Getting Local Time without gmt Offset after Deep Sleep
carlossilva132
Postby carlossilva132 » Sun Apr 15, 2018 10:48 pm
I'm getting time with SNTP (-3:00GMT), setting RTC with configTime. Check time, is ok.
Go to sleep.
After wake up, the time is wrong (0GMT), without gmtOffset.
I need to use setenv(); and tzset()? How?
/* Pega horário no SNTP e acerta o relógio interno
faz o sleep para verificar se o relógio continua funcionando.
#include <WiFi.h>
#include "time.h"
#include "esp_deep_sleep.h"
#define uS_TO_m_FACTOR 60000000   // Conversion factor for micro seconds to minutes
#define TIME_TO_SLEEP  1        // Time ESP32 will go to sleep (in minutes)
const char* ssid       = "xxxxxx";
const char* password   = "xxxxxxx";
const char* ntpServer = "200.160.7.186"; // "a.st1.ntp.br";
const long  gmtOffset_sec = -3 * 3600;
const int   daylightOffset_sec = 0;  // se estiver horário verão=3600;
void printLocalTime()
  struct tm timeinfo;
  if(!getLocalTime(&timeinfo)){
    Serial.println("Failed to obtain time");
    return;
  Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S");
  Serial.print("Epoch:");
  Serial.println(mktime(&timeinfo));
void setup()
  Serial.printf("Connecting to %s ", ssid);
  WiFi.begin(ssid, password);
      delay(500);
  //init and get the time
  struct tm timeinfo2;
  if(!getLocalTime(&timeinfo2)){
    Serial.println("Relógio nao foi configurado.");
    configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
  printLocalTime();
  WiFi.disconnect(true);
  WiFi.mode(WIFI_OFF);
  esp_deep_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_m_FACTOR);
  Serial.println("Going to sleep now");
  esp_deep_sleep_start();
void loop()
  delay(5000);
  printLocalTime();
papaluna
Re: Getting Local Time without gmt Offset after Deep Sleep
Postby papaluna » Mon Apr 16, 2018 9:07 am
In ESP-IDF you would do this:
void mjd_set_timezone_utc() {
    ESP_LOGD(TAG, "%s()", __FUNCTION__);
    // @special "" means timezone UTC (Specifying "UTC" does not work!)
    setenv("TZ", "", 1);
    tzset();
void mjd_set_timezone_amsterdam() {
    // @doc https://remotemonitoringsystems.ca/time-zone-abbreviations.php
    // @doc timezone UTC = UTC
    setenv("TZ", "CET-1CEST-2,M3.5.0/02:00:00,M10.5.0/03:00:00", 1);
    tzset();
Paul.
carlossilva132
Postby carlossilva132 » Sat Apr 21, 2018 3:22 pm
Paul,
it's works (in Arduino)!
Thank you very much!
doronby
Postby doronby » Thu Jan 31, 2019 6:11 pm
can you please post a complete code that works.
Thanks !
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 213 guests
