need some clarification. thanks loboris, this code works, but this comes under data_ind event. i just want to perform a loop function(i have one) when bt connects so that the code prints with esp_spp_write until loop ends, where do i need to place the code in the event??
Posted: Fri Feb 01, 2019 11:11 am
by gunar.kroeger
I find that the best way is to put your loop with esp_spp_write on a separate task.
To receive replies, make a queue and use the event only to put received messages into the queue, and process the message from the queue on the task also.
But I suggest using a strict request-reply protocol, because if you try to send messages in bulk you will end up getting congestion events and losing data. Until this day we haven't got a solution to this (https://www.esp32.com/viewtopic.php?f=1 ... 3&start=10) and will have to deal with low throughput
