I'm using OTA to update the firmware and would like to be able to go back to the factory partition should I download a bad update or anything goes wrong that causes a continuous exception/reboot cycle. If I could capture the exception and "if" the system is still stable enough to execute a command to erase the OTADATA partition then reboot back to the stable factory partition. Anybody got an idea about how to do this? Seems like every time I have a question somebody posts a link to the docs that I missed. I searched the docs for exception but nothing came up of obvious use.
John A
Capturing an exception crashing the app
Re: Capturing an exception crashing the app
Howdy John,
I think we want to break apart the puzzle into multiple piece. The first piece would be detection that "something wrong" and the second would be "repair".
To detect that something is wrong, we might have to invent an algorithm.
Lets assume that you always get control in app_main in order to still have some semblance of control. An algorithm might be:
The crash counter can be in NVS for persistence between boots.
main() {
if (reason for reboot is previous crash) {
increment crash counter;
if crash counter > 10 {
Perform repair;
reboot
set crash counter to 0;
Seems like a chicken and egg problem. "reason for reboot is previous crash" is what I'm trying to get from capturing the exception.
This could work... but I'd still like to capture that exception if possible.
main()
if (nvs says "reboot")
else if ( nvs says "run" )
Perform repair;
reboot
else
printf("first run nvs is not inited")
set crash count to zero
nvs write "run"
... do stuff
void normal_shutdown()
nvs write "reboot"
reboot
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 107 guests
